STM32CubeMX学习--(6)USB大容量存储设备
2020-05-14 来源:eefocus
CUBE配置
USB_OTG_FS配置
记得勾选NVIC中断使能。
USB_DEVICE配置
clock配置
修改代码
主要修改usbd_storage_if.c文件
/* USER CODE BEGIN Header */
* @file : usbd_storage_if.c
* @version : v1.0_Cube
* @brief : Memory management layer.
* @attention
© Copyright (c) 2020 STMicroelectronics. * All rights reserved.
* This software component is licensed by ST under Ultimate Liberty license
* SLA0044, the 'License'; You may not use this file except in compliance with
* the License. You may obtain a copy of the License at:
* www.st.com/SLA0044
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include 'usbd_storage_if.h'
/* USER CODE BEGIN INCLUDE */
#include 'W25QXX.h'
/* USER CODE END INCLUDE */
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* Private variables ---------------------------------------------------------*/
/* USER CODE END PV */
/** @addtogroup STM32_USB_OTG_DEVICE_LIBRARY
* @brief Usb device.
/** @defgroup USBD_STORAGE
* @brief Usb mass storage device module
/** @defgroup USBD_STORAGE_Private_TypesDefinitions
* @brief Private types.
/* USER CODE BEGIN PRIVATE_TYPES */
/* USER CODE END PRIVATE_TYPES */
/** @defgroup USBD_STORAGE_Private_Defines
* @brief Private defines.
#define STORAGE_LUN_NBR 1
#define STORAGE_BLK_NBR W25Q128FV_SUBSECTOR_SIZE-224
#define STORAGE_BLK_SIZ W25Q128FV_SUBSECTOR_SIZE
/* USER CODE BEGIN PRIVATE_DEFINES */
//#define STORAGE_BLK_NBR (W25Q128FV_SUBSECTOR_SIZE)
//#define STORAGE_BLK_SIZ W25Q128FV_SUBSECTOR_SIZE
/* USER CODE END PRIVATE_DEFINES */
/** @defgroup USBD_STORAGE_Private_Macros
* @brief Private macros.
/* USER CODE BEGIN PRIVATE_MACRO */
/* USER CODE END PRIVATE_MACRO */
/** @defgroup USBD_STORAGE_Private_Variables
* @brief Private variables.
/* USER CODE BEGIN INQUIRY_DATA_FS */
/** USB Mass storage Standard Inquiry Data. */
const int8_t STORAGE_Inquirydata_FS[] = {/* 36 */
/* LUN 0 */
0x00,
0x80,
0x02,
0x02,
(STANDARD_INQUIRY_DATA_LEN - 5),
0x00,
0x00,
0x00,
'S', 'T', 'M', ' ', ' ', ' ', ' ', ' ', /* Manufacturer : 8 bytes */
'P', 'r', 'o', 'd', 'u', 'c', 't', ' ', /* Product : 16 Bytes */
'0', '.', '0' ,'1' /* Version : 4 Bytes */
/* USER CODE END INQUIRY_DATA_FS */
/* USER CODE BEGIN PRIVATE_VARIABLES */
/* USER CODE END PRIVATE_VARIABLES */
/** @defgroup USBD_STORAGE_Exported_Variables
* @brief Public variables.
extern USBD_HandleTypeDef hUsbDeviceFS;
/* USER CODE BEGIN EXPORTED_VARIABLES */
/* USER CODE END EXPORTED_VARIABLES */
/** @defgroup USBD_STORAGE_Private_FunctionPrototypes
* @brief Private functions declaration.
static int8_t STORAGE_Init_FS(uint8_t lun);
static int8_t STORAGE_GetCapacity_FS(uint8_t lun, uint32_t *block_num, uint16_t *block_size);
static int8_t STORAGE_IsReady_FS(uint8_t lun);
static int8_t STORAGE_IsWriteProtected_FS(uint8_t lun);
static int8_t STORAGE_Read_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len);
static int8_t STORAGE_Write_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len);
static int8_t STORAGE_GetMaxLun_FS(void);
/* USER CODE BEGIN PRIVATE_FUNCTIONS_DECLARATION */
/* USER CODE END PRIVATE_FUNCTIONS_DECLARATION */
USBD_StorageTypeDef USBD_Storage_Interface_fops_FS =
STORAGE_Init_FS,
STORAGE_GetCapacity_FS,
STORAGE_IsReady_FS,
STORAGE_IsWriteProtected_FS,
STORAGE_Read_FS,
STORAGE_Write_FS,
STORAGE_GetMaxLun_FS,
(int8_t *)STORAGE_Inquirydata_FS
/* Private functions ---------------------------------------------------------*/
* @brief Initializes over USB FS IP
* @param lun:
* @retval USBD_OK if all operations are OK else USBD_FAIL
/* USER CODE BEGIN 2 */
BSP_W25Qx_Init();
return (USBD_OK);
/* USER CODE END 2 */
* @brief .
* @param lun: .
* @param block_num: .
* @param block_size: .
/* USER CODE BEGIN 3 */
*block_num = STORAGE_BLK_NBR;
*block_size = STORAGE_BLK_SIZ;
return (USBD_OK);
/* USER CODE END 3 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 4 */
return (USBD_OK);
/* USER CODE END 4 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 5 */
return (USBD_OK);
/* USER CODE END 5 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 6 */
if(!blk_len)
return USBD_OK;
for(;blk_len>0;blk_len--)
BSP_W25Qx_Read(buf,blk_addr*STORAGE_BLK_SIZ,STORAGE_BLK_SIZ);
blk_addr++;
buf+=STORAGE_BLK_SIZ;
return (USBD_OK);
/* USER CODE END 6 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 7 */
if(!blk_len)
return USBD_OK;
BSP_W25Qx_Erase_Block(blk_addr*STORAGE_BLK_SIZ);
BSP_W25Qx_Write(buf,blk_addr*STORAGE_BLK_SIZ,STORAGE_BLK_SIZ);
blk_addr++;
return (USBD_OK);
/* USER CODE END 7 */
* @brief .
* @param None
* @retval .
/* USER CODE BEGIN 8 */
return (STORAGE_LUN_NBR - 1);
/* USER CODE END 8 */
/* USER CODE BEGIN PRIVATE_FUNCTIONS_IMPLEMENTATION */
/* USER CODE END PRIVATE_FUNCTIONS_IMPLEMENTATION */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
编译下载即可读到U盘。
- STM32CUBEMX开发GD32F303(4)----GPIO输出模式,速率测试、开漏和输出说明
- STM32CubeMx普通PWM基本使用方法
- 基于STM32Cubemx HAL 库实现 DMA 驱动 GPIO 高速翻转
- STM32CubeMx配置USART1增加打印功能
- STM32CUBEMX开发GD32F303(17)----内部Flash读写
- STM32CUBEMX开发GD32F303(8)----USART收发配置
- STM32CubeMX介绍,功耗计算,中间件,CAD视图
- 如何通过STM32CubeMX制作外部Flash的烧写驱动 (.stdlr)
- STM32CUBEMX开发GD32F303(15)----外部中断EXTI
- 利用STM32CubeMX解读时钟树
