[经验分享] 【基于人脸识别的自动打卡健走计时系统】K210 MAIXBIT用二维码识别作为用户信息
alanlan86   2022-9-25 18:22 楼主
调试目标
  • 考虑到K210的交互界面比较少,因此考虑用户的信息录入采用二维码的方式,可以用ID名字等一次二维码扫描搞定,然后通过语音提示用户录入成功
调试准备
  • 基于之前的帖子有提到wav语音的播放,因此首先需要用GoldenWav CN软件,用文字转换语音的方式,准备一段 “识别成功” 的语音文件
  • 使用草料二维码(https://cli.im/text)转换出一段 包含如下信息“eeworld,123654,01:02:03:04:05:06,cs” 信息的二维码。
调试代码
import sensor
import image
import lcd
import time
from fpioa_manager import *
from Maix import I2S, GPIO
import audio
def audio_init():
    # register i2s(i2s0) pin
    fm.register(34, fm.fpioa.I2S0_OUT_D1, force=True)
    fm.register(35, fm.fpioa.I2S0_SCLK, force=True)
    fm.register(33, fm.fpioa.I2S0_WS, force=True)
    # init i2s(i2s0)
    wav_dev = I2S(I2S.DEVICE_0)
    print("i2s init")
    return wav_dev
def audio_play(wav_dev, volume):
    # init audio
    player = audio.Audio(path="/sd/2.wav")
    player.volume(volume)
    print("audio init")
    # read audio info
    wav_info = player.play_process(wav_dev)
    # config i2s according to audio info
    wav_dev.channel_config(wav_dev.CHANNEL_1, I2S.TRANSMITTER, resolution=I2S.RESOLUTION_16_BIT,
                       cycles=I2S.SCLK_CYCLES_16, align_mode=I2S.RIGHT_JUSTIFYING_MODE)
    wav_dev.set_sample_rate(wav_info[1])
    # loop to play audio
    while True:
        ret = player.play()
        if ret == None:
            print("format error")
            break
        elif ret == 0:
            print("end")
            break
    player.finish()
clock = time.clock()
dev = audio_init()
lcd.init()
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QVGA)
sensor.set_vflip(1)
sensor.run(1)
sensor.skip_frames(30)
while True:
    clock.tick()
    img = sensor.snapshot()
    res = img.find_qrcodes()
    fps =clock.fps()
    if len(res) > 0:
        img.draw_string(2, 2, res[0].payload(), color=(0,128,0), scale=2)
        print(res[0].payload())
        audio_play(dev, 50)
    lcd.display(img)
调试结果
  • 当用手机出示二维码时候,界面出现识别后字符串,同时播放出一段语音提示,识别成功!
回复评论 (3)
最后能播放出一段语音提示,证明很成功
点赞  2022-9-26 07:28
强啊!感谢楼主分享!
点赞  2022-9-28 09:20
了解了解
点赞  2022-9-29 10:10
    写回复
