[资料分享] MSP430F5529 上手小例程
灞波儿奔   2019-12-1 17:47 楼主
 将F553 设置按键脉冲
按下P1.1,P1.4产生一个脉冲,时间为5s
按下p2.1,P1.4产生一个脉冲,时间为1.2s
#include <msp430.h>
#include <msp430f5529.h>
* main.c
* 将F553 设置按键脉冲
* 按下P1.1,P1.4产生一个脉冲,时间约为5s
* 按下p2.1,P1.4产生一个脉冲,时间约为1.2s
int main(void)
   WDTCTL = WDTPW | WDTHOLD;   // stop watchdog timer
//设置输入输出
   P2DIR &= ~BIT1;
   P1DIR &= ~BIT1;
   P1DIR |= BIT4;
   P4DIR |= BIT7;
//按键无预先设置的值,故先将悬空设为1,防止之前为0。P1.1,P2.1按键
   P1OUT |= BIT1;
   P2OUT |= BIT1;
//设为输入时必须加上此寄存器配置(上下拉电阻)
   P1REN |= BIT1;
   P2REN |= BIT1;
//中断允许,下降沿中断
   P1IE |= BIT1;
   P2IE |= BIT1;
   P1IES |= BIT1;
   P2IES |= BIT1;
   P1IFG &= ~BIT1;
   P2IFG &= ~BIT1;
   _EINT();
   return 0;
#pragma vector = PORT1_VECTOR
__interrupt void PORT1(void)
   if(!(P1IN & BIT1))      //按下按键P1.1,
       P1OUT |= BIT4;      //P1OUT寄存器的第5位置一,P1.4电压抬高
       __delay_cycles(5000000);
       P1OUT &= ~BIT4;
   P1IFG &= ~BIT1;
#pragma vector = PORT2_VECTOR
__interrupt void PORT2(void)
   if(!(P2IN & BIT1))
       P4OUT |= BIT7;
       __delay_cycles(120000);
       P4OUT &= ~BIT7;
   P1IFG &= ~BIT1;
回复评论
暂无评论,赶紧抢沙发吧
    写回复
