[求助] 关于Atmel ATSAM3X8E的SPI ASF问题
john_fq   2019-1-20 17:41 楼主
大家好,我用arduino due在Atmel Studio 的ASF下实现SPI功能,没有成功,想问问是什么问题,运行后LED灯有闪,但是SPI的时钟和数据没有波形,麻烦帮忙看看问题在哪?  感谢
代码如下:
#include
#define LED IOPORT_CREATE_PIN(PIOB,27)
//#define MISO IOPORT_CREATE_PIN(PIOA,25)
//#define MOSI IOPORT_CREATE_PIN(PIOA,26)
//#define SPCK IOPORT_CREATE_PIN(PIOA,27)
//#define NPCS IOPORT_CREATE_PIN(PIOA,28)
#define DEFAULT_CHIP_ID   0
int main (void)
        /* Insert system clock initialization code here (sysclk_init()). */
        Spi SPI_EXAMPLE;
        struct spi_device SPI_DEVICE_EXAMPLE1 = {.id = IOPORT_CREATE_PIN(PIOA,28)};
        uint32_t SPI_EXAMPLE_BAUDRATE = 1000000;
        uint8_t spi_data = 0x55;
        uint32_t  i=0;
        board_init();
        sysclk_init();
        ioport_init();
        uint8_t data_buffer[1] = {0xAA};
        ioport_set_pin_mode(PIO_PA25_IDX,IOPORT_MODE_MUX_A);
        ioport_disable_pin(PIO_PA25_IDX);
        ioport_set_pin_mode(PIO_PA26_IDX,IOPORT_MODE_MUX_A);
        ioport_disable_pin(PIO_PA26_IDX);
        ioport_set_pin_mode(PIO_PA27_IDX,IOPORT_MODE_MUX_A);
        ioport_disable_pin(PIO_PA27_IDX);
        ioport_set_pin_mode(PIO_PA28_IDX,IOPORT_MODE_MUX_A);
        ioport_disable_pin(PIO_PA28_IDX);
                spi_master_init(&SPI_EXAMPLE);
                spi_master_setup_device(&SPI_EXAMPLE,&SPI_DEVICE_EXAMPLE1,SPI_MODE_1,1000000,0);
                spi_enable(&SPI_EXAMPLE);
//        ioport_set_pin_dir(LED,IOPORT_DIR_OUTPUT);
        while(1)
                if( spi_is_tx_ready (&SPI_EXAMPLE) == 1)
                        spi_select_device(&SPI_EXAMPLE,&SPI_DEVICE_EXAMPLE1);
                        spi_write_packet(&SPI_EXAMPLE, data_buffer, 1);
                        spi_read_packet(&SPI_EXAMPLE, data_buffer, 1);
                        spi_deselect_device(&SPI_EXAMPLE,&SPI_DEVICE_EXAMPLE1);
                        ioport_toggle_pin_level(LED);
                        delay_ms(500);
                else
                        ioport_set_pin_level(LED,IOPORT_PIN_LEVEL_HIGH);
        /* Insert application code here, after the board has been initialized. */
回复评论 (1)
SPI_EXAMPLE 不用设置的?
默认摸鱼,再摸鱼。2022、9、28
点赞  2019-1-22 13:33
    写回复
