以太网 Lite MAC(媒体访问控制器)设计用来整合 IEEE 标准内介绍的可用特性。802.3 媒体独立接口(MII)规范。
The Ethernet Lite MAC (Media Access Controller) is designed to incorporate the applicable features described in the IEEE Std. 802.3 Media Independent Interface (MII) specification, which should be used as the definitive specification.
The Ethernet Lite MAC supports the IEEE Std. 802.3 Media Independent Interface (MII) to industry standard Physical Layer (PHY) devices and communicates to a processor via a Processor Local Bus (PLB) interface. The design provides a 10 Megabits per second (Mbps) and 100 Mbps (also known as Fast Ethernet) Interface. The goal is to provide the minimal functions necessary to provide an Ethernet interface with the least resources used.
关键特性
- PLB interface is based on PLB v4.6 specification
- Memory mapped direct I/O interface to the transmit and receive data dual port memory
- Media Independent Interface (MII) for connection to external 10/100 Mbps PHY transceivers
- Independent internal 2K byte Tx and Rx dual port memory for holding data for one packet
- Optional dual buffer memories, 4K byte ping-pong, for Tx and Rx
XPS Ethernet Lite Media Access Controller Data Sheet (PDF):
更多:
http://china.xilinx.com/products/ipcenter/xps_ethernetlite.htm
本帖最后由 心仪 于 2010-3-31 14:41 编辑 ]
