10MBd Digital Optocoupler for High Insulation Voltage Applications
Avago Technologies announced the release of
a 10MBd Digital Optocoupler with high Insulation Voltage ratings for power supply and high-power motor control application.
The ACNV2601 single channel, 10MBd digital optocoupler addresses growing market segments that need high data communication rates along with high insulation voltage performance.
Avago’s ACNV2601 is the industry-first optocoupler that combines 10 MBd data rates while maintaining or increasing insulating voltage ratings.
ACNV2601 is designed to provide 7,500 Vrms/1 minute isolation voltage, 1,768 Vpeak continuous working insulation voltage and 12,000 Vpeak transient over voltage. The ACNV2601 is pending IEC/UL/CSA regulatory certification for Reinforced Insulation against electric shock applications.
Avago’s proprietary internal shield between the AlGaAs light emitting diode and photo-detector
helps guarantee 20,000 V/µs common-mode transient immunity performance with a common-mode voltage of 1,500 V. 10MBd Optocoupler Applications
The high insulating voltages of the Avago ACNV2601 makes it suitable for applications with 690 V power main voltages or high speed, power switching equipment that use high voltage IGBTs. Applications like wind turbines, Intelligent Power Modules and communication interfaces, such as RS‑232/RS‑485 and CANBus, will benefit from the combined high speed and insulation voltage characteristics of the ACNV2601.
Where conventional line receivers cannot operate, the ACNV2601 provides reliable logic interfacing and input/output buffering in the presence of extremely high ground or induced noise. Key Features:
10 MBd typical data rate and high insulation voltage
ACNV2601 Worldwide safety approvals pending:
IEC/EN/DIN 60747-5-5 with a 1,768 Vpeak insulation working voltage and 12,000 Vpeak transient over voltage
UL1577 with 7,500 Vrms for one minute input-to-output insulation voltage
CSA
20 kV/µs common-mode transient immunity at Vcm = 1,500 V
2 mm internal package distance-through-insulation
13 mm minimum package creepage and clearance
5 V supply operation
10-pin wide body DIP package with gull wing SMD lead option
Wide temperature operation: -40 to 105° C
Packaging and Temperature Range
A 10-pin wide body (500 mil) DIP package is offered along with a gull wing lead option for standard surface mount processes. The ACNV2601 10MBd optocoupler operates over a wide temperature range of -40 to +105 degrees-C, with guaranteed AC and DC electrical performance.
Besides providing high insulation ratings, the ACNV2601’s package provides creepage and clearance greater than 13 mm and distance through insulation (DTI) of 2 mm. Availability
Samples and production quantities are available now through Avago’s direct sales channel and worldwide distribution partners. More information about Avago´s products can be found at: www.avagotech.com/optocoupler.
