ce4.2支持 22寸宽屏?
mostimes   2009-9-25 08:37 楼主
如题,
要改哪些地方?
英雄!
回复评论 (18)
不能支持这么大屏幕吧,嘿嘿。
点赞  2009-9-25 08:53
用VGA口。17的是支持的。试过了。宽屏没试过。
点赞  2009-9-25 09:04
支持的尺寸跟驱动才有关吧
点赞  2009-9-25 09:04
MARK一下!!!
点赞  2009-9-25 09:08
没见过直接带这么大的屏幕的!vga倒是可以吧!
点赞  2009-9-25 09:22
要看是哪个CPU吧
点赞  2009-9-25 09:31
点亮了。只不过分辨率有点问题。
CPU  PXA255
点赞  2009-9-25 09:58
把竖屏横过来
点赞  2009-9-25 10:01
  1.                 PCD = 1;
  2.                         v_pLcdRegs->LCCR1 =        ( LCD_PPL(799) | LCD_HSW(150) |
  3.        LCD_ELW(25)  | LCD_BLW(210) );
  4.                         v_pLcdRegs->LCCR2 = ( LCD_LPP(599)  | LCD_VSW(5) |
  5.        LCD_EFW(77)         | LCD_BFW(16) );
  6.
  7.                         v_pLcdRegs->LCCR3 = ( LCD_PCD(PCD)         | LCD_ACB(0xff) |  LCD_PCP | LCD_BPP(BPP)
  8.        | LCD_HSP | LCD_VSP);
  9.                         v_pLcdRegs->LCCR0 = ( LCD_OUM | LCD_BM | LCD_QDM | LCD_PAS |
  10.        LCD_EFM | LCD_SFM | LCD_IUM |LCD_LDM | LCD_ENB);
这地方要改。怎么改?数字是多少?DataSheet我这里没有。。只是借来的一个屏。。看看能不能用。能用就开发了!
点赞  2009-9-25 10:05
VGA肯定没问题
点赞  2009-9-25 10:16
但是CPU的LCD控制器支持的大小是有限制的。
点赞  2009-9-25 10:17
刚刚收到一个说明:CE下的驱动:
. Copy RTPUSB.dll to a directory (Example:  D:\Your InstallSource).
2. =====================================================================
   Add the following into project.BIB ( In the parameters tab).
MODULES(<== had exist in project.BIB)
RTPUSB.dll  D:\Your InstallSource\RTPUSB.dll                NK   SH
FILES(<== had exist in project.BIB)
TPUtility.exe  D:\ Your InstallSource\TPUtility.exe         NK
3. =======================================================================
   Add the following into project.reg (In the parameters tab)
[HKEY_LOCAL_MACHINE\Drivers\USB\LoadClients\7165_5768\Default\Default\UTPSTRM]
   "DLL"="RTPUSB.DLL"
   "Prefix"="UTP"
   "Rotation"=dword:0
   "DisableReport"=dword:0
   "MouseMod"=dword:2
**Notes:
a. Dll -- system uses and do'nt change.
b. MouseMod -- This parameter descripts the emulation mode of mouse.
               1: desktop mode
               2: mouse mode
               3: button mode
c. Rotation -- This parameter descripts the screen direction.
d. DisableReport -- This parameter inhibits touch panel to active mouse cursor.
e. Prefix --  Touch panel name. Don't change.
4. TPUTility.exe is an tool to use it to do free draw test and 9 points calibration.
谁替我解释下RTPUSB是USB驱动?难道这屏是USB接触摸屏的?我得去打DATASHEET。不懂。
点赞  2009-9-25 10:49
显示搞定了。。。
就是那个触摸还不能用。再研究研究!
点赞  2009-9-25 13:23
哈哈。。好了!搞定。
不过还有一个小问题:LCD有点闪,像水波纹一样。怎么回事?
点赞  2009-9-25 14:47
时钟没调好?
点赞  2009-9-26 11:30
信号干扰
点赞  2009-9-26 13:53
学习
点赞  2009-9-27 09:00
搞定:电源功率太低影起的
点赞  2009-9-29 14:31
    写回复
