[求助] TM4c129在EPI总线的通用模式下怎么实现收发FPGA的数据
wzllonglong   2019-11-26 22:09 楼主
tm4c129EPI总线通用模式具体配置如下:
void EPI_Init()
         SysCtlPeripheralEnable(SYSCTL_PERIPH_EPI0);         //使能EPI模块
         SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
         SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
     SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
     SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
     SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG);
     SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOH);
     SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOJ);
         GPIOPinConfigure(GPIO_PH3_EPI0S0);                                 //引脚设置
         GPIOPinConfigure(GPIO_PH2_EPI0S1);
         GPIOPinConfigure(GPIO_PC4_EPI0S2);
         GPIOPinConfigure(GPIO_PC5_EPI0S3);
         GPIOPinConfigure(GPIO_PC6_EPI0S4);
         GPIOPinConfigure(GPIO_PC7_EPI0S5);
         GPIOPinConfigure(GPIO_PH0_EPI0S6);
         GPIOPinConfigure(GPIO_PH1_EPI0S7);
         GPIOPinConfigure(GPIO_PH7_EPI0S27);
     GPIOPinConfigure(GPIO_PD5_EPI0S28);
         GPIOPinConfigure(GPIO_PD6_EPI0S29);
//         GPIOPinConfigure(GPIO_PJ6_EPI0S30);
         GPIOPinConfigure(GPIO_PG7_EPI0S31);
         GPIOPinTypeEPI(GPIO_PORTH_BASE,GPIO_PIN_3 );  //D0
         GPIOPinTypeEPI(GPIO_PORTH_BASE,GPIO_PIN_2 );  //D1
         GPIOPinTypeEPI(GPIO_PORTC_BASE,GPIO_PIN_4 );  //D2
         GPIOPinTypeEPI(GPIO_PORTC_BASE,GPIO_PIN_5 );  //D3
         GPIOPinTypeEPI(GPIO_PORTC_BASE,GPIO_PIN_6 );  //D4
         GPIOPinTypeEPI(GPIO_PORTC_BASE,GPIO_PIN_7 );  //D5
         GPIOPinTypeEPI(GPIO_PORTH_BASE,GPIO_PIN_0 );  //D6
         GPIOPinTypeEPI(GPIO_PORTH_BASE,GPIO_PIN_1 );  //D7
         GPIOPinTypeEPI(GPIO_PORTH_BASE,GPIO_PIN_7 );  //iRDY
         GPIOPinTypeEPI(GPIO_PORTD_BASE,GPIO_PIN_5 );  //WR
         GPIOPinTypeEPI(GPIO_PORTD_BASE,GPIO_PIN_6 );  //RD
//         GPIOPinTypeEPI(GPIO_PORTJ_BASE,GPIO_PIN_6 );  //FRAME
         GPIOPinTypeEPI(GPIO_PORTG_BASE,GPIO_PIN_7 );  //clk
         EPIModeSet(EPI0_BASE,EPI_MODE_GENERAL);
         EPIConfigGPModeSet(EPI0_BASE,EPI_GPMODE_ASIZE_NONE|EPI_GPMODE_DSIZE_8|EPI_GPMODE_RDYEN|EPI_GPMODE_CLKPIN|EPI_GPMODE_READ2CYCLE|EPI_GPMODE_READWRITE,0,0);
//         HWREG(EPI0_BASE + EPI_O_GPCFG2) =0x00000000;
//         HWREG(EPI0_BASE + EPI_O_GPCFG) =0x90240000;
//         EPIConfigGPModeSet(EPI0_BASE,EPI_GPMODE_ASIZE_NONE|EPI_GPMODE_DSIZE_8|EPI_GPMODE_CLKGATE|EPI_GPMODE_CLKPIN|EPI_GPMODE_READ2CYCLE|EPI_GPMODE_READWRITE,0,0);
         EPIFIFOConfig(EPI0_BASE,EPI_FIFO_CONFIG_RX_FULL);
         EPIDividerSet(EPI0_BASE, 0);                                   //50M
         EPIIntEnable(EPI0_BASE,EPI_INT_RXREQ);                   //接收中断
         IntEnable(INT_EPI0);
         IntMasterEnable();
/*         HWREG(EPI0_BASE + EPI_O_ADDRMAP) = 0x00000000;        //no per addr,256b ram
         HWREG(EPI0_BASE + EPI_O_RSIZE0)  =        0x00000001;        //8bit data
         HWREG(EPI0_BASE + EPI_O_RADDR0)  = 0x00000000;        //current addr          */
         EPINonBlockingReadConfigure(EPI0_BASE,0,EPI_NBCONFIG_SIZE_8,0);
请问一下配置完后怎么用地址映射向FPGA发数据和收数据?求助各位大神! 急用,谢谢!
回复评论 (3)
这个需要看数据手册有关EPI配置内容
http://www.ti.com/cn/lit/ds/symlink/tm4c129encpdt.pdf
点赞  2019-11-27 09:58
引用: Jacktang 发表于 2019-11-27 09:58 这个需要看数据手册有关EPI配置内容 http://www.ti.com/cn/lit/ds/symlink/tm4c129encpdt.pdf
我看过了,就是看的不太懂,你能给我讲一下吗
点赞  2019-11-27 12:33
请问问题解决了吗?能否告知一下,也碰到了同样的问题。
点赞  2019-12-24 16:26
    写回复
