现在需要用Waveout函数系列来实现播放wav文件的功能,播放功能已经实现,现在实现快进的功能的时候出现了一个问题,就是在按下快进按钮的时候, 原来已经读入缓冲区的音频内容还在, 请问这时候如何去清除缓冲区内的音频内容.
如果你用的是C#就可以用进度条直接拖动,那样最方便。我写的一个播放器,部分代码如下:你可以参考一下。
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
namespace ChatSharpPlayer
public partial class ChatSharpPlayer : Form
int x,btopmost;
public ChatSharpPlayer()
btopmost = 1;
InitializeComponent();
private void 电影一ToolStripMenuItem_Click(object sender, EventArgs e)
if (openFileDialog1.ShowDialog() == DialogResult.OK)
Player1.URL = openFileDialog1.FileName;
string temp = researchTheFileName(openFileDialog1.FileName);
listBox1.Items.Add(temp);
timer1.Enabled = true;
x = 1;
private void 电影二ToolStripMenuItem_Click(object sender, EventArgs e)
Player2.URL = openFileDialog1.FileName;
x = 2;
private void 电影三ToolStripMenuItem_Click(object sender, EventArgs e)
Player3.URL = openFileDialog1.FileName;
x = 3;
private void 电影四ToolStripMenuItem_Click(object sender, EventArgs e)
Player4.URL = openFileDialog1.FileName;
x = 4;
private void Player1_ClickEvent(object sender, AxWMPLib._WMPOCXEvents_ClickEvent e)
x = 1;
private void Player2_ClickEvent(object sender, AxWMPLib._WMPOCXEvents_ClickEvent e)
x = 2;
private void Player3_ClickEvent(object sender, AxWMPLib._WMPOCXEvents_ClickEvent e)
x = 3;
private void Player4_ClickEvent(object sender, AxWMPLib._WMPOCXEvents_ClickEvent e)
x = 4;
private void button1_Click(object sender, EventArgs e)
switch (x)
case 1: Player1.Ctlcontrols.play(); break;
case 2: Player2.Ctlcontrols.play(); break;
case 3: Player3.Ctlcontrols.play(); break;
case 4: Player4.Ctlcontrols.play(); break;
private void button2_Click(object sender, EventArgs e)
switch (x)
case 1: Player1.Ctlcontrols.pause(); break;
case 2: Player2.Ctlcontrols.pause(); break;
case 3: Player3.Ctlcontrols.pause(); break;
case 4: Player4.Ctlcontrols.pause(); break;
private void button3_Click(object sender, EventArgs e)
switch (x)
case 1: Player1.Ctlcontrols.stop(); break;
case 2: Player2.Ctlcontrols.stop(); break;
case 3: Player3.Ctlcontrols.stop(); break;
case 4: Player4.Ctlcontrols.stop(); break;
private void button4_Click(object sender, EventArgs e)
System.Windows.Forms.Application.Exit();
private void trackBar1_Scroll(object sender, EventArgs e)
switch (x)
case 1: Player1.Ctlcontrols.currentPosition = trackBar1.Value;
case 2: Player2.Ctlcontrols.currentPosition = trackBar1.Value;
case 3: Player3.Ctlcontrols.currentPosition = trackBar1.Value;
case 4: Player4.Ctlcontrols.currentPosition = trackBar1.Value;
private void timer1_Tick(object sender, EventArgs e)
switch (x)
case 1:trackBar1.Maximum = (int)Player1.currentMedia.duration;
trackBar1.Value = (int)Player1.Ctlcontrols.currentPosition; break;
case 2:trackBar1.Maximum = (int)Player2.currentMedia.duration;
trackBar1.Value = (int)Player2.Ctlcontrols.currentPosition; break;
case 3:trackBar1.Maximum = (int)Player3.currentMedia.duration;
trackBar1.Value = (int)Player3.Ctlcontrols.currentPosition; break;
case 4:trackBar1.Maximum = (int)Player4.currentMedia.duration;
trackBar1.Value = (int)Player4.Ctlcontrols.currentPosition; break;
private void trackBar1_MouseUp(object sender, MouseEventArgs e)
switch (x)
private void trackBar1_MouseDown(object sender, MouseEventArgs e)
switch (x)
private void trackBar2_Scroll(object sender, EventArgs e)
switch (x)
case 1: Player1.settings.volume = trackBar2.Value; break;
case 2: Player2.settings.volume = trackBar2.Value; break;
case 3: Player3.settings.volume = trackBar2.Value; break;
case 4: Player4.settings.volume = trackBar2.Value; break;
private void button5_Click(object sender, EventArgs e)
btopmost++;
if (btopmost % 2 == 0)
this.TopMost = false;
button5.Text = "置前";
else
this.TopMost = true;
button5.Text = "取消置前";
private string researchTheFileName(string m)
char[] fg={'\\'};
string[] FileName = m.Split(fg);
int i = FileName.Length - 1;
return FileName;
private void button6_Click(object sender, EventArgs e)
Player1.settings.mute = !(Player1.settings.mute);
可以实现:进度条拖动,静音,音量调节,窗口置前,可以同时播放四个视频。
buffer自己是可以访问得到的。至于你的快进应该是把播放速度放快的就行了,要是拖动到一个位置播放,那要waveOutUnprepareHeader,然后waveOutPrepareHeader 来重新设置buffer
