ESP32-C6支持很多无线通信协议,下面就通过wifi获取天气信息。
本次获取天气使用的是心知天气服务。使用该服务需要注册心知天气账号,获取个人使用的API KEY。
下面是获取天气的接口:
也可以获取3天内的天气(免费版):
下面就是代码实现了。首先就是需要WIFI,JSON,和HTTPClient库支持。
#include <WiFi.h>
#include <Arduino_JSON.h>
#include <HTTPClient.h>
const char *ssid = "SSID"; //WIFI名称
const char *pwd = "PWD"; //WIFI密码
//填入你获得的API Key
String openWeatherMapApiKey = "API KEY";
//String http_api_str = "https://api.seniverse.com/v3/weather/now.json?key=your_api_key&location=beijing&language=zh-Hans&unit=c" //now
//返回例子
//{"results":[
//{"location":{"id":"WX4FBXXFKE4F","name":"北京","country":"CN","path":"北京,北京,中国","timezone":"Asia/Shanghai","timezone_offset":"+08:00"},
//"now":{"text":"晴","code":"0","temperature":"22"},"last_update":"2024-05-20T10:22:03+08:00"}
//3Day https://api.seniverse.com/v3/weather/daily.json?key=your_api_key&location=beijing&language=zh-Hans&unit=c&start=0&days=3
//返回例子
//{"results":
//[{"location":{"id":"WS0E9D8WN298","name":"广州","country":"CN","path":"广州,广州,广东,中国","timezone":"Asia/Shanghai","timezone_offset":"+08:00"},
//"daily":[
// {"date":"2024-05-20","text_day":"大雨","code_day":"15","text_night":"雷阵雨","code_night":"11","high":"25","low":"21","rainfall":"29.50","precip":"0.92","wind_direction":"东","wind_direction_degree":"90","wind_speed":"23.4","wind_scale":"4","humidity":"91"},
// {"date":"2024-05-21","text_day":"雷阵雨","code_day":"11","text_night":"雷阵雨","code_night":"11","high":"27","low":"21","rainfall":"1.29","precip":"0.24","wind_direction":"无持续风向","wind_direction_degree":"","wind_speed":"8.4","wind_scale":"2","humidity":"87"},
// {"date":"2024-05-22","text_day":"雷阵雨","code_day":"11","text_night":"雷阵雨","code_night":"11","high":"28","low":"24","rainfall":"0.88","precip":"0.22","wind_direction":"无持续风向","wind_direction_degree":"","wind_speed":"3.0","wind_scale":"1","humidity":"91"}],
//"last_update":"2024-05-20T08:00:00+08:00"}
获取天气服务的JSON数据。
//获取天气JSON数据
String httpGETRequest(const char* serverName)
WiFiClient client;
HTTPClient http;
//连接网址
http.begin(client, serverName);
//发送HTTP站点请求
int httpResponseCode = http.GET();
//该数组用于储存获得的数据
String payload = "{}";
//将获得的数据放入数组
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
payload = http.getString();
else {
Serial.print("Error code: ");
//释放资源
http.end();
//返回获得的数据用于Json处理
return payload;
初始化连接WIFI热点:
WiFi.mode(WIFI_MODE_STA);
Serial.println(WiFi.macAddress());
WiFi.begin(ssid, pwd);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
Serial.println("WiFi connected!");
Serial.print("Connected to WiFi network with IP Address: ");
Serial.println(WiFi.localIP());
定时循环获取天气信息:
//发送HTTP获取请求
if ((millis() - lastTime) > timerDelay)
timerDelay = 60000;
//检测WIFI是否已经连接
if(WiFi.status()== WL_CONNECTED)
String serverPath = "http://api.seniverse.com/v3/weather/now.json?key=" + openWeatherMapApiKey + "&location=" + city + "&language=en&unit=c";
Serial.println("=======================================================================");
//将组合好的URL放入httpGETRequest函数中通过HTTP获取请求以获得文本
jsonBuffer = httpGETRequest(serverPath.c_str());
Serial.println(jsonBuffer);
//将解析的Json对象值储存在Jsonu缓冲区中
JSONVar myObject = JSON.parse(jsonBuffer);
//判断解析是否成功
if (JSON.typeof(myObject) == "undefined") {
Serial.println("Parsing input failed!");
return;
// Serial.print("JSON object = ");
// Serial.println(myObject);
Serial.print("Weather: ");
Serial.println(myObject["results"][0]["now"]["text"]);
Serial.print("Code: ");
Serial.println(myObject["results"][0]["now"]["code"]);
Serial.print("Temperature: ");
Serial.println(myObject["results"][0]["now"]["temperature"]);
else {
Serial.println("WiFi Disconnected");
lastTime = millis();
下面是打印输出的天气信息:
整体代码如下:
#include <WiFi.h>
#include <Wire.h>
#include <RPR-0521RS.h>
#include <shtc3.h>
RPR0521RS rpr0521rs;
SHTC3 d_shtc3;
#define myLED 15 //设置引脚15为LED引脚
//填入你获得的API Key
String openWeatherMapApiKey = "API KEY";//你的心知天气API KEY
//返回例子
//{"results":[
//返回例子
//{"results":
//"daily":[
const char *ntpServer = "pool.ntp.org";
const long gmtOffset_sec = 8 * 3600;
const int daylightOffset_sec = 0;
// 填写城市名以及国家简写
String city = "GuangZhou";
String jsonBuffer;
unsigned long lastTime = 0;
//设置每10分钟获得一次天气数据
unsigned long timerDelay = 10000;
//打印时间
void printLocalTime()
struct tm timeinfo;
if (!getLocalTime(&timeinfo))
Serial.println("Failed to obtain time");
return;
Serial.println(&timeinfo, "%F %T %A"); // 格式化输出
//获取天气JSON数据
WiFiClient client;
HTTPClient http;
//连接网址
//发送HTTP站点请求
//该数组用于储存获得的数据
//将获得的数据放入数组
else {
//释放资源
http.end();
//返回获得的数据用于Json处理
return payload;
void setup()
byte rc;
pinMode(myLED, OUTPUT);
digitalWrite(myLED, HIGH);
Serial.begin(115200);
Serial.println("******************************** senser test *******************************************");
//set the resolution to 12 bits (0-4096)
analogReadResolution(12);
Wire.begin();
rc = rpr0521rs.init();
Serial.print(F("RPR-0521RS Init = "));
Serial.println(rc);
rc = d_shtc3.Init();
Serial.print(F("SHTC3 Init = "));
Serial.println(rc);
delay(500);
Serial.print(".");
// 从网络时间服务器上获取并设置时间
// 获取成功后芯片会使用RTC时钟保持时间的更新
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
printLocalTime();
void loop()
byte rc;
byte near_far;
unsigned short ps_val;
float als_val;
int temp;
int rh;
delay(100);
printLocalTime();
Serial.println("----------------------------------------");
// read the analog / millivolts value for pin 2:
int analogValue = analogRead(0);
int analogVolts = analogReadMilliVolts(0);
// print out the values you read:
Serial.print("ADC analog value = ");
Serial.println(analogValue);
Serial.print("ADC millivolts value = ");
Serial.print(analogVolts);
Serial.println("mV");
// Please adjust the calculation coefficient according to the actual measurement.
Serial.print("BAT millivolts value = ");
Serial.print(analogVolts * 2.1218 + 1000);
delay(100);
rc = rpr0521rs.get_psalsval(&ps_val, &als_val);
if (rc == 0) {
Serial.print(F("RPR-0521RS (Proximity) = "));
Serial.print(ps_val);
near_far = rpr0521rs.check_near_far(ps_val);
if (near_far == RPR0521RS_NEAR_VAL) {
Serial.print(F(" Near,"));
} else {
Serial.print(F(" Far,"));
if (als_val != RPR0521RS_ERROR) {
Serial.print(F("\t (Ambient Light) = "));
Serial.print(als_val);
Serial.println(F("[lx]."));
delay(100);
rc = d_shtc3.GetMode1_TempRH(&temp, &rh);
if (rc == 0) {
Serial.print(F("SHTC3 Temp = "));
Serial.print(temp);
Serial.print("^C,");
Serial.print(F(" \t RH = "));
Serial.print(rh);
Serial.println("%");
Serial.println();
digitalWrite(myLED, LOW);
delay(800);
//发送HTTP获取请求
timerDelay = 60000;
//检测WIFI是否已经连接
//判断解析是否成功
return;
// Serial.print("Pressure: ");
// //myObject["now"]["pressure"]前为{}前的引号内容,后为读取哪一个引号后数据
// Serial.println(myObject["now"]["pressure"]);
// Serial.print("Humidity: ");
// Serial.println(myObject["now"]["humidity"]);
// Serial.print("Wind Speed: ");
// Serial.println(myObject["now"]["wind_speed"]);
else {
