单片机
C51读写AT24C04源代码及AT24C04测试程序
2023-04-03 来源:elecfans
一、C51读写AT24C04源代码
/*;起动24C01时序*/
void Start()
SCL=1;
SDA=1;
SDA=0;
SCL=0;
/*;停止24C01时序*/
void Stop()
SDA=0;
SCL=1;
SDA=1;
/*;检测24C01的响应信号*/
bit ACK()
bit c;
SDA=1;
SCL=1;
c=SDA;
SCL=0;
return c;
/*;往24C01发一8位数据*/
void SendChar(unsigned char ch)
unsigned char i;
i=8;
do
SDA=(ch&0x80);
SCL=1;
SCL=0;
ch《《=1;
}while(--i!=0);
/*;从24C01接收一8位数据*/
unsigned char RecChar()
unsigned char i,j;
i=8;
do
SCL=1;
j=(j《《1)|SDA;
SCL=0;
}while(--i!=0);
return j;
/*;往24C01写一字节*/
void WriteChar(unsigned int addr,unsigned char ch)
unsigned char c;
c=((*((unsigned char *)&addr))《《1)&0x02;
Start();
SendChar(0xa0|c);
ACK();
SendChar(addr);
ACK();
SendChar(ch);
ACK();
Stop();
// for(addr=4;addr!=0;addr--)
for(ch=0xff;ch!=0;ch--) ;
/*;往24C01写多字节*/
void WriteBuf(unsigned int addr,unsigned char idata *buf,unsigned char count)
unsigned char c;
Start();
SendChar(0xa0|c);
ACK();
SendChar(addr);
ACK();
do
SendChar(*buf++);
ACK();
if(count!=1)
{if(((++addr)&0x7)==0)
Stop();
for(c=0xff;c!=0;c--) ;
Start();
SendChar(0xa0|c);
ACK();
SendChar(addr);
ACK();
else
Stop();
}while(--count!=0);
/*;从24C01读一字节*/
/*;入口:R0中为要读出内容的地址*/
/*;出口:A中为读到的内容*/
unsigned char ReadChar(unsigned int addr)
unsigned char ch;
ch=((*((unsigned char *)&addr))《《1)&0x02;
Start();
SendChar(0xa0|ch);
ACK();
SendChar(addr);
ACK();
Start();
SendChar(0xa1|ch);
ACK();
ch=RecChar();
Stop();
return ch;
/*至少读2字节*/
void ReadBuf(unsigned int addr,unsigned char idata *buf,unsigned char count)
unsigned char ch;
Start();
SendChar(0xa0|ch);
ACK();
SendChar(addr);
ACK();
Start();
SendChar(0xa1|ch);
ACK();
count--;
do
*buf++=RecChar();
SDA=0;
SCL=1;
SCL=0;
SDA=1;
}while(--count!=0);
*buf=RecChar();
Stop();
二、AT24C04测试程序
主芯片 : STC12C5A60S2 (1T)
工作频率: 12.000MHz
#include “REG51.H”
#include “INTRINS.H”
typedef unsigned char BYTE;
typedef unsigned short WORD;
sbit SCL = P3^4; //AT24C04的时钟
sbit SDA = P3^5; //AT24C04的数据
BYTE BUF[16]; //数据缓存区
BYTE code TESTDATA[] =
0x00,0x11,0x22,0x33,0x44,0x55,0x66,0x77,
0x88,0x99,0xAA,0xBB,0xCC,0xDD,0xEE,0xFF
void Delay5us();
void Delay5ms();
void AT24C04_Start();
void AT24C04_Stop();
void AT24C04_SendACK(bit ack);
bit AT24C04_RecvACK();
void AT24C04_SendByte(BYTE dat);
BYTE AT24C04_RecvByte();
void AT24C04_ReadPage();
void AT24C04_WritePage();
void main()
Delay5ms();
AT24C04_ReadPage();
while (1);
向AT24C04写1页(16字节)数据
将TESTDATA开始的16个测试数据写如设备的00~0F地址中
BYTE i;
AT24C04_Start(); //起始信号
AT24C04_SendByte(0xa0); //发送设备地址+写信号
AT24C04_SendByte(0x00); //发送存储单元地址
for (i=0; i《16; i++)
AT24C04_SendByte(TESTDATA[i]);
AT24C04_Stop(); //停止信号
从AT24C04读取1页(16字节)数据
将设备的00~0F地址中的数据读出存放在DATA区的BUF中
BYTE i;
AT24C04_SendByte(0xa1); //发送设备地址+读信号
BUF[i] = AT24C04_RecvByte();
if (i == 15)
AT24C04_SendACK(1); //最后一个数据需要会NAK
else
AT24C04_SendACK(0); //回应ACK
延时5微秒(STC12C5A60S2@12M)
不同的工作环境,需要调整此函数
此延时函数是使用1T的指令周期进行计算,与传统的12T的MCU不同
void Delay5us()
BYTE n = 4;
while (n--)
_nop_();
_nop_();
延时5毫秒(STC12C5A60S2@12M)
不同的工作环境,需要调整此函数
void Delay5ms()
WORD n = 2500;
while (n--)
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
起始信号
SDA = 1; //拉高数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 0; //产生下降沿
Delay5us(); //延时
SCL = 0; //拉低时钟线
停止信号
void AT24C04_Stop()
SDA = 0; //拉低数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 1; //产生上升沿
Delay5us(); //延时
发送应答信号
入口参数:ack (0:ACK 1:NAK)
SDA = ack; //写应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
接收应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
CY = SDA; //读应答信号
SCL = 0; //拉低时钟线
Delay5us(); //延时
return CY;
向IIC总线发送一个字节数据
BYTE i;
for (i=0; i《8; i++) //8位计数器
dat 《《= 1; //移出数据的最高位
SDA = CY; //送数据口
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
AT24C04_RecvACK();
从IIC总线接收一个字节数据
BYTE i;
BYTE dat = 0;
SDA = 1; //使能内部上拉,准备读取数据
dat 《《= 1;
SCL = 1; //拉高时钟线
Delay5us(); //延时
dat |= SDA; //读数据
SCL = 0; //拉低时钟线
Delay5us(); //延时
return dat;
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • 用数字电路CD4069制作的万能遥控轻触开关
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 开关电源的基本组成及工作原理
  • 用NE555制作定时器
  • 带有短路保护系统的5V直流稳压电源电路图
    相关电子头条文章
