TCRT5000+STM32红外循迹小车程序
2020-08-11 来源:51hei
用正点原子的精英版作为主控,红外循迹用TCRT5000芯片。
单片机源程序如下:
/* Includes ------------------------------------------------------------------*/
#include 'stm32f10x.h'
#include 'stm32f10x_tim.h'
#include 'stm32f10x_flash.h'
#include 'stm32f10x_exti.h'
#include 'stm32f10x_rcc.h'
#include 'systick.h'
#include 'stdio.h'
#include 'misc.h'
#define infra1 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7);
#define infra2 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_8);
#define tube1 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_0);
#define tube2 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_1);
#define tube3 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2);
#define tube4 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_3);
TIM_OCInitTypeDef TIM1_OCInitStructure;
extern FlagStatus Status;
extern u16 TIM1Compare1[3] = {0,0x3FFF,0x1FFF};
extern u16 TIM1Compare2[3] = {0x7FFF,0x3FFF,0x1FFF};
extern u16 TIM1Compare3[3] = {0,0x3FFF,0x1FFF};
extern u16 TIM1Compare4[3] = {0x7FFF,0x3FFF,0x1FFF};
extern u16 tubecnt;
extern u16 flag;
extern int add;
void GPIO_Configuration(void);
void TIM_Configuration(void);
void tim2_Configuration(void);
void exti_Configuration(void);
void nvic_Configuration(void);
void zhi1(void);
void zhi2(void);
void zhi3(void);
void zuoxiao(void);
void zuoda(void);
void youxiao(void);
void youda(void);
void xunji(void);
u16 ceju(void);
int main(void)
RCC_Configuration();
GPIO_Configuration();
TIM_Configuration();
delay_init();
while(1)
GPIO_ResetBits(GPIOE,GPIO_Pin_15);
GPIO_ResetBits(GPIOB,GPIO_Pin_11);
GPIO_InitTypeDef GPIO_InitStructure;
/*TIM1 PWM 输出:A9:CH1/A10:CH2 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/*LED显示:LED5:PE15 / LED6:PB11 / LED7:PE14 / LED8:PB10 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_SetBits(GPIOB,GPIO_Pin_10);
GPIO_SetBits(GPIOB,GPIO_Pin_11);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14|GPIO_Pin_15;
GPIO_Init(GPIOE, &GPIO_InitStructure);
GPIO_SetBits(GPIOE,GPIO_Pin_14);
GPIO_SetBits(GPIOE,GPIO_Pin_15);
/*红外管:infra1-> PC7, infra2-> PC8 浮空输入 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/*光电管:tube1-> PC0, tube2-> PC1, tube3-> PC2, tube4-> PC3 浮空输入*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1|GPIO_Pin_2 | GPIO_Pin_3;
/*超声波:Trig:PB9 Echo:PB8 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_ResetBits( GPIOB, GPIO_Pin_9);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //PB1接受采集上升沿 PB6低电平
GPIO_ResetBits(GPIOB,GPIO_Pin_8);
TIM_TimeBaseInitTypeDef TIM1_TimeBaseStructure;
TIM_DeInit(TIM1);
/* Time Base configuration */
TIM1_TimeBaseStructure.TIM_Prescaler = 0x0; //设置了用来作为TIMx时钟频率除数的预分频值
TIM1_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //选择了计数器模式
TIM1_TimeBaseStructure.TIM_Period = 0xFFFF; //设置了在下一个更新事件装入活动的自动重装载寄存器周期 ARR
TIM1_TimeBaseStructure.TIM_ClockDivision = 0x0; //设置了时钟分割
TIM1_TimeBaseStructure.TIM_RepetitionCounter = 0x0; //设置了周期计数器值
TIM_TimeBaseInit(TIM1,&TIM1_TimeBaseStructure);//根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位(5个参数)
//TIM1基本计数器设置(设置PWM频率) //频率=TIM1_CLK/(ARR+1)
/* Channel 1, 2,3 and 4 Configuration in PWM mode */
TIM1_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM1_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM1_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM1_OCInitStructure.TIM_Pulse = 0x0;
TIM1_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
TIM1_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM1_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC1Init(TIM1,&TIM1_OCInitStructure); //同TimeBaseStructure (8个参数) //TIM1_OC1模块设置(设置1通道占空比)
TIM1_OCInitStructure.TIM_Pulse = 0x7fff;
TIM_OC2Init(TIM1,&TIM1_OCInitStructure); //同TimeBaseStructure
TIM_OC3Init(TIM1,&TIM1_OCInitStructure); //同TimeBaseStructure
TIM_OC4Init(TIM1,&TIM1_OCInitStructure); //同TimeBaseStructure
TIM_Cmd(TIM1,ENABLE); //先设置好了TimeBase、OC、BDTR 使能或者失能TIM1外设
/* Main Output Enable */
TIM_CtrlPWMOutputs(TIM1,DISABLE); //TIM1_CtrlPWMOutputs(ENABLE); 使能或者失能TIM1的主输出
void zhi1(void) //直走速度1
TIM_SetCompare1(TIM1,TIM1Compare1[0]);
TIM_SetCompare2(TIM1,TIM1Compare2[0]);
TIM_SetCompare3(TIM1,TIM1Compare3[0]);
TIM_SetCompare4(TIM1,TIM1Compare4[0]);
TIM_CtrlPWMOutputs(TIM1,ENABLE);
void zhi2(void) //直走速度2(慢)
TIM_SetCompare2(TIM1,TIM1Compare2[1]);
TIM_SetCompare4(TIM1,TIM1Compare4[1]);
void zhi(void) //直走速度3(很慢)
TIM_SetCompare2(TIM1,TIM1Compare2[2]);
TIM_SetCompare4(TIM1,TIM1Compare4[2]);
void zuoxiao(void) //左小转
void zuoda(void) //左大转
TIM_SetCompare2(TIM1,0);
void youxiao(void) //右小转
void youda(void) //右大转
void xunji(void) //循迹
zhi1();
if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7)) youxiao();
if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_8)) zuoxiao();
if(1)
tubecnt++;
zhi1();
delay_ms(100);
zuoda();
delay_ms(100);
u16 ceju(void)
u16 juli;
flag=0;
GPIO_SetBits( GPIOB, GPIO_Pin_9);
TIM_Cmd(TIM2,ENABLE);
while(juli==0);
juli=add*3.4;;
flag=0;
return juli;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3, ENABLE);
TIM_DeInit(TIM2);
TIM_TimeBaseStructure.TIM_Period=72-1;
TIM_TimeBaseStructure.TIM_Prescaler=15-1;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, & TIM_TimeBaseStructure);
TIM_ClearFlag(TIM2,TIM_FLAG_Update);
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
TIM_Cmd(TIM2,DISABLE);
TIM_DeInit(TIM3);
TIM_TimeBaseStructure.TIM_Prescaler =72-1; //设置了用来作为TIMx时钟频率除数的预分频值
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //选择了计数器模式
TIM_TimeBaseStructure.TIM_Period = 20-1; //设置了15us在下一个更新事件装入活动的自动重装载寄存器周期 ARR
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ; //设置了时钟分割
TIM_TimeBaseInit(TIM3, & TIM_TimeBaseStructure);
TIM_ClearFlag(TIM3,TIM_FLAG_Update);
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
TIM_Cmd(TIM3,DISABLE);
EXTI_InitTypeDef EXTI_InitStructure;
EXTI_DeInit();
GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource8);
EXTI_InitStructure.EXTI_Line = EXTI_Line8;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger =EXTI_Trigger_Rising_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel =TIM2_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel =TIM3_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
NVIC_InitStructure.NVIC_IRQChannel =EXTI9_5_IRQChannel ;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
#endif
