PIC单片机的一个简单的SPI小程序
2019-10-30 来源:51hei
这里介绍一个简单的PIC单片机SPI测试小程序,希望大家能够喜欢。
// DAC module connections
sbit Chip_Select at RC0_bit;
sbit Chip_Select_Direction at TRISC0_bit;
// End DAC module connections
unsigned int value;
void InitMain() {
TRISA0_bit = 1; // Set RA0 pin as input
TRISA1_bit = 1; // Set RA1 pin as input
Chip_Select = 1; // Deselect DAC
Chip_Select_Direction = 0; // Set CS# pin as Output
SPI1_Init(); // Initialize SPI module
// DAC increments (0..4095) --> output voltage (0..Vref)
void DAC_Output(unsigned int valueDAC) {
char temp;
Chip_Select = 0; // Select DAC chip
// Send High Byte
temp = (valueDAC >> 8) & 0x0F; // Store valueDAC[11..8] to temp[3..0]
temp |= 0x30; // Define DAC setting, see MCP4921 datasheet
SPI1_Write(temp); // Send high byte via SPI
// Send Low Byte
temp = valueDAC; // Store valueDAC[7..0] to temp[7..0]
SPI1_Write(temp); // Send low byte via SPI
Chip_Select = 1; // Deselect DAC chip
void main() {
ANSEL = 0;
ANSELH = 0;
InitMain(); // Perform main initialization
value = 2048; // When program starts, DAC gives
// the output in the mid-range
while (1) { // Endless loop
if ((RA0_bit) && (value < 4095)) { // If RA0 button is pressed
value++; // increment value
else {
if ((RA1_bit) && (value > 0)) { // If RA1 button is pressed
value--; // decrement value
DAC_Output(value); // Send value to DAC chip
Delay_ms(1); // Slow down key repeat pace
