请教AMD LX800的定制wince5.0 BSP的问题
手里有一块AMD LX800的工控板子,厂商不给提供BSP。
只好在eeworld的下载频道下载了一个。
简单的配置之后,debug调试。加载到某个位置后就停住不动了~
产生这种情况的原因太多了,也不能定位到某点,就连想问为什么都问不出来!!!
有没有过来人,帮着分析分析哦?
另外用wince自带的geode那个bsp可以不?不过看那个好像是gx系列的cpu的....
如果有人能提供一份好用的BSP就更好了,国内的公司基本上都是按公板抄来抄去的,估摸着能兼容吧?
The Kernel Debugger is waiting to connect with target.
0 PID:0 TID:0 CEPC Firmware Init
0 PID:0 TID:0 RTC - Status Reg B - 0x02
0 PID:0 TID:0 g_dwCPUFeatures = 0088a93d
0 PID:0 TID:0 Looking for rom chain
0 PID:0 TID:0 Rom chain NOT found
0 PID:0 TID:0 Firmware Init Done.
0 PID:0 TID:0 Error Reporting Memory Reserved, dump size = 00020000
0 PID:0 TID:0 Booting Windows CE version 5.00 for (x86)
0 PID:0 TID:0 &pTOC = 802279d8, pTOC = 80fbb228, pTOC->ulRamFree = 81046000, MemForPT = 00004000
0 PID:0 TID:0
Old or invalid version stamp in kernel structures - starting clean!
0 PID:0 TID:0 Configuring: Primary pages: 41098, Secondary pages: 0, Filesystem pages = 20549
0 PID:0 TID:0
Booting kernel with clean memory configuration:
0 PID:0 TID:0 Memory Sections:
0 PID:0 TID:0 [0] : start: 8104b000, extension: 0000b000, length: 0a08a000
0 PID:0 TID:0 X86Init done, OEMAddressTable = 81047000.
0 PID:0 TID:0 Windows CE KernelInit
4294767298 PID:b0df002 TID:b0df1de Updated eptr->e32_vsize to = 00090000
4294767298 PID:b0df002 TID:b0df1de Scheduling the first thread.
4294767299 PID:b0df002 TID:b0df1de 0x8b0df030: KernelInit2: pCurThread=8b0df030 hCurThread=0b0df1de hCurProc=0b0df002, KernelInit = 80260e20
4294767299 PID:b0df002 TID:b0df1de 0x8b0df030: Updated eptr->e32_vsize to = 00005000
4294767310 PID:b0df002 TID:b0df1de 0x8b0df030: Updated eptr->e32_vsize to = 00022000
4294767311 PID:b0df002 TID:b0df1de 0x8b0df030: Updated eptr->e32_vsize to = 00007000
4294767311 PID:b0df002 TID:b0df1de 0x8b0df030: Updated eptr->e32_vsize to = 00018000
4294767311 PID:b0df002 TID:b0df1de 0x8b0df030: Starting kernel debugger software probe (KdStub) - KD API version 18
4294767312 PID:b0df002 TID:b0df1de 0x8b0df030: Calling KDEnableInt (FALSE, NULL) without previously calling KDEnableInt (FALSE, p)
4294767315 PID:b0df002 TID:b0df1de 0x8b0df030: >>> Loading module NK.EXE at address 0x80220000-0x802B0000 (RW data at 0x80FBD000-0x8102B21F)
Kernel debugger connected.
The Kernel Debugger connection has been established (Target CPU is X86).
Target name: CE Device
Probe name: KdStub
Binary Image should be loaded at 0x80220000 / Data relocated at 0x80fbd000
Loaded symbols for 'F:\WINCE500\PBWORKSPACES\SIMPLE_LX800\RELDIR\GEODELX_X86_DEBUG\NK.EXE'
Loaded symbols for 'F:\WINCE500\PBWORKSPACES\SIMPLE_LX800\RELDIR\GEODELX_X86_DEBUG\KD.DLL'
Loaded symbols for 'F:\WINCE500\PBWORKSPACES\SIMPLE_LX800\RELDIR\GEODELX_X86_DEBUG\OSAXST1.DLL'
Loaded symbols for 'F:\WINCE500\PBWORKSPACES\SIMPLE_LX800\RELDIR\GEODELX_X86_DEBUG\OSAXST0.DLL'
Loaded symbols for 'F:\WINCE500\PBWORKSPACES\SIMPLE_LX800\RELDIR\GEODELX_X86_DEBUG\HD.DLL'
4294767337 PID:b0df002 TID:b0df1de 0x8b0df030: first = 01ed0000, last = 02000000, SharedDllBase = 03320000
4294767339 PID:b0df002 TID:b0df1de 0x8b0df030: >>> Loading module coredll.dll at address 0x03F60000-0x04000000 (RW data at 0x01FFE000-0x01FFF765)
Loaded symbols for 'F:\WINCE500\PBWORKSPACES\SIMPLE_LX800\RELDIR\GEODELX_X86_DEBUG\COREDLL.DLL'
4294767349 PID:b0df002 TID:b0df1de 0x8b0df030: Did not find emulation code for x86... using floating point hardware.
在此处就再也没响应了~
是什么引起的此问题的呢?
内存?
没用过,友情帮顶下。
MARK,期待高人,我也学习下。
最好还是找个相应CPU的BSP,至少也要是差不多型号的,否则需要改动的东西太多。
引用: 引用 3 楼 wangxin_801115 的回复:
AMD LX800的BSP我有
赫赫 能给我发一份么?
我在网上下的是Geode_LX_5536_WinCE50.msi
引用: 引用 4 楼 veabol 的回复:
我看了下下的BSP在启动引导方面没啥改动
主要是显示驱动 AES 以及USB方面驱动
如果错误出现在那些驱动的地方,也就能明确修改的方向了。
关键是从现在死的地方根本看不出来出问题的地方呢?
我现在顺着出问题的函数加一些东西作测试,都是private文件夹里面的函数~~
另外我添加了HIVE之后出错的地方又换了~
4294767416 PID:23fc8c1a TID:23fc8bea 0x83fc8a3c: FS: Creating signal event SYSTEM/DevMgrApiSetReady
4294767417 PID:23fc8c1a TID:23fc8bea 0x83fc8a3c: FS: Creating signal event SYSTEM/PowerManagerReady
之后再也没响应
你可以选择release方式编译nk文件的。
我们也用过lx800的bsp通常情况下用release方式生成的nk文件,默认就可以启动板卡的。
0x81fff030: Did not find emulation code for x86... using floating point
hardware.
This occurs on the x86, as there are some versions of the i486 architecture that do not include the floating-point co-processor. The system will check for the presence of the FPEMUL library. (You can specify that your BSP uses one of these CPUs by setting BSP_FPEMUL=1.) All code on an x86 is written assuming the presence of the co-processor. In a case where there isn't one, the instructions cause a trap in the kernel, which then calls the emulation library to implement the floating-point calculations. This message simply informs you that the kernel did not find the emulation library and therefore is using the hardware co-processor. If your CPU doesn't have the co-processor, this would be an important message to look for if your fonts are not showing up in the Microsoft? Internet Explorer shell (or other applications).
引用: 引用 8 楼 wangxin_801115 的回复:
可以
你加我
公司不让上QQ晚上加你好么 谢谢了
引用: 引用 9 楼 zhoukq 的回复:
刚用release方式编了一下,在板子上能启动了~~~
是不是BSP那块的kitl的问题呢?
另外分辨率上有一些问题,你们那遇到过么?
引用: 引用 10 楼 amorous 的回复:
? hardware.
用过的几块x86的板子都会打出这句话~~
引用: 引用 11 楼 lmlmlmnew 的回复:
可以
你加我
公司不让上QQ晚上加你好么 谢谢了
引用 9 楼 zhoukq 的回复:
是不是BSP那块的kitl的问题呢?
BSP的DISPLAY驱动我没加上,可能是这得问题 呵呵~~~
