单片机
59pic USART 232汇编程序
2017-12-06 来源:eefocus
INCLUDE          ;MCU PIC16F877  DIP40
LIST     P=PIC16F877
;__CONFIG  _CP_OFF & _DEBUG_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC & _LVP_OFF  ;PIC16F877
;__IDLOCS 0x7206
 errorlevel  -302
   errorlevel  -203
CBLOCK  20H
COUNTERH
COUNTERL
COUNTER
TEMP1
TEMP2
TEMP3
TEMP4
TEMP_A
TEMP_B
TEMP_C
DADR
CNT
EE_DADR
ENDC
#DEFINE START_KEY PORTB,1
#DEFINE BELL  PORTD,0
 ORG 00H
 NOP
 GOTO START
 ORG 04H
 GOTO _INT
; ORG 0100H
;查问题回答 1 字符表(共 25 个字符)
TABLE1
 ADDWF PCL,F
 DT '\n\r-My name is P16F877.\n\n\r'
      ;\n 换行
      ;\r 回车
;查问题回答 2 字符表(共 22 个字符)
TABLE2
 ADDWF PCL,F
 DT '\n\r-I’m 3 years old.\n\n\r'
;查问题回答 3 字符表(共 27 个字符)
TABLE3
 ADDWF PCL,F
 DT '\n\r-I’m born in ShangHai.\n\n\r'
;查问题回答 4 字符表(共 34 个字符)
TABLE4
 ADDWF PCL,F
 DT '\n\r-Yes,I like sports very much.\n\n\r'
;查问题回答 5 字符表(共 28 个字符)
TABLE5
 ADDWF PCL,F
 DT '\n\r-The date is 2007-2-15.\n\n\r'
;初始化和提示信息字符表(共 74 个字符)
TABLE
 ADDWF PCL,F
 DT '\nHello!\n\r'
 DT 'I’m your new friend,Nice to meet you.'
 DT 'What do you want to know?\n\n\r'
 ORG 0100H
;问题 5 字符表(共 22 个字符)
TAB5
 ADDWF PCL,F
 DT 'What’s the date today?'
;问题 4 字符表(共 19 个字符)
TAB4
 ADDWF PCL,F
 DT 'Do you like sports?'
;问题 3 字符表(共 20 个字符)
TAB3
 ADDWF PCL,F
 DT 'Where were you born?'
;问题 2 字符表(共 16 个字符)
TAB2
 ADDWF PCL,F
 DT 'How old are you?'
;问题 1 字符表(共 17 个字符)
TAB1
 ADDWF PCL,F
 DT 'What’s your name?'
;错误提示 1 字符表(共 64 个字符)
TABLE6
 ADDWF PCL,F
 DT '\n\r-Sorry.I CANnot answer the question.'
 DT 'Please ask another one.\n\n\r'
;错误提示 2 字符表(共 48 个字符)
TABLE7
 ADDWF PCL,F
 DT '\n\r-What your enter is wrong.Please try again.\n\n\r'
 ORG 0200H
_INT
 NOP
 NOP
 RETFIE
START
        NOP
        BSF      STATUS,RP0 ;定义RA口,RC口全部为输出
        MOV LW    06H  ;
        MOV WF    ADCON1  ;设置RA口全部为普通数字IO口
        MOV LW    B’00110000’ ;
        MOV WF    TRISA
        MOV LW    B’11011000’ ;设置SCL为输入, SDA为输入
        MOV WF    TRISC
        MOV LW    00H
        MOV WF    TRISD  ;
  MOV LW 0FFH
  MOV WF TRISB
 BCF OPTION_REG,7
        BCF      STATUS,RP0
;**********   IIC 初始化设置  ************
  MOV LW 08H             ;初始化SSPCON,
  MOV WF SSPCON          ;IIC主控模式
 BCF PIR1,SSPIF
 BSF STATUS,RP0
  MOV LW 80H             ;初始化SSPSTAT寄存器,
  MOV WF SSPSTAT         ;传送速率为标准模式100KHz
  MOV LW 09H
  MOV WF SSPADD          ;设定IIC时钟频率
 CLRF SSPCON2         ;初始化SSPCON2
 BSF PIE1,SSPIE      ;SSP中断允许
 CLRF INTCON
 BSF INTCON,PEIE     ;开中断
 BSF INTCON,GIE
 BCF STATUS,RP0
 BSF SSPCON,SSPEN    ;SSP模块使能
;**********   IIC 初始化设置结束  ************
;**********   USART 初始化设置开始  ************
ST BSF STATUS,RP0
  MOV LW B’00100100’
  MOV WF TXSTA  ;异步方式,高波特率,发送使能
  MOV LW .25
  MOV WF SPBRG  ;设置波特率 9600,Fosc=4MHz
 BCF STATUS,RP0
  MOV LW B’10010000’ ;设置连续接收数据
  MOV WF RCSTA
; CLRF INTCON
 BSF STATUS,RP0
 CLRF PIE1
 BCF STATUS,RP0
;**********   USART 初始化设置结束  ************
 CLRF     PORTA
;       CLRF     PORTB
        CLRF     PORTD
 CALL CLR_RAM
BEGIN
;Read Test Counter Value from EEPROM***********************
  MOV LW 20H  ;read counterl counterh from eeprom
  MOV WF DADR
  MOV LW .2
  MOV WF CNT
  MOV LW 00H
  MOV WF EE_DADR
 CALL EE_READ
;Compare Test Counter Value is zero?************************
 CLRZ
  MOV F COUNTERH,F
 BTFSS STATUS,Z
 GOTO PRESS_START_KEY
 CLRZ
  MOV F COUNTERL,F
 BTFSS STATUS,Z
 CALL _ERROR_BELL
 GOTO BEGIN
PRESS_START_KEY
        BTFSC    START_KEY         ;按开始键开始测试
        GOTO     $-1
        CALL     DELAY20MS
        BTFSC    START_KEY
        GOTO     $-4
        BTFSS    START_KEY
        GOTO     $-1
        CALL     DELAY20MS
        BTFSS    START_KEY
        GOTO     $-4
;Test Counter decrease 1****************************
  MOV LW .1  ;conter decrease 1
 SUBWF COUNTERL,F
 BTFSS STATUS,C
 DECF COUNTERH,F
 CALL RAM_TO_EE ;write counterl counterh to eeprom
; GOTO BEGIN
;输出问候语
CSH
  MOV F COUNTER,W
; BSF PCLATH,0
 CALL TABLE
; BCF PCLATH,0
 CALL FASONG
 CALL DELAY3
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .74
 BTFSS STATUS,Z
 GOTO CSH
;开始检测并储存外界输入
LOOP
 CLRF PIR1  ;清 RCIF
 CLRF COUNTER
  MOV LW 30H
  MOV WF FSR
 BCF PIR1,RCIF
JIESHU NOP
LRC BTFSS PIR1,RCIF
 GOTO LRC
  MOV F RCREG,W
 SUBLW '\r'  ;与 Enter 对应的 ASCII 码比较
 BTFSC STATUS,Z
 GOTO WTPD  ;按了回车键,转判断子程序
  MOV F RCREG,W
 SUBLW '\b'  ;与退格键 BacksPACe 对应的 ASCII 码比较
 BTFSC STATUS,Z
 GOTO TUIGE  ;按了退格键,转退格处理
  MOV F RCREG,W
 CALL FASONG
  MOV WF INDF
 INCF FSR
 GOTO LRC
;退格处理子程序
TUIGE
  MOV F RCREG,W
 CALL FASONG
 DECF FSR
 GOTO LRC
;问题判断子程序
WTPD
  MOV F RCREG,W
  MOV WF INDF
;和第一个问题进行比较
PD1
 CLRF COUNTER
  MOV LW 30H
  MOV WF FSR
LP1
  MOV F COUNTER,W
; BSF PCLATH,1
 BSF PCLATH,0
 CALL TAB1
 BCF PCLATH,0
; BCF PCLATH,1
 SUBWF INDF,W  ;查表所得的数据与 INDF 的内容相减,结果送 W
 BTFSS STATUS,Z
 GOTO PD2  ;内容不符,转 PD2 判断
 INCF FSR  ;内容相符,数据存储地址加一
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .17  ;判断是否已到第一个问题的 17 个字符数
 BTFSS STATUS,Z
 GOTO LP1  ;没到,继续第一个问题的判断
  MOV LW '\r'  ; Enter ??
 SUBWF INDF,W
 BTFSS STATUS,Z
 GOTO CUOWU2  ;不相等,后面还有内容,转到错误提示2
 CLRF COUNTER
 GOTO HD1  ;转到回答1
;和第二个问题进行比较
PD2
 CLRF COUNTER
  MOV LW 30H
  MOV WF FSR
LP2
  MOV F COUNTER,W
; BSF PCLATH,1
 BSF PCLATH,0
 CALL TAB2
 BCF PCLATH,0
; BCF PCLATH,1
 BTFSS STATUS,Z
 GOTO PD3  ;内容不符,转 PD3 判断
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .16  ;判断是否已到第一个问题的 16 个字符数
 BTFSS STATUS,Z
 GOTO LP2  ;没到,继续第一个问题的判断
 SUBWF INDF,W
 BTFSS STATUS,Z
 CLRF COUNTER
 GOTO HD2  ;转到回答2
;和第三个问题进行比较
PD3
 CLRF COUNTER
  MOV LW 30H
  MOV WF FSR
LP3
  MOV F COUNTER,W
; BSF PCLATH,1
 BSF PCLATH,0
 CALL TAB3
 BCF PCLATH,0
; BCF PCLATH,1
 BTFSS STATUS,Z
 GOTO PD4  ;内容不符,转 PD4 判断
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .20  ;判断是否已到第一个问题的 20 个字符数
 BTFSS STATUS,Z
 GOTO LP3  ;没到,继续第一个问题的判断
 SUBWF INDF,W
 BTFSS STATUS,Z
 CLRF COUNTER
 GOTO HD3  ;转到回答3
;和第四个问题进行比较
PD4
 CLRF COUNTER
  MOV LW 30H
  MOV WF FSR
LP4
  MOV F COUNTER,W
; BSF PCLATH,1
 BSF PCLATH,0
 CALL TAB4
 BCF PCLATH,0
; BCF PCLATH,1
 BTFSS STATUS,Z
 GOTO PD5  ;内容不符,转 PD5 判断
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .19  ;判断是否已到第一个问题的 19 个字符数
 BTFSS STATUS,Z
 GOTO LP4  ;没到,继续第一个问题的判断
 SUBWF INDF,W
 BTFSS STATUS,Z
 CLRF COUNTER
 GOTO HD4  ;转到回答4
;和第五个问题进行比较
PD5
 CLRF COUNTER
  MOV LW 30H
  MOV WF FSR
LP5
  MOV F COUNTER,W
; BSF PCLATH,1
 BSF PCLATH,0
 CALL TAB5
 BCF PCLATH,0
; BCF PCLATH,1
 BTFSS STATUS,Z
 GOTO CUOWU  ;内容不符,转 CUOWU 提示1
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .22  ;判断是否已到第一个问题的 16 个字符数
 BTFSS STATUS,Z
 GOTO LP5  ;没到,继续第一个问题的判断
 SUBWF INDF,W
 BTFSS STATUS,Z
 CLRF COUNTER
 GOTO HD5  ;转到回答2
;输出回答 1
HD1
  MOV F COUNTER,W
; BSF PCLATH,0
 CALL TABLE1
; BCF PCLATH,0
 CALL FASONG
 CALL DELAY3
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .25
 BTFSS STATUS,Z
 GOTO HD1
 GOTO LOOP  ;输出完毕,转到输出检测
;输出回答 2
HD2
  MOV F COUNTER,W
; BSF PCLATH,0
 CALL TABLE2
; BCF PCLATH,0
 CALL FASONG
 CALL DELAY3
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .22
 BTFSS STATUS,Z
 GOTO HD2
;输出回答 3
HD3
  MOV F COUNTER,W
; BSF PCLATH,0
 CALL TABLE3
; BCF PCLATH,0
 CALL FASONG
 CALL DELAY3
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .27
 BTFSS STATUS,Z
 GOTO HD3
;输出回答 4
HD4
  MOV F COUNTER,W
; BSF PCLATH,0
 CALL TABLE4
; BCF PCLATH,0
 CALL FASONG
 CALL DELAY3
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .34
 BTFSS STATUS,Z
 GOTO HD4
;输出回答 5
HD5
  MOV F COUNTER,W
; BSF PCLATH,0
 CALL TABLE5
; BCF PCLATH,0
 CALL FASONG
 CALL DELAY3
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .28
 BTFSS STATUS,Z
 GOTO HD5
; GOTO LOOP  ;输出完毕,转到输出检测
 CLRF COUNTER
 CALL DELAY1S
 CALL _PASS_BELL
 GOTO BEGIN
;输出错误提示 1
CUOWU
 CLRF COUNTER
LP6  MOV F COUNTER,W
; BSF PCLATH,1
 BSF PCLATH,0
 CALL TABLE6
 BCF PCLATH,0
; BCF PCLATH,1
 CALL FASONG
 CALL DELAY3
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .64
 BTFSS STATUS,Z
 GOTO LP6
 GOTO LOOP
;输出错误提示 2
CUOWU2
 CLRF COUNTER
LP7  MOV F COUNTER,W
; BSF PCLATH,1
 BSF PCLATH,0
 CALL TABLE7
 BCF PCLATH,0
; BCF PCLATH,1
 CALL FASONG
 CALL DELAY3
 INCF COUNTER
  MOV F COUNTER,W
 SUBLW .48
 BTFSS STATUS,Z
 GOTO LP7
 GOTO LOOP
;USART 方式发送数据子程序
FASONG
  MOV WF TXREG
 BSF STATUS,RP0
 BTFSS TXSTA,TRMT
 GOTO $-1
 BCF STATUS,RP0
 RETURN
CLR_RAM
  MOV LW 20H
  MOV WF FSR
 CLRF INDF
 INCF FSR,F
 BTFSS FSR,7
 GOTO $-3
 RETURN
;***********************_ERROR_BELL 子程序  **********************************
_ERROR_BELL
        CALL     _PASS_BELL
        CALL     DELAY200MS
        CALL     DELAY200MS
        CALL     _PASS_BELL
        CALL     DELAY200MS
        CALL     DELAY200MS
        CALL     _PASS_BELL
        CALL     DELAY200MS
        CALL     DELAY200MS
        RETURN
;***********************_PASS_BELL 子程序  **********************************
_PASS_BELL
  MOV LW   .20
  MOV WF   TEMP_A
BELL2
  MOV LW   .190
  MOV WF   TEMP_B
BELL1
 BSF     BELL  ;频率 Hz
 CALL DELAY125US
 BCF     BELL
 CALL DELAY125US
 DECFSZ  TEMP_B,1
 GOTO    BELL1
 DECFSZ  TEMP_A,1
 GOTO    BELL2
 RETURN
DELAY50US
        MOV lw     .15              ;DELAY50US
        MOV wf     TEMP1
        decfsz    TEMP1,F
        goto      $-1
 RETLW 0
;*********************** 250uS 延时子程序 1 **************
DELAY125US
  MOV LW .42
  MOV WF TEMP_C
 DECFSZ  TEMP_C,F
 GOTO     $-1
 RETURN
DELAY1MS
        MOV lw     .2
        MOV wf     TEMP2
        MOV lw     .170
        MOV wf     TEMP1
        DECFSZ   TEMP1,F
        goto      $-1
        DECFSZ   TEMP2,F
        GOTO     $-5
        RETURN
DELAY10MS
 CALL DELAY1MS
 CALL DELAY1MS
 CALL DELAY1MS
 CALL DELAY1MS
 CALL DELAY1MS
 CALL DELAY1MS
 CALL DELAY1MS
 CALL DELAY1MS
 CALL DELAY1MS
 CALL DELAY1MS
 RETLW 0
;延时子程序,约 10MS
DELAY3
  MOV LW .20
  MOV WF TEMP1
LOOP1
  MOV LW .166
  MOV WF TEMP2
 DECFSZ TEMP2
 GOTO $-1
 DECFSZ TEMP1
 GOTO LOOP1
 RETURN
;延时 20MS 子程序
DELAY20MS
        MOV lw     .40
        MOV wf     TEMP2
DELAY20MS_1
        MOV lw     .166
        MOV wf     TEMP1
        DECFSZ   TEMP1,F
        goto      $-1
        DECFSZ   TEMP2,F
        GOTO     DELAY20MS_1
        RETURN
DELAY200MS
        MOV lw     .10
        MOV wf     TEMP3
DELAY200MS_2
        MOV lw     .40
        MOV wf     TEMP2
DELAY200MS_1
        MOV lw     .166
        MOV wf     TEMP1
        DECFSZ   TEMP1,F
        goto      $-1
        DECFSZ   TEMP2,F
        GOTO     DELAY200MS_1
        DECFSZ   TEMP3,F
        GOTO     DELAY200MS_2
        RETURN
DELAY1S
        MOV lw     .50
        MOV wf     TEMP3
DELAY1S_2
        MOV lw     .40
        MOV wf     TEMP2
DELAY1S_1
        MOV lw     .166
        MOV wf     TEMP1
        DECFSZ   TEMP1,F
        goto      $-1
        DECFSZ   TEMP2,F
        GOTO     DELAY1S_1
        DECFSZ   TEMP3,F
        GOTO     DELAY1S_2
        RETURN
RAM_TO_EE:
  MOV LW 20H
  MOV WF DADR
  MOV LW .2
  MOV WF CNT
  MOV LW 00H
  MOV WF EE_DADR
 CALL EE_WRITE
 RETURN
;*********************************EE_WRITE***********************************
;本程序实现从内部RAM传送多字节数据到内部EEPROM。
;入口参数:原操作数的地址放在DADR中,目标EEPROM的地址放在EE_DADR中,字节数在W中。
;出口参数:相关数据已写入指定EEPROM单元中。
;占用资源:W,STATUS,FSR,一重堆栈。
EE_WRITE:
  MOV F DADR,W
  MOV WF FSR            ;RAM 单元首地址
  MOV F EE_DADR,W
 BANKSEL PIE1  ;BANK1
 BCF PIE1,EEIE      ;关闭EE中断
 BANKSEL EEADR  ;BANK2
  MOV WF EEADR          ;将目标地址写入EEADR
EE_LOOP2:
 BANKSEL PORTA  ;BANK0
  MOV F INDF,W
 BANKSEL EEDATA  ;BANK2
  MOV WF EEDATA         ;将源数据写入EEDATA
 BANKSEL EECON1  ;BANK3
 BCF EECON1,EEPGD ;指定 EEPROM 为操作对象
 BSF EECON1,WREN    ;写允许
 BCF INTCON,GIE     ;关闭中断
  MOV LW 55H            ;MICROChip
  MOV WF EECON2         ;规
  MOV LW 0XAA           ;定
  MOV WF EECON2         ;代码
 BSF EECON1,WR      ;开始写入
 BCF EECON1,WREN    ;写保护
 BTFSC EECON1,WR      ;写完了吗?
 GOTO $-1
  INCF FSR,F          ;写下一个数据
  INCF EEADR,F
 DECFSZ CNT,F          ;所有字节的数据写完了吗?
 GOTO NEXT1
 BSF INTCON,GIE     ;重新开总中断
  RETURN
NEXT1:
  GOTO EE_LOOP2
;********************************EE_READ***********************************
;本程序实现从内部连续的EEPROM单元传送多字节数据到内部RAM。
;入口参数:原操作数在EEPROM中的首地址放在EE_DADR中,目标RAM的首地址放在DADR中,
;          字节数放在CNT中。
;出口参数:相关数据已在指定的连续RAM单元中
;占用资源:W,STATUS,FSR,内部EEPROM模块,一重堆栈。
EE_READ:
  MOV F DADR,W
  MOV WF FSR          ;目标RAM的地址
  MOV F EE_DADR,W
  MOV WF EEADR        ;地址
EE_READ1:
 BSF EECON1,RD    ;开始读取
  MOV F EEDATA,W
  MOV WF INDF         ;依次取出连续的数据
 INCF FSR,F
 INCF EEADR,F
 DECFSZ CNT,F        ;判断所有字节的数据是否取完
 GOTO EE_READ1
 RETURN
 ORG 0x2100
 DE 00H,0AH,00H,00H,00H,00H
 END
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 简洁的过零调功器电路设计与分析
  • 永不缺相启动运行的电动机控制电路
  • IGBT模块通过控制门极阻断过电流
  • 比较常见的功率整流器和滤波电路
  • 基于M66T旋律发​​生器的电路图解析
  • 基于CA3193的热电偶放大器电路
    相关电子头条文章
