【前言】
stm32U5系列有比较优秀的ADC外设,U5A5有ADC12与ADC4。
在用户手册《RM0456》中有描述:
STM32U5A5除了有14位的ADC12外还有12位的ADC4,总共可以支持45个通道输入。
本次体验只是初步体验:
【软件环境】STM32CubeIDE1.14.0
【实现步骤】
1、新建基于NOCLE-U5A5ZJ-Q的开发板工程。
2、使用默认的生成环境,环境中初始化了开发板的基础运行环境,如串口等。
3、开发板工程已经初始好了ADC1的AN3通道(PC2)。其基础配置参数如下:
生成代码后可以看到配置的代码如下:
/* ADC1 init function */
void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
hadc1.Init.Resolution = ADC_RESOLUTION_14B;
hadc1.Init.GainCompensation = 0;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
hadc1.Init.OversamplingMode = DISABLE;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_3;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLETIME_5CYCLE;
sConfig.SingleDiff = ADC_SINGLE_ENDED;
sConfig.OffsetNumber = ADC_OFFSET_NONE;
sConfig.Offset = 0;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
在主程序中添加测试代码如下:
int main(void)
/* USER CODE BEGIN 1 */
uint16_t adc_val;
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* Configure the System Power */
SystemPower_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_ADC1_Init();
MX_ICACHE_Init();
MX_UCPD1_Init();
MX_USART1_UART_Init();
MX_USB_OTG_HS_HCD_Init();
/* USER CODE BEGIN 2 */
printf("start\r\n");
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
HAL_ADC_Start(&hadc1);
adc_val = HAL_ADC_GetValue(&hadc1);
printf("ADC VaL:%d voltage:%.3f \r\n ", adc_val, (float)adc_val*3.3/16384);
HAL_Delay(500);
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
其代码为添加一个变量adc_val用来存放ADC的转换值,使用HAL_ADC_Start(&hadc1);开始ADC的转换,使用 adc_val = HAL_ADC_GetValue(&hadc1);来读取转换结果
使用printf把打印结果输出到串口。
【实验效果】
1、接入一个可调电位器到开发板上,调节电器位可以看到实实时的转换结果。
2、同时将万用表也接到电位器的输出端口进行对比测试。
我们通过看到万用表与串口输出值的对比,相差为mV级别。
将转换时间延长到814个周期,可以看到转换的稳定性相比5个周期要好很多:
