ucgui界面设计&实体按键驱动
2020-10-15 来源:eefocus
环境:
主机:WIN8
开发环境:MDK4.72
ucgui版本:3.90
mcu: stm32f103VE
说明:
本程序基于ucgui对话框机制设计了一个界面,并用6个实体按键对界面进行控制
效果图:
源码:
gui_main.h
* 主界面模块头文件
* (c)copyright 2014,jdh
* All Right Reserved
*新建时间:2014/10/23 by jdh
#ifndef _GUI_MAIN_H_
#define _GUI_MAIN_H_
* 头文件
#include 'world.h'
* 宏定义
* 工作间隔
*单位:ms
#define INTERVAL_GUI_MAIN 100
* 函数
* 模块载入
void gui_main_load(void);
* 模块运行
void gui_main_run(void);
* 设置显示状态
*参数:enable:0:关闭显示,1:打开显示
void gui_main_show(uint8_t enable);
* 得到当前的显示状态
*返回:0:关闭显示,1:打开显示
uint8_t gui_main_get_show(void);
#endif
gui_main.c
* 主界面模块主文件
* 头文件
#include 'gui_main.h'
* 宏定义
#define ID_FRAMEWIN (GUI_ID_USER + 0x10)
#define ID_BUTTON_OK (GUI_ID_USER + 0x11)
#define ID_BUTTON_CANCEL (GUI_ID_USER + 0x12)
#define ID_BUTTON_UP (GUI_ID_USER + 0x13)
#define ID_BUTTON_DOWN (GUI_ID_USER + 0x14)
#define ID_BUTTON_LEFT (GUI_ID_USER + 0x15)
#define ID_BUTTON_RIGHT (GUI_ID_USER + 0x16)
#define ID_TEXT_MATCH (GUI_ID_USER + 0x17)
#define ID_TEXT_RSSI (GUI_ID_USER + 0x18)
#define ID_LISTBOX_FUNC (GUI_ID_USER + 0x19)
* 数据结构
* 按键状态
struct _Key_State
uint8_t ok;
uint8_t cancel;
uint8_t up;
uint8_t down;
uint8_t left;
uint8_t right;
* 静态变量
* 界面句柄
static WM_HWIN Handle_Gui;
* 资源表
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
{ FRAMEWIN_CreateIndirect, 'Frame3', ID_FRAMEWIN, 0, 0, 240, 320, 0, 0x0},
{ BUTTON_CreateIndirect, 'OK', ID_BUTTON_OK, 5, 255, 40, 20, 0, 0x0},
{ BUTTON_CreateIndirect, 'Button', ID_BUTTON_DOWN, 95, 280, 40, 20, 0, 0x0},
{ BUTTON_CreateIndirect, 'UP', ID_BUTTON_UP, 95, 255, 40, 20, 0, 0x0},
{ BUTTON_CreateIndirect, 'CANCEL', ID_BUTTON_CANCEL, 185, 255, 40, 20, 0, 0x0},
{ BUTTON_CreateIndirect, 'RIGHT', ID_BUTTON_RIGHT, 140, 270, 40, 20, 0, 0x0},
{ BUTTON_CreateIndirect, 'LEFT', ID_BUTTON_LEFT, 50, 270, 40, 20, 0, 0x0},
{ TEXT_CreateIndirect, 'Match', ID_TEXT_MATCH, 140, 15, 80, 20, 0, 0x0},
{ TEXT_CreateIndirect, 'RSSI', ID_TEXT_RSSI, 140, 40, 80, 20, 0, 0x0},
{ LISTBOX_CreateIndirect, 'Listbox', ID_LISTBOX_FUNC, 5, 10, 120, 220, 0, 0x0},
// USER START (Optionally insert additional widgets)
// USER END
* 上次工作时间
static struct _Time Time_Last =
.s = 0,
.ms = 0,
.us = 0
* 按键状态
static struct _Key_State Key_State =
.ok = 0,
.cancel = 0,
.up = 0,
.down = 0,
.left = 0,
.right = 0
* 当前显示状态
*0:未显示,1显示
static uint8_t State_Show = 1;
* 静态函数
* 回调函数
static void _cbDialog(WM_MESSAGE * pMsg);
* 定时工作
static void slot_tick(void);
* 按键处理
static void deal_key(void);
* 函数
* 模块载入
//新建界面
Handle_Gui = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate),
_cbDialog, WM_HBKWIN, 0, 0);
* 模块运行
struct _Time time;
//判断当前是否显示
if (State_Show == 0)
return;
//得到当前时间
get_time(&time);
//判断是否到工作时间
if (sub_time(time,Time_Last) >= INTERVAL_GUI_MAIN * 1000)
//更新时间
Time_Last = time;
//定时工作
slot_tick();
* 设置显示状态
State_Show = enable;
if (enable)
WM_ShowWindow(Handle_Gui);
else
WM_HideWindow(Handle_Gui);
* 得到当前的显示状态
*返回:0:关闭显示,1:打开显示
return State_Show;
* 定时工作
//按键处理
deal_key();
* 按键处理
WM_HWIN hItem;
//按键扫描
//inf_key_scan();
//判断关机键是否按下
if (inf_key_detect_hold(KEY_CANCEL))
if (Key_State.cancel == 0)
Key_State.cancel = 1;
//按下状态
hItem = WM_GetDialogItem(Handle_Gui, ID_BUTTON_CANCEL);
BUTTON_SetState(hItem,BUTTON_STATE_HASFOCUS | BUTTON_STATE_PRESSED);
//关机
inf_power_set(OFF);
else
if (Key_State.cancel == 1)
Key_State.cancel = 0;
//初始化按键
BUTTON_SetState(hItem,BUTTON_STATE_HASFOCUS);
//开机
inf_power_set(ON);
//判断下键是否按下
if (inf_key_detect_hold(KEY_DOWN))
if (Key_State.down == 0)
Key_State.down = 1;
//初始化按键
hItem = WM_GetDialogItem(Handle_Gui, ID_BUTTON_DOWN);
//发送按键信号
WM_NotifyParent(hItem,WM_NOTIFICATION_CLICKED);
else
if (Key_State.down == 1)
Key_State.down = 0;
//初始化按键
//判断上键是否按下
if (inf_key_detect_hold(KEY_UP))
if (Key_State.up == 0)
Key_State.up = 1;
//初始化按键
hItem = WM_GetDialogItem(Handle_Gui, ID_BUTTON_UP);
//发送按键信号
else
if (Key_State.up == 1)
Key_State.up = 0;
//初始化按键
//判断测试键是否按下
if (inf_key_detect_hold(KEY_OK))
if (Key_State.ok == 0)
Key_State.ok = 1;
//初始化按键
hItem = WM_GetDialogItem(Handle_Gui, ID_BUTTON_OK);
//发送按键信号
else
if (Key_State.ok == 1)
Key_State.ok = 0;
//初始化按键
* 回调函数
WM_HWIN hItem;
int NCode;
int Id;
// USER START (Optionally insert additional variables)
// USER END
char str[20] = {0};
switch (pMsg->MsgId)
case WM_INIT_DIALOG:
//初始化窗体
//增加小按键
FRAMEWIN_AddCloseButton(pMsg->hWin, FRAMEWIN_BUTTON_RIGHT, 0);
FRAMEWIN_AddMaxButton(pMsg->hWin, FRAMEWIN_BUTTON_RIGHT, 1);
FRAMEWIN_AddMinButton(pMsg->hWin, FRAMEWIN_BUTTON_RIGHT, 2);
FRAMEWIN_SetFont(pMsg->hWin, &GUI_FontHZ12);
sprintf(str,'脚镣测试系统Ver%d by jdh',VERSION_SOFT);
FRAMEWIN_SetText(pMsg->hWin,str);
//初始化列表框
hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTBOX_FUNC);
//设置为焦点
WM_SetFocus(hItem);
//设置内容
LISTBOX_SetFont(hItem, &GUI_FontHZ12);
LISTBOX_AddString(hItem, '对码绑定');
LISTBOX_AddString(hItem, '频点选择');
LISTBOX_AddString(hItem, '通话测试');
LISTBOX_AddString(hItem, 'GPRS测试');
LISTBOX_AddString(hItem, 'GPS测试');
LISTBOX_AddString(hItem, '125K测试');
SCROLLBAR_CreateAttached(hItem, SCROLLBAR_CF_VERTICAL);
//初始化按键
hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_OK);
BUTTON_SetFont(hItem, &GUI_FontHZ12);
BUTTON_SetText(hItem,'测试');
hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_CANCEL);
BUTTON_SetText(hItem,'关机');
hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_UP);
BUTTON_SetText(hItem,'上');
hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_DOWN);
BUTTON_SetText(hItem,'下');
hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_LEFT);
BUTTON_SetText(hItem,'');
hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_RIGHT);
//初始化文本
hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_MATCH);
TEXT_SetFont(hItem, &GUI_FontHZ12);
TEXT_SetText(hItem,'未绑定脚镣');
hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_RSSI);
TEXT_SetText(hItem,'');
break;
case WM_NOTIFY_PARENT:
Id = WM_GetId(pMsg->hWinSrc);
NCode = pMsg->Data.v;
switch(Id)
case ID_BUTTON_OK:
switch(NCode)
case WM_NOTIFICATION_CLICKED:
//获得当前列表数目
int a = LISTBOX_GetSel(hItem);
sprintf(str,'%d',a);
TEXT_SetText(hItem,str);
LISTBOX_GetItemText(hItem,a,str,20);
break;
case WM_NOTIFICATION_RELEASED:
break;
break;
case ID_BUTTON_DOWN:
switch(NCode)
//发送按键信号
GUI_SendKeyMsg(GUI_KEY_DOWN, 1);
break;
break;
break;
case ID_BUTTON_UP:
switch(NCode)
//发送按键信号
GUI_SendKeyMsg(GUI_KEY_UP, 1);
break;
break;
break;
case ID_BUTTON_CANCEL:
switch(NCode)
break;
break;
break;
case ID_BUTTON_RIGHT:
switch(NCode)
break;
break;
break;
case ID_BUTTON_LEFT:
switch(NCode)
break;
break;
break;
case ID_LISTBOX_FUNC:
switch(NCode)
break;
break;
break;
break;
default:
WM_DefaultProc(pMsg);
break;
上一篇:w5100实现dns解析功能
