测试设备 | 单位 | 数量 |
EV_F4A0_LQ176_REV1.0开发板 | 块 | 壹 |
ARM仿真器 | 个 | 壹 |
5V电源适配器 | 个 | 壹 |
ZLG USBCANFD-200U | 个 | 壹 |
ALIENTEK 4.3’TFTLCD | 块 | 壹 |
RIGOL DHO804示波器 | 台 | 壹 |
产生发送数据
static void LoadData()
uint8_t i;
for (i = 0U; i < CAN_TX_DATA_SIZE; i++) {
stcTx1.au8Data[i] = i + 0x0AU;
stcTx2.au8Data[i] = i + 0x3aU;
stcTx1.u32Ctrl = 0x0UL;
stcTx1.u32ID = CAN_TX_ID1;
stcTx1.IDE = CAN_TX_ID1_IDE;
stcTx1.DLC = CAN_TX_DLC;
stcTx2.u32Ctrl = 0x0UL;
stcTx2.u32ID = CAN_TX_ID2;
stcTx2.IDE = CAN_TX_ID2_IDE;
stcTx2.DLC = CAN_TX_DLC;
发送数据并显示
static void CanTx(uint16_t u16Width,uint16_t u16Height)
uint8_t i;
if (BSP_KEY_GetStatus(BSP_KEY_1) == SET) {
if (m_u8TxStart == 0U) {
m_u8TxProcess++;
if (m_u8TxProcess > CAN_TX_PROCESS_STB) {
m_u8TxProcess = CAN_TX_PROCESS_PTB;
switch (m_u8TxProcess) {
case CAN_TX_PROCESS_PTB:
/* Transmit one frame via PTB */
(void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_PTB, &stcTx1);
CAN_StartTx(CAN_UNIT, CAN_TX_REQ_PTB);
//lcd_show_xnum(140,20,m_astRxFrame[0].u32ID,4,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(120,100,stcTx1.au8Data[0],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(150,100,stcTx1.au8Data[1],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(180,100,stcTx1.au8Data[2],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(210,100,stcTx1.au8Data[3],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(240,100,stcTx1.au8Data[4],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(270,100,stcTx1.au8Data[5],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(300,100,stcTx1.au8Data[6],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(330,100,stcTx1.au8Data[7],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
break;
case CAN_TX_PROCESS_STB:
/* Transmit one frame via STB */
(void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_STB, &stcTx2);
CAN_StartTx(CAN_UNIT, CAN_TX_REQ_STB_ONE);
lcd_show_xnum(120,100,stcTx2.au8Data[0],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(150,100,stcTx2.au8Data[1],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(180,100,stcTx2.au8Data[2],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(210,100,stcTx2.au8Data[3],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(240,100,stcTx2.au8Data[4],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(270,100,stcTx2.au8Data[5],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(300,100,stcTx2.au8Data[6],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(330,100,stcTx2.au8Data[7],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
break;
m_u32TxTick = CAN_TX_TIMEOUT_MS;
m_u8TxStart = 1U;
} else {
接收数据并显示
static void CanRx(uint16_t u16Width,uint16_t u16Height)
uint8_t i;
uint8_t j;
uint8_t u8RxFrameNum = 0U;
int32_t i32Ret;
/* Get all received frames. */
do {
i32Ret = CAN_GetRxFrame(CAN_UNIT, &m_astRxFrame[u8RxFrameNum]);
if (i32Ret == LL_OK) {
u8RxFrameNum++;
} while (i32Ret == LL_OK);
lcd_show_xnum(120,60,m_astRxFrame[0].au8Data[0],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(150,60,m_astRxFrame[0].au8Data[1],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(180,60,m_astRxFrame[0].au8Data[2],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(210,60,m_astRxFrame[0].au8Data[3],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(240,60,m_astRxFrame[0].au8Data[4],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(270,60,m_astRxFrame[0].au8Data[5],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(300,60,m_astRxFrame[0].au8Data[6],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_xnum(330,60,m_astRxFrame[0].au8Data[7],2,24,0,LCD_COLOR_BLACK,u16Width,u16Height);
/* Handle received frames. */
for (i = 0U; i < u8RxFrameNum; i++) {
for (j = 0; j < (uint8_t)m_astRxFrame[i].DLC; j++) {
m_astRxFrame[i].au8Data[j] = 2U;
过滤器设置
#define CAN_FILTER1_ID (0x101UL)
#define CAN_FILTER1_ID_MASK (0x0UL)
#define CAN_FILTER1_ID_TYPE (CAN_ID_STD)
主函数
int32_t main(void)
uint16_t u16Width;
uint16_t u16Height;
/* MCU Peripheral registers write unprotected */
LL_PERIPH_WE(LL_PERIPH_ALL);
/* Initialize system clock: */
BSP_CLK_Init();
CLK_SetClockDiv(CLK_BUS_EXCLK, CLK_EXCLK_DIV8);
BSP_IO_Init();
//BSP_LED_Init();
BSP_LCD_IO_Init();
BSP_KEY_Init();
BSP_LCD_RSTCmd(EIO_PIN_RESET); /* RST# to low */
DDL_DelayMS(50UL);
BSP_LCD_RSTCmd(EIO_PIN_SET); /* RST# to high */
DDL_DelayMS(50UL);
BSP_NT35510_Init();
BSP_NT35510_Clear(LCD_COLOR_WHITE);
BSP_LCD_BKLCmd(EIO_PIN_SET);
/* Set LCD cursor */
BSP_NT35510_SetCursor(0U, 0U);
/* Turn on LCD backlight */
CanCommClockConfig();
CanPinConfig();
CanInitConfig();
CanIrqConfig();
CanPhyEnable();
(void)SysTick_Init(1000U);
/* Clear LCD screen */
/* MCU Peripheral registers write protected */
LL_PERIPH_WP(LL_PERIPH_ALL);
u16Width = BSP_NT35510_GetPixelWidth();
u16Height = BSP_NT35510_GetPixelHeight();
LoadData();
lcd_show_string(20,20,u16Width,u16Height,24,"CAN_RX_ID:",LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_string(20,60,u16Width,u16Height,24,"RX_DATA:",LCD_COLOR_BLACK,u16Width,u16Height);
lcd_show_string(20,100,u16Width,u16Height,24,"TX_DATA:",LCD_COLOR_BLACK,u16Width,u16Height);
for (;;) {
if (m_u8RxFlag != 0U) {
/* Read frames here or in CAN_IrqCallback */
CanRx(u16Width,u16Height);
m_u8RxFlag = 0U;
CanTx(u16Width,u16Height);
can盒发送过程:
