18B20 驱动 MSP430
2022-08-19 来源:csdn
float get_temp(void);
void reset_18B20(void);
void send_18B20(char data);
unsigned int read_18B20(void);
#define ONE_WIRE_PIN BIT4
#define ONE_WIRE_IN P1IN
#define ONE_WIRE_OUT P1OUT
#define ONE_WIRE_DIR P1DIR
unsigned int temp;
reset_18B20();
send_18B20(0xcc); //send CCH,Skip ROM command
send_18B20(0x44);
delay_us(100);
reset_18B20();
send_18B20(0xbe);
temp = read_18B20();
return((float)temp/8.0);
ONE_WIRE_DIR |=ONE_WIRE_PIN;
ONE_WIRE_OUT &= ~ONE_WIRE_PIN;
__delay_cycles(500);
ONE_WIRE_OUT |=ONE_WIRE_PIN;
ONE_WIRE_DIR &= ~ONE_WIRE_PIN;
char i;
for(i=8;i>0;i--)
__delay_cycles(2);
if(data & 0x01)
ONE_WIRE_OUT |= ONE_WIRE_PIN;
__delay_cycles(60);
data >>=1;
unsigned int read_18B20()
char i;
unsigned int data=0;
for(i=16;i>0;i--)
ONE_WIRE_DIR |= ONE_WIRE_PIN;
__delay_cycles(2);
__delay_cycles(8);
if(ONE_WIRE_IN & ONE_WIRE_PIN)
data |=0x8000;
data>>=1;
__delay_cycles(120);
return(data);
