单片机
2440下的IIC实验
2016-11-27 来源:eefocus
#include '2440addr.h'
extern void Uart_Printf(char *fmt,...);
void Wr24C02(U32 slvAddr,U32 addr,U8 data);
void Rd24C02(U32 slvAddr,U32 addr,U8 *data);
void Run_IicPoll(void);
void IicPoll(void) ;
void Delay(int x) ;
static U8 iicData[IICBUFSIZE];
static volatile int iicDataCount;
static volatile int iicStatus;
static volatile int iicMode;
static int iicPt;
void iicMain(void)
    unsigned int i,j;
    static U8 data[256];
    Uart_Printf('IIC Test(Polling) using AT24C02\n');
    //设置GPE15->IICSDA 和 GPE14->IICSCL
    rGPEUP  |= 0xc000;                  //Pull-up disable
    rGPECON &= ~0xf0000000;
    rGPECON |= 0xa0000000;              //GPE15:IICSDA , GPE14:IICSCL
 //Enable ACK, Prescaler IICCLK=PCLK/16, Enable interrupt, Transmit clock value Tx clock=IICCLK/16
    rIICCON    = (1<<7) | (0<<6) | (1<<5) | (0xf);  //0xaf
    rIICADD  = 0x10;                    //2440 slave address = [7:1]
    rIICSTAT = 0x10;                     //IIC bus data output enable(Rx/Tx)
    Uart_Printf('Write test data into AT24C02\n');
//写入一个page的数据,page的大小是256byte,
    //page 的起始地址是0xa0,写入的数据是:0、1、2、...255。0xa0是AT24C02的页地址。
    //AT24C02的页地址是0x00/0x20/0x40/0x60/0x80/0xa0/0xc0/0xe0。
    for(i=0;i<256;i++)
       Wr24C02(0xa0,(U8)i,i);//U32 slvAddr,U32 addr,U8 data
    //初始化data数组的值为0。
    for(i=0;i<256;i++)
        data[i] = 0;
    Uart_Printf('Read test data from AT24C02\n');
    //读24C02的0xa0地址中数据到data数组中。
    for(i=0;i<256;i++)
        Rd24C02(0xa1,(U8)i,&(data[i]));
    //输出data数组接收数据的值
    for(i=0;i<16;i++)
        for(j=0;j<16;j++)
        Uart_Printf('%2x ',data[i*16+j]);
        Uart_Printf('\n');
    Uart_Printf('OK! Write data is same to Read data!\n');
    while(1);
    iicMode      = WRDATA;
    iicPt        = 0;
    iicData[0]   = (U8)addr;
    iicData[1]   = data;
    iicDataCount = 2;
    //8-bit data shift register for IIC-bus Tx/Rx operation.
    rIICDS        = slvAddr;            //0xa0
    //Master Tx mode, Start(Write), IIC-bus data output enable
        //Bus arbitration sucessful, Address as slave status flag Cleared,
        //Address zero status flag cleared, Last received bit is 0
    rIICSTAT      = 0xf0;
    //Clearing the pending bit isn't needed because the pending bit has been cleared.
    while(iicDataCount!=-1)
       Run_IicPoll();
iicMode = POLLACK;
    while(1)
   rIICDS     = slvAddr;
        iicStatus = 0x100;                 //To check if _iicStatus is changed
        rIICSTAT   = 0xf0;           //Master Tx, Start, Output Enable, Sucessful, Cleared, Cleared, 0
        rIICCON    = 0xe0;//0xaf;     //Resumes IIC operation. //hzh
        while(iicStatus==0x100)
            Run_IicPoll();
        if(!(iicStatus & 0x1))
            break;                      //When ACK is received
    rIICSTAT = 0xd0;                     //Master Tx condition, Stop(Write), Output Enable
    Delay(1);                           //Wait until stop condtion is in effect.
      //Write is completed.
    iicMode      = SETRDADDR;
    iicPt        = 0;
    iicDataCount = 1;
    rIICDS   = slvAddr;
    rIICSTAT = 0xf0;                    //MasTx,Start
        Run_IicPoll();
    iicMode      = RDDATA;
    iicPt        = 0;
    iicDataCount = 1;
    rIICDS   = slvAddr;
    rIICSTAT = 0xb0;                    //Master Rx,Start
        Run_IicPoll();
    *data = iicData[1];
    if(rIICCON & 0x10)                  //Tx/Rx Interrupt Enable
       IicPoll();
void IicPoll(void)
    U32 iicSt,i;
    iicSt = rIICSTAT;
    if(iicSt & 0x8){};                   //When bus arbitration is failed. 总线仲裁失败
    if(iicSt & 0x4){};                    //When a slave address is matched with IICADD
    if(iicSt & 0x2){};                   //When a slave address is 0000000b
    if(iicSt & 0x1){} ;                  //When ACK isn't received
    switch(iicMode)
    case POLLACK:
        iicStatus = iicSt;
        break;
    case RDDATA:
        if((iicDataCount--)==0)
            iicData[iicPt++] = rIICDS;
            rIICSTAT = 0x90;           //Stop MasRx condition
            rIICCON  = 0xc0;
            break;
                    //The last data has to be read with no ack.
 if((iicDataCount)==0)
            rIICCON = 0x60;//0x2f;
    else
        break;
      case SETRDADDR:
              break;
          rIICDS = iicData[iicPt++];
  for(i=0;i<10;i++);
            rIICCON = 0xc0;
            break;
            default:
            break;
void Delay(int x)
  int k,j;
  while(x)
   for(k=0;k<=0xff;k++)
    for(j=0;j<=0xff;j++);
    x--;
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • PIC单片机控制的遥控防盗报警器电路
  • 用数字电路CD4069制作的万能遥控轻触开关
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 用NE555制作定时器
  • RS-485基础知识:处理空闲总线条件的两种常见方法
    相关电子头条文章
