[MCU] 【GD32E503评测】07 测评SDIO总线驱动SD卡(二)
caizhiwei   2021-2-9 14:11 楼主
根据上一篇的贴子,我们对SD卡这个外设有了更深入的了解。
这篇重点讲解移植的过程,遇到其他MCU如何移植,重在方法。
以下是通用接口,移植不需要修改的。需要修改的是SDIO的驱动部分,要把设备驱动分开。
#ifndef SDCARD_H
#define SDCARD_H
#include "gd32e50x.h"
#include "gd32e50x_sdio.h"
#include "gd32e50x_dma.h"
#include <stddef.h>
#include <stdio.h>
/* card status of R1 definitions */
#define SD_R1_OUT_OF_RANGE                  BIT(31)                   /* command's argument was out of the allowed range */
#define SD_R1_ADDRESS_ERROR                 BIT(30)                   /* misaligned address which did not match the block length */
#define SD_R1_BLOCK_LEN_ERROR               BIT(29)                   /* transferred block length is not allowed */
#define SD_R1_ERASE_SEQ_ERROR               BIT(28)                   /* an error in the sequence of erase commands occurred */
#define SD_R1_ERASE_PARAM                   BIT(27)                   /* an invalid selection of write-blocks for erase occurred */
#define SD_R1_WP_VIOLATION                  BIT(26)                   /* the host attempts to write to a protected block or to the temporary or permanent write protected card */
#define SD_R1_CARD_IS_LOCKED                BIT(25)                   /* the card is locked by the host */
#define SD_R1_LOCK_UNLOCK_FAILED            BIT(24)                   /* a sequence or password error has been detected in lock/unlock card command */
#define SD_R1_COM_CRC_ERROR                 BIT(23)                   /* CRC check of the previous command failed */
#define SD_R1_ILLEGAL_COMMAND               BIT(22)                   /* command not legal for the card state */
#define SD_R1_CARD_ECC_FAILED               BIT(21)                   /* card internal ECC was applied but failed to correct the data */
#define SD_R1_CC_ERROR                      BIT(20)                   /* internal card controller error */
#define SD_R1_GENERAL_UNKNOWN_ERROR         BIT(19)                   /* a general or an unknown error occurred during the operation */
#define SD_R1_CSD_OVERWRITE                 BIT(16)                   /* read only section of the CSD does not match or attempt to reverse the copy or permanent WP bits */
#define SD_R1_WP_ERASE_SKIP                 BIT(15)                   /* partial address space was erased */
#define SD_R1_CARD_ECC_DISABLED             BIT(14)                   /* command has been executed without using the internal ECC */
#define SD_R1_ERASE_RESET                   BIT(13)                   /* an erase sequence was cleared before executing */
#define SD_R1_READY_FOR_DATA                BIT(8)                    /* correspond to buffer empty signaling on the bus */
#define SD_R1_APP_CMD                       BIT(5)                    /* card will expect ACMD */
#define SD_R1_AKE_SEQ_ERROR                 BIT(3)                    /* error in the sequence of the authentication process */
#define SD_R1_ERROR_BITS                    (uint32_t)0xFDF9E008      /* all the R1 error bits */
/* card status of R6 definitions */
#define SD_R6_COM_CRC_ERROR                 BIT(15)                   /* CRC check of the previous command failed */
#define SD_R6_ILLEGAL_COMMAND               BIT(14)                   /* command not legal for the card state */
#define SD_R6_GENERAL_UNKNOWN_ERROR         BIT(13)                   /* a general or an unknown error occurred during the operation */
/* card state */
#define SD_CARDSTATE_IDLE                   ((uint8_t)0x00)           /* card is in idle state */
#define SD_CARDSTATE_READY                  ((uint8_t)0x01)           /* card is in ready state */
#define SD_CARDSTATE_IDENTIFICAT            ((uint8_t)0x02)           /* card is in identificat state */
#define SD_CARDSTATE_STANDBY                ((uint8_t)0x03)           /* card is in standby state */
#define SD_CARDSTATE_TRANSFER               ((uint8_t)0x04)           /* card is in transfer state */
#define SD_CARDSTATE_DATA                   ((uint8_t)0x05)           /* card is in data sending state */
#define SD_CARDSTATE_RECEIVING              ((uint8_t)0x06)           /* card is in receiving state */
#define SD_CARDSTATE_PROGRAMMING            ((uint8_t)0x07)           /* card is in programming state */
#define SD_CARDSTATE_DISCONNECT             ((uint8_t)0x08)           /* card is in disconnect state */
#define SD_CARDSTATE_LOCKED                 ((uint32_t)0x02000000)    /* card is in locked state */
#define SD_CHECK_PATTERN                    ((uint32_t)0x000001AA)    /* check pattern for CMD8 */
#define SD_VOLTAGE_WINDOW                   ((uint32_t)0x80100000)    /* host 3.3V request in ACMD41 */
/* parameters for ACMD41(voltage validation) */
#define SD_HIGH_CAPACITY                    ((uint32_t)0x40000000)    /* high capacity SD memory card */
#define SD_STD_CAPACITY                     ((uint32_t)0x00000000)    /* standard capacity SD memory card */
/* SD bus width, check SCR register */
#define SD_BUS_WIDTH_4BIT                   ((uint32_t)0x00040000)    /* 4-bit width bus mode */
#define SD_BUS_WIDTH_1BIT                   ((uint32_t)0x00010000)    /* 1-bit width bus mode */
/* masks for SCR register */
#define SD_MASK_0_7BITS                     ((uint32_t)0x000000FF)    /* mask [7:0] bits */
#define SD_MASK_8_15BITS                    ((uint32_t)0x0000FF00)    /* mask [15:8] bits */
#define SD_MASK_16_23BITS                   ((uint32_t)0x00FF0000)    /* mask [23:16] bits */
#define SD_MASK_24_31BITS                   ((uint32_t)0xFF000000)    /* mask [31:24] bits */
#define SDIO_FIFO_ADDR                      ((uint32_t)SDIO + 0x80U)  /* address of SDIO_FIFO */
#define SD_FIFOHALF_WORDS                   ((uint32_t)0x00000008)    /* words of FIFO half full/empty */
#define SD_FIFOHALF_BYTES                   ((uint32_t)0x00000020)    /* bytes of FIFO half full/empty */
#define SD_DATATIMEOUT                      ((uint32_t)0xFFFFFFFF)    /* DSM data timeout */
#define SD_MAX_VOLT_VALIDATION              ((uint32_t)0x0000FFFF)    /* the maximum times of voltage validation */
#define SD_MAX_DATA_LENGTH                  ((uint32_t)0x01FFFFFF)    /* the maximum length of data */
#define SD_ALLZERO                          ((uint32_t)0x00000000)    /* all zero */
#define SD_RCA_SHIFT                        ((uint8_t)0x10)           /* RCA shift bits */
#define SD_CLK_DIV_INIT                     ((uint16_t)0x01C0)        /* SD clock division in initilization phase */
#define SD_CLK_DIV_TRANS                    ((uint16_t)0x0011)        /* SD clock division in transmission phase */
#define SDIO_MASK_INTC_FLAGS                ((uint32_t)0x00C007FF)    /* mask flags of SDIO_INTC */
/* SD memory card bus commands index */
#define SD_CMD_GO_IDLE_STATE                  ((uint8_t)0)   /* CMD0, GO_IDLE_STATE */
#define SD_CMD_ALL_SEND_CID                   ((uint8_t)2)   /* CMD2, ALL_SEND_CID */
#define SD_CMD_SEND_RELATIVE_ADDR             ((uint8_t)3)   /* CMD3, SEND_RELATIVE_ADDR */
#define SD_CMD_SET_DSR                        ((uint8_t)4)   /* CMD4, SET_DSR */
#define SD_CMD_SWITCH_FUNC                    ((uint8_t)6)   /* CMD6, SWITCH_FUNC */
#define SD_CMD_SELECT_DESELECT_CARD           ((uint8_t)7)   /* CMD7, SELECT_DESELECT_CARD */
#define SD_CMD_SEND_IF_COND                   ((uint8_t)8)   /* CMD8, SEND_IF_COND */
#define SD_CMD_SEND_CSD                       ((uint8_t)9)   /* CMD9, SEND_CSD */
#define SD_CMD_SEND_CID                       ((uint8_t)10)  /* CMD10, SEND_CID */
#define SD_CMD_STOP_TRANSMISSION              ((uint8_t)12)  /* CMD12, STOP_TRANSMISSION */
#define SD_CMD_SEND_STATUS                    ((uint8_t)13)  /* CMD13, SEND_STATUS */
#define SD_CMD_GO_INACTIVE_STATE              ((uint8_t)15)  /* CMD15, GO_INACTIVE_STATE */
#define SD_CMD_SET_BLOCKLEN                   ((uint8_t)16)  /* CMD16, SET_BLOCKLEN */
#define SD_CMD_READ_SINGLE_BLOCK              ((uint8_t)17)  /* CMD17, READ_SINGLE_BLOCK */
#define SD_CMD_READ_MULTIPLE_BLOCK            ((uint8_t)18)  /* CMD18, READ_MULTIPLE_BLOCK */
#define SD_CMD_WRITE_BLOCK                    ((uint8_t)24)  /* CMD24, WRITE_BLOCK */
#define SD_CMD_WRITE_MULTIPLE_BLOCK           ((uint8_t)25)  /* CMD25, WRITE_MULTIPLE_BLOCK */
#define SD_CMD_PROG_CSD                       ((uint8_t)27)  /* CMD27, PROG_CSD */
#define SD_CMD_SET_WRITE_PROT                 ((uint8_t)28)  /* CMD28, SET_WRITE_PROT */
#define SD_CMD_CLR_WRITE_PROT                 ((uint8_t)29)  /* CMD29, CLR_WRITE_PROT */
#define SD_CMD_SEND_WRITE_PROT                ((uint8_t)30)  /* CMD30, SEND_WRITE_PROT */
#define SD_CMD_ERASE_WR_BLK_START             ((uint8_t)32)  /* CMD32, ERASE_WR_BLK_START */
#define SD_CMD_ERASE_WR_BLK_END               ((uint8_t)33)  /* CMD33, ERASE_WR_BLK_END */
#define SD_CMD_ERASE                          ((uint8_t)38)  /* CMD38, ERASE */
#define SD_CMD_LOCK_UNLOCK                    ((uint8_t)42)  /* CMD42, LOCK_UNLOCK */
#define SD_CMD_APP_CMD                        ((uint8_t)55)  /* CMD55, APP_CMD */
#define SD_CMD_GEN_CMD                        ((uint8_t)56)  /* CMD56, GEN_CMD */
/* SD memory card application specific commands index */
#define SD_APPCMD_SET_BUS_WIDTH               ((uint8_t)6)   /* ACMD6, SET_BUS_WIDTH */
#define SD_APPCMD_SD_STATUS                   ((uint8_t)13)  /* ACMD13, SD_STATUS */
#define SD_APPCMD_SEND_NUM_WR_BLOCKS          ((uint8_t)22)  /* ACMD22, SEND_NUM_WR_BLOCKS */
#define SD_APPCMD_SET_WR_BLK_ERASE_COUNT      ((uint8_t)23)  /* ACMD23, SET_WR_BLK_ERASE_COUNT */
#define SD_APPCMD_SD_SEND_OP_COND             ((uint8_t)41)  /* ACMD41, SD_SEND_OP_COND */
#define SD_APPCMD_SET_CLR_CARD_DETECT         ((uint8_t)42)  /* ACMD42, SET_CLR_CARD_DETECT */
#define SD_APPCMD_SEND_SCR                    ((uint8_t)51)  /* ACMD51, SEND_SCR */
/* card command class */
#define SD_CCC_SWITCH                          BIT(10)       /* class 10 */
#define SD_CCC_IO_MODE                         BIT(9)        /* class 9 */
#define SD_CCC_APPLICATION_SPECIFIC            BIT(8)        /* class 8 */
#define SD_CCC_LOCK_CARD                       BIT(7)        /* class 7 */
#define SD_CCC_WRITE_PROTECTION                BIT(6)        /* class 6 */
#define SD_CCC_ERASE                           BIT(5)        /* class 5 */
#define SD_CCC_BLOCK_WRITE                     BIT(4)        /* class 4 */
#define SD_CCC_BLOCK_READ                      BIT(2)        /* class 2 */
#define SD_CCC_BASIC                           BIT(0)        /* class 0 */
/* SD card data transmission mode */
#define SD_DMA_MODE                           ((uint32_t)0x00000000) /* DMA mode */
#define SD_POLLING_MODE                       ((uint32_t)0x00000001) /* polling mode */
/* lock unlock status */
#define SD_LOCK                               ((uint8_t)0x05)        /* lock the SD card */
#define SD_UNLOCK                             ((uint8_t)0x02)        /* unlock the SD card */
/* supported memory cards types */
typedef enum
    SDIO_STD_CAPACITY_SD_CARD_V1_1 = 0,   /* standard capacity SD card version 1.1 */
    SDIO_STD_CAPACITY_SD_CARD_V2_0,       /* standard capacity SD card version 2.0 */
    SDIO_HIGH_CAPACITY_SD_CARD,           /* high capacity SD card */
    SDIO_SECURE_DIGITAL_IO_CARD,          /* secure digital IO card */
    SDIO_SECURE_DIGITAL_IO_COMBO_CARD,    /* secure digital IO combo card */
    SDIO_MULTIMEDIA_CARD,                 /* multimedia card */
    SDIO_HIGH_CAPACITY_MULTIMEDIA_CARD,   /* high capacity multimedia card */
    SDIO_HIGH_SPEED_MULTIMEDIA_CARD       /* high speed multimedia card */
}sdio_card_type_enum;
/* card identification (CID) register */
typedef struct
    __IO uint8_t mid;                     /* manufacturer ID */
    __IO uint16_t oid;                    /* OEM/application ID */
    __IO uint32_t pnm0;                   /* product name */
    __IO uint8_t pnm1;                    /* product name */
    __IO uint8_t prv;                     /* product revision */
    __IO uint32_t psn;                    /* product serial number */
    __IO uint16_t mdt;                    /* manufacturing date */
    __IO uint8_t cid_crc;                 /* CID CRC7 checksum */
}sd_cid_struct;
/* CSD register (CSD version 1.0 and 2.0) */
typedef struct
    __IO uint8_t csd_struct;              /* CSD struct */
    __IO uint8_t taac;                    /* data read access-time */
    __IO uint8_t nsac;                    /* data read access-time in CLK cycles */
    __IO uint8_t tran_speed;              /* max. data transfer rate */
    __IO uint16_t ccc;                    /* card command classes */
    __IO uint8_t read_bl_len;             /* max. read data block length */
    __IO uint8_t read_bl_partial;         /* partial blocks for read allowed */
    __IO uint8_t write_blk_misalign;      /* write block misalignment */
    __IO uint8_t read_blk_misalign;       /* read block misalignment */
    __IO uint8_t dsp_imp;                 /* DSR implemented */
    __IO uint32_t c_size;                 /* device size, 12 bits in CSD version 1.0, 22 bits in CSD version 2.0 */
    __IO uint8_t vdd_r_curr_min;          /* max. read current [url=home.php?mod=space&uid=201251]@vdd[/url] min, CSD version 1.0 */
    __IO uint8_t vdd_r_curr_max;          /* max. read current @VDD max, CSD version 1.0 */
    __IO uint8_t vdd_w_curr_min;          /* max. write current @VDD min, CSD version 1.0 */
    __IO uint8_t vdd_w_curr_max;          /* max. write current @VDD max, CSD version 1.0 */
    __IO uint8_t c_size_mult;             /* device size multiplier, CSD version 1.0 */
    __IO uint8_t erase_blk_en;            /* erase single block enable */
    __IO uint8_t sector_size;             /* erase sector size */
    __IO uint8_t wp_grp_size;             /* write protect group size */
    __IO uint8_t wp_grp_enable;           /* write protect group enable */
    __IO uint8_t r2w_factor;              /* write speed factor */
    __IO uint8_t write_bl_len;            /* max. write data block length */
    __IO uint8_t write_bl_partial;        /* partial blocks for write allowed */
    __IO uint8_t file_format_grp;         /* file format group */
    __IO uint8_t copy_flag;               /* copy flag (OTP) */
    __IO uint8_t perm_write_protect;      /* permanent write protection */
    __IO uint8_t tmp_write_protect;       /* temporary write protection */
    __IO uint8_t file_format;             /* file format */
    __IO uint8_t csd_crc;                 /* CSD CRC checksum */
}sd_csd_struct;
/* information of card */
typedef struct
    sd_cid_struct card_cid;               /* CID register */
    sd_csd_struct card_csd;               /* CSD register */
    sdio_card_type_enum card_type;        /* card tpye */
    uint32_t card_capacity;               /* card capacity (KB)*/
    uint32_t card_blocksize;              /* card block size (Byte)*/
    uint16_t card_rca;                    /* card relative card address */
}sd_card_info_struct;
/* SD error flags */
typedef enum
    SD_OUT_OF_RANGE = 0,                  /* command's argument was out of range */
    SD_ADDRESS_ERROR,                     /* misaligned address which did not match the block length */
    SD_BLOCK_LEN_ERROR,                   /* transferred block length is not allowed for the card or the number of transferred bytes does not match the block length */
    SD_ERASE_SEQ_ERROR,                   /* an error in the sequence of erase command occurs */
    SD_ERASE_PARAM,                       /* an invalid selection of write-blocks for erase occurred */
    SD_WP_VIOLATION,                      /* attempt to program a write protect block or permanent write protected card */
    SD_LOCK_UNLOCK_FAILED,                /* sequence or password error has been detected in lock/unlock card command */
    SD_COM_CRC_ERROR,                     /* CRC check of the previous command failed */
    SD_ILLEGAL_COMMAND,                   /* command not legal for the card state */
    SD_CARD_ECC_FAILED,                   /* card internal ECC was applied but failed to correct the data */
    SD_CC_ERROR,                          /* internal card controller error */
    SD_GENERAL_UNKNOWN_ERROR,             /* general or unknown error occurred during the operation */
    SD_CSD_OVERWRITE,                     /* read only section of the CSD does not match the card content or an attempt to reverse the copy or permanent WP bits was made */
    SD_WP_ERASE_SKIP,                     /* only partial address space was erased or the temporary or permanent write protected card was erased */
    SD_CARD_ECC_DISABLED,                 /* command has been executed without using internal ECC */
    SD_ERASE_RESET,                       /* erase sequence was cleared before executing because an out of erase sequence command was received */
    SD_AKE_SEQ_ERROR,                     /* error in the sequence of the authentication process */
    SD_CMD_CRC_ERROR,                     /* command response received (CRC check failed) */
    SD_DATA_CRC_ERROR,                    /* data block sent/received (CRC check failed) */
    SD_CMD_RESP_TIMEOUT,                  /* command response timeout */
    SD_DATA_TIMEOUT,                      /* data timeout */
    SD_TX_UNDERRUN_ERROR,                 /* transmit FIFO underrun error occurs */
    SD_RX_OVERRUN_ERROR,                  /* received FIFO overrun error occurs */
    SD_START_BIT_ERROR,                   /* start bit error in the bus */
    SD_VOLTRANGE_INVALID,                 /* the voltage range is invalid */
    SD_PARAMETER_INVALID,                 /* the parameter is invalid */
    SD_OPERATION_IMPROPER,                /* the operation is improper */
    SD_FUNCTION_UNSUPPORTED,              /* the function is unsupported */
    SD_ERROR,                             /* an error occurred */
    SD_OK                                 /* no error occurred */
}sd_error_enum;
typedef enum
  SD_NO_TRANSFER = 0,                     /* no data transfer is acting */
  SD_TRANSFER_IN_PROGRESS                 /* data transfer is in progress */
}sd_transfer_state_enum;
extern uint32_t sd_scr[2];                /* SD card SCR */
/* function declarations */
/* initialize the card and get CID and CSD of the card */
sd_error_enum sd_card_init(void);
/* configure the clock and the work voltage, and get the card type */
sd_error_enum sd_power_on(void);
/* close the power of SDIO */
sd_error_enum sd_power_off(void);
/* configure the bus mode */
sd_error_enum sd_bus_mode_config(uint32_t busmode);
/* configure the mode of transmission */
sd_error_enum sd_transfer_mode_config(uint32_t txmode);
/* read a block data into a buffer from the specified address of a card */
sd_error_enum sd_block_read(uint32_t *preadbuffer, uint32_t readaddr, uint16_t blocksize);
/* read multiple blocks data into a buffer from the specified address of a card */
sd_error_enum sd_multiblocks_read(uint32_t *preadbuffer, uint32_t readaddr, uint16_t blocksize, uint32_t blocksnumber);
/* write a block data to the specified address of a card */
sd_error_enum sd_block_write(uint32_t *pwritebuffer, uint32_t writeaddr, uint16_t blocksize);
/* write multiple blocks data to the specified address of a card */
sd_error_enum sd_multiblocks_write(uint32_t *pwritebuffer, uint32_t writeaddr, uint16_t blocksize, uint32_t blocksnumber);
/* erase a continuous area of a card */
sd_error_enum sd_erase(uint32_t startaddr, uint32_t endaddr);
/* process all the interrupts which the corresponding flags are set */
sd_error_enum sd_interrupts_process(void);
/* select or deselect a card */
sd_error_enum sd_card_select_deselect(uint16_t cardrca);
/* get the card status whose response format R1 contains a 32-bit field */
sd_error_enum sd_cardstatus_get(uint32_t *pcardstatus);
/* get the SD status, the size of the SD status is one data block of 512 bit */
sd_error_enum sd_sdstatus_get(uint32_t *psdstatus);
/* stop an ongoing data transfer */
sd_error_enum sd_transfer_stop(void);
/* lock or unlock a card */
sd_error_enum sd_lock_unlock(uint8_t lockstate);
/* get the data transfer state */
sd_transfer_state_enum sd_transfer_state_get(void);
/* get SD card capacity(KB) */
uint32_t sd_card_capacity_get(void);
/* get the detailed information of the SD card based on received CID and CSD */
sd_error_enum sd_card_information_get(sd_card_info_struct *pcardinfo);
sd_error_enum BSP_SDCard_init(void);
void BSP_SDCard_info_get(void);
void BSP_SDCard_test(void);
2. 这里利用官方给的demo,自己再添砖加瓦,做了些修改,增加一个初始化接口。
	int i  = 0;
	sd_error_enum sd_error;
	/* initialize the card , Must try more times.*/
	for(i=0; i<10; i++)  /*循环尝试次数*/
		sd_error = SDcard_init();
		if(sd_error == SD_OK)
			break;
        printf("\r\n Card init success![%d]\r\n",i);
	else
        printf("\r\n Card init failed!\r\n");
	return sd_error;
这里倒是很奇怪的,有时候一次初始化不能成功,需要要循环几次~ 不知道有没有小伙伴遇到同样的。
这些驱动整理进去,就可以看到效果了!
微信图片_20210209140910.png 微信图片_20210209140918.jpg 代码见附件:
gitee/casy
回复评论 (4)
没有看到插入附件的地方,贴子都不能添加附件了吗
gitee/casy
点赞  2021-2-9 14:12
虾扯蛋,蛋扯虾,虾扯蛋扯虾
点赞  2021-3-14 20:58
附件在哪里?
点赞  2023-7-9 20:57
引用: 黑仔23 发表于 2023-7-9 20:57 附件在哪里?
黑仔,您好,需要源码吗?
gitee/casy
点赞  2023-7-12 13:50
    写回复
