linux内核配置文件.config,基于s3c2410实现
2023-05-06 来源:elecfans
下面的文件的使用方法是:将下面的文件保存在linux内核源码目录中,文件的名称是.config,然后make menuconfig,在出现
的配置界面中选择Load Configuratio选项,然后可以在这个基础上修改自己的kernel。下面的配置是基于s3c2410,支持yaffs2
文件系统。我看了一下编译出来的uImage大概在800k左右,呵呵么这是本人第一次成功裁减内核。
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.22.6
# Tue Mar 16 20:42:20 2010
CONFIG_ARM=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_GENERIC_GPIO=y
# CONFIG_GENERIC_TIME is not set
# CONFIG_GENERIC_CLOCKEVENTS is not set
CONFIG_MMU=y
CONFIG_NO_IOPORT=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_RWSEM_GENERIC_SPINLOCK=y
# CONFIG_ARCH_HAS_ILOG2_U32 is not set
# CONFIG_ARCH_HAS_ILOG2_U64 is not set
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ZONE_DMA=y
CONFIG_VECTORS_BASE=0xffff0000
CONFIG_DEFCONFIG_LIST='/lib/modules/$UNAME_RELEASE/.config'
# Code maturity level options
# CONFIG_EXPERIMENTAL is not set
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
# General setup
CONFIG_LOCALVERSION=''
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
# CONFIG_IPC_NS is not set
CONFIG_SYSVIPC_SYSCTL=y
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_UTS_NS is not set
# CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=16
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
# CONFIG_BLK_DEV_INITRD is not set
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
# CONFIG_EMBEDDED is not set
CONFIG_UID16=y
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_ANON_INODES=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
CONFIG_RT_MUTEXES=y
# CONFIG_TINY_SHMEM is not set
CONFIG_BASE_SMALL=0
# Loadable module support
CONFIG_MODULES=y
# CONFIG_MODULE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_KMOD is not set
# Block layer
CONFIG_BLOCK=y
# CONFIG_LBD is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_LSF is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
# CONFIG_IOSCHED_AS is not set
# CONFIG_IOSCHED_DEADLINE is not set
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_AS is not set
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED='cfq'
# System Type
# CONFIG_ARCH_AAEC2000 is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_CLPS7500 is not set
# CONFIG_ARCH_CLPS711X is not set
# CONFIG_ARCH_CO285 is not set
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_H720X is not set
# CONFIG_ARCH_IMX is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP23XX is not set
# CONFIG_ARCH_IXP2000 is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_L7200 is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_NS9XXX is not set
# CONFIG_ARCH_PNX4008 is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
CONFIG_ARCH_S3C2410=y
# CONFIG_ARCH_SHARK is not set
# CONFIG_ARCH_LH7A40X is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_OMAP is not set
CONFIG_PLAT_S3C24XX=y
# CONFIG_S3C2410_BOOT_WATCHDOG is not set
# CONFIG_S3C2410_BOOT_ERROR_RESET is not set
# CONFIG_S3C2410_PM_DEBUG is not set
CONFIG_S3C2410_LOWLEVEL_UART_PORT=0
CONFIG_S3C2410_DMA=y
# CONFIG_S3C2410_DMA_DEBUG is not set
CONFIG_MACH_SMDK=y
# S3C2400 Machines
CONFIG_CPU_S3C2410=y
CONFIG_CPU_S3C2410_DMA=y
CONFIG_S3C2410_PM=y
CONFIG_S3C2410_GPIO=y
CONFIG_S3C2410_CLOCK=y
# S3C2410 Machines
CONFIG_ARCH_SMDK2410=y
# CONFIG_ARCH_H1940 is not set
# CONFIG_MACH_N30 is not set
# CONFIG_ARCH_BAST is not set
# CONFIG_MACH_OTOM is not set
# CONFIG_MACH_AML_M5900 is not set
# CONFIG_MACH_VR1000 is not set
# CONFIG_MACH_QT2410 is not set
# S3C2412 Machines
# CONFIG_MACH_SMDK2413 is not set
# CONFIG_MACH_SMDK2412 is not set
# CONFIG_MACH_VSTMS is not set
# S3C2440 Machines
# CONFIG_MACH_ANUBIS is not set
# CONFIG_MACH_OSIRIS is not set
# CONFIG_MACH_RX3715 is not set
# CONFIG_ARCH_S3C2440 is not set
# CONFIG_MACH_NEXCODER_2440 is not set
# S3C2442 Machines
# S3C2443 Machines
# CONFIG_MACH_SMDK2443 is not set
# Processor Type
CONFIG_CPU_32=y
CONFIG_CPU_ARM920T=y
CONFIG_CPU_32v4T=y
CONFIG_CPU_ABRT_EV4T=y
CONFIG_CPU_CACHE_V4WT=y
CONFIG_CPU_CACHE_VIVT=y
CONFIG_CPU_COPY_V4WB=y
CONFIG_CPU_TLB_V4WBI=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
# CONFIG_ARM_THUMB is not set
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_WRITETHROUGH is not set
# CONFIG_OUTER_CACHE is not set
# Bus support
# CONFIG_ARCH_SUPPORTS_MSI is not set
# PCCARD (PCMCIA/CardBus) support
# CONFIG_PCCARD is not set
# Kernel Features
# CONFIG_TICK_ONESHOT is not set
# CONFIG_NO_IDLE_HZ is not set
CONFIG_HZ=200
# CONFIG_AEABI is not set
# CONFIG_ARCH_DISCONTIGMEM_ENABLE is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
# CONFIG_SPARSEMEM_STATIC is not set
CONFIG_SPLIT_PTLOCK_CPUS=4096
# CONFIG_RESOURCES_64BIT is not set
CONFIG_ZONE_DMA_FLAG=1
CONFIG_ALIGNMENT_TRAP=y
# Boot options
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_CMDLINE='root=/dev/hda1 ro init=/bin/bash console=ttySAC0'
# CONFIG_XIP_KERNEL is not set
# Floating point emulation
# At least one emulation must be selected
CONFIG_FPE_NWFPE=y
# CONFIG_FPE_NWFPE_XP is not set
# Userspace binary formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_AOUT is not set
# CONFIG_BINFMT_MISC is not set
# CONFIG_ARTHUR is not set
# Power management options
CONFIG_PM=y
# CONFIG_PM_LEGACY is not set
# CONFIG_PM_DEBUG is not set
# CONFIG_PM_SYSFS_DEPRECATED is not set
# CONFIG_APM_EMULATION is not set
# Networking
# CONFIG_NET is not set
# Device Drivers
# Generic Driver Options
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# CONFIG_FW_LOADER is not set
# CONFIG_SYS_HYPERVISOR is not set
# Connector - unified userspace <-> kernelspace linker
CONFIG_MTD=y
# CONFIG_MTD_DEBUG is not set
# CONFIG_MTD_CONCAT is not set
CONFIG_MTD_PARTITIONS=y
# CONFIG_MTD_REDBOOT_PARTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
# CONFIG_MTD_AFS_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
CONFIG_MTD_JEDECPROBE=y
CONFIG_MTD_GEN_PROBE=y
# CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
# CONFIG_MTD_CFI_STAA is not set
CONFIG_MTD_CFI_UTIL=y
# CONFIG_MTD_RAM is not set
CONFIG_MTD_ROM=y
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PHYSMAP is not set
# CONFIG_MTD_ARM_INTEGRATOR is not set
# CONFIG_MTD_IMPA7 is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
CONFIG_MTD_NAND=y
# CONFIG_MTD_NAND_VERIFY_WRITE is not set
# CONFIG_MTD_NAND_ECC_SMC is not set
# CONFIG_MTD_NAND_MUSEUM_IDS is not set
CONFIG_MTD_NAND_IDS=y
CONFIG_MTD_NAND_S3C2410=y
# CONFIG_MTD_NAND_S3C2410_DEBUG is not set
# CONFIG_MTD_NAND_S3C2410_HWECC is not set
# CONFIG_MTD_NAND_S3C2410_CLKSTOP is not set
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_ONENAND is not set
# UBI - Unsorted block images
# CONFIG_MTD_UBI is not set
# Parallel port support
# CONFIG_PARPORT is not set
# Plug and Play support
# CONFIG_PNPACPI is not set
# Block devices
# CONFIG_BLK_DEV_COW_COMMON is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
CONFIG_IDE=y
# CONFIG_BLK_DEV_IDE is not set
# CONFIG_BLK_DEV_HD_ONLY is not set
# CONFIG_BLK_DEV_HD is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
# CONFIG_SCSI is not set
# CONFIG_SCSI_NETLINK is not set
# CONFIG_ATA is not set
# Multi-device support (RAID and LVM)
# CONFIG_MD is not set
# ISDN subsystem
# Input device support
CONFIG_INPUT=y
# CONFIG_INPUT_FF_MEMLESS is not set
# CONFIG_INPUT_POLLDEV is not set
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
# CONFIG_INPUT_MOUSEDEV_PSAUX is not set
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
# CONFIG_INPUT_TSDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
# CONFIG_INPUT_KEYBOARD is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
# CONFIG_SERIO_RAW is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_SERIAL_NONSTANDARD=y
# CONFIG_ROCKETPORT is not set
# CONFIG_DIGIEPCA is not set
# CONFIG_MOXA_INTELLIO is not set
# CONFIG_MOXA_SMARTIO is not set
# CONFIG_SYNCLINKMP is not set
# CONFIG_N_HDLC is not set
# CONFIG_RISCOM8 is not set
# CONFIG_SPECIALIX is not set
# CONFIG_RIO is not set
# CONFIG_STALDRV is not set
# Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_NR_UARTS=8
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_MANY_PORTS=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
# CONFIG_SERIAL_8250_DETECT_IRQ is not set
# CONFIG_SERIAL_8250_RSA is not set
CONFIG_SERIAL_EXTEND_S3C24xx=y
# Non-8250 serial port support
CONFIG_SERIAL_S3C2410=y
CONFIG_SERIAL_S3C2410_CONSOLE=y
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_UNIX98_PTYS=y
# CONFIG_LEGACY_PTYS is not set
# IPMI
# CONFIG_IPMI_HANDLER is not set
CONFIG_WATCHDOG=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
CONFIG_S3C2410_WATCHDOG=y
# CONFIG_HW_RANDOM is not set
# CONFIG_NVRAM is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# TPM devices
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_CHARDEV=m
# I2C Algorithms
CONFIG_I2C_ALGOBIT=m
# CONFIG_I2C_ALGOPCF is not set
# CONFIG_I2C_ALGOPCA is not set
# I2C Hardware Bus support
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
CONFIG_I2C_S3C2410=y
# CONFIG_I2C_SIMTEC is not set
# Miscellaneous I2C Chip support
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# CONFIG_I2C_DEBUG_CHIP is not set
# SPI support
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
# SPI Protocol Masters
# CONFIG_SPI_AT25 is not set
# Dallas's 1-wire bus
# CONFIG_W1 is not set
# CONFIG_HWMON is not set
# Misc devices
# Multifunction device drivers
# CONFIG_MFD_SM501 is not set
# LED devices
# CONFIG_NEW_LEDS is not set
# LED drivers
# LED Triggers
# Multimedia devices
# CONFIG_VIDEO_DEV is not set
# CONFIG_DAB is not set
# Graphics support
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# CONFIG_VGASTATE is not set
# CONFIG_FB is not set
# Console display driver support
# CONFIG_VGA_CONSOLE is not set
CONFIG_DUMMY_CONSOLE=y
# Sound
# CONFIG_SOUND is not set
# HID Devices
# CONFIG_HID is not set
# USB support
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
# CONFIG_USB_ARCH_HAS_EHCI is not set
# CONFIG_USB is not set
# NOTE: USB_STORAGE enables SCSI, and 'SCSI disk support'
# USB Gadget Support
# CONFIG_USB_GADGET is not set
# CONFIG_MMC is not set
# Real Time Clock
CONFIG_RTC_LIB=y
# File systems
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_FS_POSIX_ACL is not set
# CONFIG_XFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_INOTIFY is not set
# CONFIG_QUOTA is not set
CONFIG_DNOTIFY=y
# CONFIG_AUTOFS_FS is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_FUSE_FS is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
# CONFIG_MSDOS_FS is not set
# CONFIG_VFAT_FS is not set
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_SYSFS=y
# CONFIG_TMPFS is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
# Miscellaneous filesystems
# CONFIG_HFSPLUS_FS is not set
CONFIG_YAFFS_FS=y
CONFIG_YAFFS_YAFFS1=y
# CONFIG_YAFFS_9BYTE_TAGS is not set
# CONFIG_YAFFS_DOES_ECC is not set
CONFIG_YAFFS_YAFFS2=y
CONFIG_YAFFS_AUTO_YAFFS2=y
# CONFIG_YAFFS_DISABLE_LAZY_LOAD is not set
# CONFIG_YAFFS_DISABLE_WIDE_TNODES is not set
# CONFIG_YAFFS_ALWAYS_CHECK_CHUNK_ERASED is not set
# CONFIG_YAFFS_SHORT_NAMES_IN_RAM is not set
# CONFIG_JFFS2_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
# CONFIG_MSDOS_PARTITION is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
# CONFIG_EFI_PARTITION is not set
# CONFIG_SYSV68_PARTITION is not set
# Native Language Support
CONFIG_NLS=y
CONFIG_NLS_DEFAULT='cp936'
# CONFIG_NLS_CODEPAGE_437 is not set
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
CONFIG_NLS_CODEPAGE_936=y
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
# CONFIG_NLS_ISO8859_1 is not set
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_UTF8 is not set
# Kernel hacking
# CONFIG_PRINTK_TIME is not set
# CONFIG_ENABLE_MUST_CHECK is not set
# CONFIG_MAGIC_SYSRQ is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_DEBUG_FS is not set
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_KERNEL is not set
CONFIG_DEBUG_BUGVERBOSE=y
CONFIG_FRAME_POINTER=y
# CONFIG_WANT_EXTRA_DEBUG_INFORMATION is not set
# CONFIG_UNWIND_INFO is not set
# CONFIG_DEBUG_USER is not set
CONFIG_DEBUG_S3C2410_UART=0
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
# Cryptographic options
# CONFIG_CRYPTO is not set
# Library routines
# CONFIG_CRC_CCITT is not set
# CONFIG_CRC16 is not set
# CONFIG_CRC_ITU_T is not set
# CONFIG_CRC32 is not set
# CONFIG_LIBCRC32C is not set
CONFIG_PLIST=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_DMA=y
- 学习ARM开发(2)
- Linux帧缓冲设备驱动程序框架及图形界面GUI的移植
- Linux Kernel之flush_cache_all在ARM平台下是如何实现的
- 手把手教你写Linux设备驱动---中断(三)--workqueue实现(基于友善之臂4412开发板)
- makefile初步制作,arm-linux- (gcc/ld/objcopy/objdump)详解
- Ubuntu下安装arm-linux-gnueabi-xxx编译器
- 用Qemu运行/调试arm linux
- Linux内核异常处理体系结构详解(一)
- arm linux 移植 mtd-utils 1.x
- 基于gnu-arm-linux的LPC2220的简单工程模板
