[资源共享] 树莓派PICO的一些扩展模块产品
Jacktang   2021-3-28 21:43 楼主
Pimoroni公司的产品
-Pico Explorer Base
11.jpeg 特性
Pico Explorer Base
Piezo speaker
1.54" IPS LCD screen (240 x 240)
Four user-controllable switches
Two Half-Bridge motor drivers (with over current indicator LED)
Easy access GPIO and ADC pin Headers
Two Breakout Garden I2C sockets
Mini breadboard
Rubber feet
Compatible with Raspberry Pi Pico.
No soldering required (as long as your Pico has header pins attached).
Dimensions: approx 117mm x 63mm x 20mm (L x W x H, assembled)
C/C++ and MicroPython libraries
22.png Pico RGB Keypad Base
33.jpeg 特性
4x4 silicone keypad with conductive buttons
16 x APA102 addressable RGB LEDs (datasheet)
Keypad buttons are connected via a TCA9555 IO expander (I2C address: 0x20).
Labelled landing area with female headers for attaching your Pico, with broken out pins.
Some assembly required!
Dimensions: approx 60mm x 101mm x 16mm (L x W x H, assembled)
管脚连接
image.png Pico Unicorn Pack
44.jpeg 特性
16x7 matrix of RGB LEDs (112 total)
Individual colour/brightness control of each LED
4 x tactile buttons
Pre-soldered female headers for attaching to Pico
Fully assembled
Dimensions: approx 62mm x 25mm x 10mm (L x W x H, including headers and buttons)
管脚连接
回复评论 (2)
Pico Display Pack
-特性
1.14” 240x135 pixel IPS LCD screen
4 x tactile buttons
RGB LED
Fully assembled
Dimensions: approx 53mm x 25mm x 9mm (L x W x H)
Screen usable area: approx 25mm x 15mm (L x W)
管脚连接
-Pico Scroll Pack
-特性
17x7 matrix of white LEDs (119 total)
Individual PWM brightness control of each LED
IS31FL3731 LED matrix driver chip, I2C address: 0x74
4x tactile buttons
Fully assembled
Dimensions: approx 65mm x 25mm x 10mm (L x W x H, including headers and buttons)
管脚连接
-Pico Audio Pack (Line-Out and Headphone Amp)
-特性
PCM5100A stereo DAC (datasheet)
PAM8908JER stereo headphone amp (datasheet)
3.5mm stereo headphone jack connector
3.5mm stereo line out jack connector
Switch to adjust headphone amp gain (low / high)
Fully assembled
Dimensions: approx 53mm x 29mm x 11mm (L x W x H, including headers and audio jacks)
Programmable with C/C++
管脚连接
-Pimoroni Pico VGA Demo Base
-特性
15-pin VGA connector
PCM5100A DAC for line out audio over I2S (datasheet)
PWM audio output
SD card slot
Reset button
Female headers to install your Raspberry Pi Pico
Three user-controllable switches
Rubber feet
连接图片
-Pico Omnibus (Dual Expander)
-特性
One landing area with labelled female headers for attaching to your Pico.
Two landing areas with labelled (mirrored) male headers for attaching add-ons.
4x rubber feet
99% assembled - just need to stick on the feet!
Fully assembled.
No soldering required.
Dimensions: approx 94mm x 52 mm x 12mm (L x W x H, including headers)
-连接图片
-Pico Breakout Garden Base
-特性
Six sturdy edge-connector slots for Pimoroni breakouts
4x I2C slots (5 pins)
2x SPI slot (7 pins)
Landing area with female headers for Raspberry Pi Pico
0.1” pitch, 5 or 7 pin connectors
Broken-out pins
Reverse polarity protection (built into breakouts)
-Pico Decker (Quad Expander)
-特性
Four landing areas with labelled (mirrored) male headers for attaching add-ons.
4x M2.5 mounting holes.
4x rubber feet
Dimensions: approx 148mm x 52mm x 13mm (L x W x H, including feet and headers)
-连接图片
点赞  2021-3-28 21:45
这种外设的搭载方式看着挺酷
点赞  2021-3-29 09:18
这种拓展版感觉自己也可以DIY
点赞  2021-3-29 12:42
    写回复
