platform方式的led驱动测试。
一、驱动程序
1.1、leddevice.c
#include <linux/types.h>
#include <linux/kernel.h>
#include <linux/delay.h>
#include <linux/ide.h>
#include <linux/init.h>
#include <linux/module.h>
#include <linux/errno.h>
#include <linux/gpio.h>
#include <linux/cdev.h>
#include <linux/device.h>
#include <linux/of_gpio.h>
#include <linux/semaphore.h>
#include <linux/timer.h>
#include <linux/irq.h>
#include <linux/wait.h>
#include <linux/poll.h>
#include <linux/fs.h>
#include <linux/fcntl.h>
#include <linux/platform_device.h>
#include <asm/mach/map.h>
#include <asm/uaccess.h>
#include <asm/io.h>
* 寄存器地址定义
#define IOMUXC_SW_MUX_CTL_PAD_EIM_ADDR17_BASE (0X020E00F0)
#define IOMUXC_SW_PAD_CTL_PAD_EIM_ADDR17_BASE (0X020E0404)
#define GPIO2_DR_BASE (0X020A0000)
#define GPIO2_GDIR_BASE (0X020A0004)
#define REGISTER_LENGTH 4
/* [url=home.php?mod=space&uid=1068364]@description[/url] : 释放flatform设备模块的时候此函数会执行
* @param - dev : 要释放的设备
* [url=home.php?mod=space&uid=784970]@return[/url] : 无
static void led_release(struct device *dev)
printk("led device released!\r\n");
* 设备资源信息,也就是LED0所使用的所有寄存器
static struct resource led_resources[] = {
[0] = {
.start = IOMUXC_SW_MUX_CTL_PAD_EIM_ADDR17_BASE,
.end = (IOMUXC_SW_MUX_CTL_PAD_EIM_ADDR17_BASE + REGISTER_LENGTH - 1),
.flags = IORESOURCE_MEM,
[1] = {
.start = IOMUXC_SW_PAD_CTL_PAD_EIM_ADDR17_BASE,
.end = (IOMUXC_SW_PAD_CTL_PAD_EIM_ADDR17_BASE + REGISTER_LENGTH - 1),
[2] = {
.start = GPIO2_DR_BASE,
.end = (GPIO2_DR_BASE + REGISTER_LENGTH - 1),
[3] = {
.start = GPIO2_GDIR_BASE,
.end = (GPIO2_GDIR_BASE + REGISTER_LENGTH - 1),
* platform设备结构体
static struct platform_device leddevice = {
.name = "imx6q-led",
.id = -1,
.dev = {
.release = &led_release,
.num_resources = ARRAY_SIZE(led_resources),
.resource = led_resources,
* @description : 设备模块加载
* @param : 无
* @return : 无
static int __init leddevice_init(void)
return platform_device_register(&leddevice);
* @description : 设备模块注销
* @param : 无
* @return : 无
static void __exit leddevice_exit(void)
platform_device_unregister(&leddevice);
module_init(leddevice_init);
module_exit(leddevice_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("ZZK");
1.2、leddriver.c
#include <asm/io.h>
#define LEDDEV_CNT 1 /* 设备号长度 */
#define LEDDEV_NAME "platled" /* 设备名字 */
#define LEDOFF 0
#define LEDON 1
/* 寄存器名 */
static void __iomem *SW_MUX_GPIO2_IO21;
static void __iomem *SW_PAD_GPIO2_IO21;
static void __iomem *GPIO2_DR;
static void __iomem *GPIO2_GDIR;
/* leddev设备结构体 */
struct leddev_dev{
dev_t devid; /* 设备号 */
struct cdev cdev; /* cdev */
struct class *class; /* 类 */
struct device *device; /* 设备 */
int major; /* 主设备号 */
struct leddev_dev leddev; /* led设备 */
* @description : LED打开/关闭
* @param - sta : LEDON(0) 打开LED,LEDOFF(1) 关闭LED
* @return : 无
void led0_switch(u8 sta)
u32 val = 0;
if(sta == LEDON){
val = readl(GPIO2_DR);
val &= ~(1 << 21);
writel(val, GPIO2_DR);
}else if(sta == LEDOFF){
val|= (1 << 21);
* @description : 打开设备
* @param - inode : 传递给驱动的inode
* @param - filp : 设备文件,file结构体有个叫做private_data的成员变量
* 一般在open的时候将private_data指向设备结构体。
* @return : 0 成功;其他 失败
static int led_open(struct inode *inode, struct file *filp)
filp->private_data = &leddev; /* 设置私有数据 */
return 0;
* @description : 向设备写数据
* @param - filp : 设备文件,表示打开的文件描述符
* @param - buf : 要写给设备写入的数据
* @param - cnt : 要写入的数据长度
* @param - offt : 相对于文件首地址的偏移
* @return : 写入的字节数,如果为负值,表示写入失败
static ssize_t led_write(struct file *filp, const char __user *buf, size_t cnt, loff_t *offt)
int retvalue;
unsigned char databuf[1];
unsigned char ledstat;
retvalue = copy_from_user(databuf, buf, cnt);
if(retvalue < 0) {
return -EFAULT;
ledstat = databuf[0]; /* 获取状态值 */
if(ledstat == LEDON) {
led0_switch(LEDON); /* 打开LED灯 */
}else if(ledstat == LEDOFF) {
led0_switch(LEDOFF); /* 关闭LED灯 */
return 0;
/* 设备操作函数 */
static struct file_operations led_fops = {
.owner = THIS_MODULE,
.open = led_open,
.write = led_write,
* @description : flatform驱动的probe函数,当驱动与
* 设备匹配以后此函数就会执行
* @param - dev : platform设备
* @return : 0,成功;其他负值,失败
static int led_probe(struct platform_device *dev)
int i = 0;
int ressize[5];
u32 val = 0;
struct resource *ledsource[5];
printk("led driver and device has matched!\r\n");
/* 1、获取资源 */
for (i = 0; i < 4; i++) {
ledsource[i] = platform_get_resource(dev, IORESOURCE_MEM, i); /* 依次MEM类型资源 */
if (!ledsource[i]) {
dev_err(&dev->dev, "No MEM resource for always on\n");
return -ENXIO;
ressize[i] = resource_size(ledsource[i]);
/* 2、初始化LED */
/* 寄存器地址映射 */
//IMX6U_CCM_CCGR1 = ioremap(ledsource[0]->start, ressize[0]);
SW_MUX_GPIO2_IO21 = ioremap(ledsource[0]->start, ressize[0]);
SW_PAD_GPIO2_IO21 = ioremap(ledsource[1]->start, ressize[1]);
GPIO2_DR = ioremap(ledsource[2]->start, ressize[2]);
GPIO2_GDIR = ioremap(ledsource[3]->start, ressize[3]);
/* 设置GPIO2_IO21复用功能,将其复用为GPIO2_IO21 */
writel(5, SW_MUX_GPIO2_IO21);
writel(0x10B0, SW_PAD_GPIO2_IO21);
/* 设置GPIO2_IO21为输出功能 */
val = readl(GPIO2_GDIR);
val &= ~(1 << 21); /* 清除以前的设置 */
val |= (1 << 21); /* 设置为输出 */
writel(val, GPIO2_GDIR);
/* 默认关闭LED1 */
val |= (1 << 21) ;
/* 注册字符设备驱动 */
/*1、创建设备号 */
if (leddev.major) { /* 定义了设备号 */
leddev.devid = MKDEV(leddev.major, 0);
register_chrdev_region(leddev.devid, LEDDEV_CNT, LEDDEV_NAME);
} else { /* 没有定义设备号 */
alloc_chrdev_region(&leddev.devid, 0, LEDDEV_CNT, LEDDEV_NAME); /* 申请设备号 */
leddev.major = MAJOR(leddev.devid); /* 获取分配号的主设备号 */
/* 2、初始化cdev */
leddev.cdev.owner = THIS_MODULE;
cdev_init(&leddev.cdev, &led_fops);
/* 3、添加一个cdev */
cdev_add(&leddev.cdev, leddev.devid, LEDDEV_CNT);
/* 4、创建类 */
leddev.class = class_create(THIS_MODULE, LEDDEV_NAME);
if (IS_ERR(leddev.class)) {
return PTR_ERR(leddev.class);
/* 5、创建设备 */
leddev.device = device_create(leddev.class, NULL, leddev.devid, NULL, LEDDEV_NAME);
if (IS_ERR(leddev.device)) {
return PTR_ERR(leddev.device);
return 0;
* @description : platform驱动的remove函数,移除platform驱动的时候此函数会执行
static int led_remove(struct platform_device *dev)
//iounmap(IMX6U_CCM_CCGR1);
iounmap(SW_MUX_GPIO2_IO21);
iounmap(SW_PAD_GPIO2_IO21);
iounmap(GPIO2_DR);
iounmap(GPIO2_GDIR);
cdev_del(&leddev.cdev);/* 删除cdev */
unregister_chrdev_region(leddev.devid, LEDDEV_CNT); /* 注销设备号 */
device_destroy(leddev.class, leddev.devid);
class_destroy(leddev.class);
return 0;
/* platform驱动结构体 */
static struct platform_driver led_driver = {
.driver = {
.name = "imx6q-led", /* 驱动名字,用于和设备匹配 */
.probe = led_probe,
.remove = led_remove,
* @description : 驱动模块加载函数
* @param : 无
* @return : 无
static int __init leddriver_init(void)
return platform_driver_register(&led_driver);
* @description : 驱动模块卸载函数
* @param : 无
* @return : 无
static void __exit leddriver_exit(void)
platform_driver_unregister(&led_driver);
module_init(leddriver_init);
module_exit(leddriver_exit);
1.3、Makefile
KERNELDIR := ~/okmx6q-c/linux-4.1.15
CURRENT_PATH := $(shell pwd)
obj-m := leddevice.o leddriver.o
build: kernel_modules
kernel_modules:
$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) modules
clean:
$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) clean
二、编译及运行
2.1、编译驱动模块
root@ThinkPad:~/okmx6q-c/app/platform# make ARCH=arm
root@ThinkPad:~/okmx6q-c/app/platform# cp leddevice.ko leddriver.ko /nfs_rootfs/imx6qdl-rootfs/lib/modules/4.1.15
2.2、加载驱动模块
2.3、测试运行
使用上篇的测试程序运行
LED闪烁运行。
