单片机
Linux设备驱动开发 - 混杂设备驱动
2024-09-20
混杂设备共享一个主设备号MISC_MAJOR(10),次设备号不同。
混杂设备本质上仍然是一个字符设备,所以混杂设备的操作跟字符设备基本相同。
在字符设备中,描述字符设备的结构体为struct cdev,在混杂设备中同样有一个描述混杂设备的结构体struct miscdevice。
 1 struct miscdevice  {
 2     int minor;                             /* 次设备号 */
 3     const char *name;                      /* 设备名 */
 4     const struct file_operations *fops;    /* 文件操作 */
 5     struct list_head list;
 6     struct device *parent;
 7     struct device *this_device;
 8     const char *nodename;
 9     mode_t mode;
10 };
因为混杂设备共享一个主设备号10,所以在struct miscdevice结构体里面只要指定次设备号,如果次设备号为MISC_DYNAMIC_MINOR系统会自动分配一个次设备号,同时在/dev目录下根据struct miscdevice结构体的name成员创建一个设备节点/dev/'name'。
和字符设备一样要指定一个设备文件操作fops。
 1 struct file_operations {
 2     struct module *owner;
 3     loff_t (*llseek) (struct file *, loff_t, int);
 4     ssize_t (*read) (struct file *, char __user *, size_t, loff_t *);
 5     ssize_t (*write) (struct file *, const char __user *, size_t, loff_t *);
 6     ssize_t (*aio_read) (struct kiocb *, const struct iovec *, unsigned long, loff_t);
 7     ssize_t (*aio_write) (struct kiocb *, const struct iovec *, unsigned long, loff_t);
 8     int (*readdir) (struct file *, void *, filldir_t);
 9     unsigned int (*poll) (struct file *, struct poll_table_struct *);
10     long (*unlocked_ioctl) (struct file *, unsigned int, unsigned long);
11     long (*compat_ioctl) (struct file *, unsigned int, unsigned long);
12     int (*mmap) (struct file *, struct vm_area_struct *);
13     int (*open) (struct inode *, struct file *);
14     int (*flush) (struct file *, fl_owner_t id);
15     int (*release) (struct inode *, struct file *);
16     int (*fsync) (struct file *, int datasync);
17     int (*aio_fsync) (struct kiocb *, int datasync);
18     int (*fasync) (int, struct file *, int);
19     int (*lock) (struct file *, int, struct file_lock *);
20     ssize_t (*sendpage) (struct file *, struct page *, int, size_t, loff_t *, int);
21     unsigned long (*get_unmapped_area)(struct file *, unsigned long, unsigned long, unsigned long, unsigned long);
22     int (*check_flags)(int);
23     int (*flock) (struct file *, int, struct file_lock *);
24     ssize_t (*splice_write)(struct pipe_inode_info *, struct file *, loff_t *, size_t, unsigned int);
25     ssize_t (*splice_read)(struct file *, loff_t *, struct pipe_inode_info *, size_t, unsigned int);
26     int (*setlease)(struct file *, long, struct file_lock **);
27     long (*fallocate)(struct file *file, int mode, loff_t offset,loff_t len);
28 };
在模块加载时需要注册混杂设备驱动,相对于字符设备驱动而言混杂设备驱动显得更为简单,只要一个misc_register()函数并指定要操作的miscdevice结构体即可。
1 int misc_register(struct miscdevice * misc);
成功返回0,失败返回一个负的错误号。
在模块卸载时需要卸载混杂设备驱动,使用函数misc_deregister()。
1 int misc_deregister(struct miscdevice *misc);
混杂设备驱动模板:
 1 static struct file_operations xxx_fops =
 2 {
 3     .owner = THIS_MODULE,
 4     .open = xxx_open,
 5     .read = xxx_read,
 6     ...
 7 };
 9 static struct miscdevice xxx_misc =
10 {
11     .minor = MISC_DYNAMIC_MINOR,
12     .name = NAME,
13     .fops = &xxx_fops,
14 };
16 static int __init xxx_init(void)
17 {
18     ...
19     /* 注册混杂设备驱动 */
20     misc_register(&xxx_misc);
21     ...
22 }
23
24 static void __exit xxx_exit(void)
25 {
26     ...
27     /* 卸载混杂设备驱动 */
28     misc_deregister(&xxx_misc);
29     ...
30 }
31
32 module_init(xxx_init);
33 module_exit(xxx_exit);
34 MODULE_LICENSE('GPL');
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 红外线探测报警器
  • 用NE555制作定时器
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何构建一个触摸传感器电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
