测试AT25SF128 FLASH读写。
一、硬件电路图
开发板AT25SF128部分电路图
二、软件配置
2.1、添加SPI
2.2、配置SPI引脚
2.3、根据FLASH芯片设置此参数
三、程序代码
3.1、main.c
#include "hal_data.h"
#include "led/led.h"
#include "debug_uart/bsp_debug_uart.h"
#include "sdram/board_sdram.h"
#include "ospi_flash/bsp_ospi_flash.h"
#include "common_utils.h"
fsp_err_t err;
void R_BSP_WarmStart(bsp_warm_start_event_t event);
* [url=home.php?mod=space&uid=159083]@brief[/url] Blinky example application
* Blinks all leds at a rate of 1 second using the software delay function provided by the BSP.
void hal_entry (void)
fsp_err_t err = FSP_SUCCESS;
fsp_pack_version_t version = {RESET_VALUE};
uint32_t flash_id = RESET_VALUE;
uint8_t * p_ospi_b_address = NULL;
init_led();
Debug_UART3_Init();
//bsp_sdram_init();
err = ospi_b_init();
/* Read Flash device ID */
err = ospi_b_read_device_id(&flash_id);
printf("ID:%lx\r\n",flash_id);
/* 选择Flash 测试地址 */
p_ospi_b_address = OSPI_B_APP_ADDRESS(OSPI_B_SECTOR_FIRST);
/* Flash 读写操作测试 */
ospi_b_operation(p_ospi_b_address);
while (1)
R_BSP_SoftwareDelay(100, BSP_DELAY_UNITS_MILLISECONDS);
led201_on();
led201_off();
3.2、bsp_ospi_flash.c
#include "stdio.h"
#include "ospi_flash/ospi_b_commands.h"
extern spi_flash_direct_transfer_t g_ospi_b_direct_transfer [OSPI_B_TRANSFER_MAX];
/* Global variables */
uint8_t g_read_data [OSPI_B_APP_DATA_SIZE] = {RESET_VALUE};
const uint8_t g_write_data [OSPI_B_APP_DATA_SIZE] = {
0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F,
0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E, 0x1F,
0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28, 0x29, 0x2A, 0x2B, 0x2C, 0x2D, 0x2E, 0x2F,
0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39, 0x3A, 0x3B, 0x3C, 0x3D, 0x3E, 0x3F,
fsp_err_t ospi_b_read_device_id (uint32_t * const p_id)
spi_flash_direct_transfer_t transfer = {RESET_VALUE};
/* Read and check flash device ID */
transfer = g_ospi_b_direct_transfer[OSPI_B_TRANSFER_READ_DEVICE_ID_SPI];
err = R_OSPI_B_DirectTransfer(&g_ospi_flash_ctrl, &transfer, SPI_FLASH_DIRECT_TRANSFER_DIR_READ);
if(err!=FSP_SUCCESS)
printf("R_OSPI_B_DirectTransfer API FAILED \r\n");
/* Get flash device ID */
*p_id = transfer.data;
return err;
* @brief This functions enables write and verify the read data.
* @param None
* @retval FSP_SUCCESS Upon successful operation
* @retval FSP_ERR_ABORTED Upon incorrect read data.
* @retval Any Other Error code apart from FSP_SUCCESS Unsuccessful operation
static fsp_err_t ospi_b_write_enable (void)
/* Transfer write enable command */
transfer = g_ospi_b_direct_transfer[OSPI_B_TRANSFER_WRITE_ENABLE_SPI];
err = R_OSPI_B_DirectTransfer(&g_ospi_flash_ctrl, &transfer, SPI_FLASH_DIRECT_TRANSFER_DIR_WRITE);
/* Read Status Register */
transfer = g_ospi_b_direct_transfer[OSPI_B_TRANSFER_READ_STATUS_SPI];
/* Check Write Enable bit in Status Register */
if(OSPI_B_WEN_BIT_MASK != (transfer.data & OSPI_B_WEN_BIT_MASK))
printf("Write enable FAILED\r\n");
return err;
* @brief This function wait until OSPI operation completes.
* @param[in] timeout Maximum waiting time
* @retval FSP_SUCCESS Upon successful wait OSPI operating
* @retval FSP_ERR_TIMEOUT Upon time out
* @retval Any Other Error code apart from FSP_SUCCESS Unsuccessful operation.
static fsp_err_t ospi_b_wait_operation (uint32_t timeout)
spi_flash_status_t status = {RESET_VALUE};
status.write_in_progress = true;
while (status.write_in_progress)
/* Get device status */
R_OSPI_B_StatusGet(&g_ospi_flash_ctrl, &status);
if(RESET_VALUE == timeout)
printf("OSPI time out occurred\r\n");
R_BSP_SoftwareDelay(1, OSPI_B_TIME_UNIT);
timeout --;
return err;
* @brief This function performs an erase sector operation on the flash device.
* @param[in] *p_address Pointer to flash device memory address
* @param[out] *p_time Pointer will be used to store execute time
* @retval FSP_SUCCESS Upon successful erase operation
static fsp_err_t ospi_b_erase_operation (uint8_t * const p_address)
uint32_t sector_size = RESET_VALUE;
uint32_t erase_timeout = RESET_VALUE;
/* Check sector size according to input address pointer, described in S28HS512T data sheet */
if(OSPI_B_SECTOR_4K_END_ADDRESS < (uint32_t)p_address)
sector_size = OSPI_B_SECTOR_SIZE_256K;
erase_timeout = OSPI_B_TIME_ERASE_256K;
else
sector_size = OSPI_B_SECTOR_SIZE_4K;
erase_timeout = OSPI_B_TIME_ERASE_4K;
/* Performs erase sector */
err = R_OSPI_B_Erase(&g_ospi_flash_ctrl, p_address, sector_size);
/* Wait till operation completes */
err = ospi_b_wait_operation(erase_timeout);
return err;
* @brief This function performs an write operation on the flash device.
* @retval FSP_SUCCESS Upon successful write operation
static fsp_err_t ospi_b_write_operation (uint8_t * const p_address)
/* Erase sector before write data to flash device */
err = ospi_b_erase_operation(p_address);
/* Write data to flash device */
err = R_OSPI_B_Write(&g_ospi_flash_ctrl, g_write_data, p_address, OSPI_B_APP_DATA_SIZE);
/* Wait until write operation completes */
err = ospi_b_wait_operation(OSPI_B_TIME_WRITE);
return err;
* @brief This function performs an read operation on the flash device.
* @retval FSP_SUCCESS Upon successful read operation
static fsp_err_t ospi_b_read_operation (uint8_t * const p_address)
/* Clean read buffer */
memset(&g_read_data, RESET_VALUE, OSPI_B_APP_DATA_SIZE);
/* Read data from flash device */
memcpy(&g_read_data, p_address, OSPI_B_APP_DATA_SIZE);
return err;
* @brief This functions initializes OSPI module and Flash device.
* @param None
* @retval FSP_SUCCESS Upon successful initialization of OSPI module and Flash device
* @retval Any Other Error code apart from FSP_SUCCESS Unsuccessful open
fsp_err_t ospi_b_init (void)
/* By default, the flash device is in SPI mode, so it is necessary to open the OSPI module in SPI mode */
/* Open OSPI module */
err = R_OSPI_B_Open(&g_ospi_flash_ctrl, &g_ospi_flash_cfg);
/* Switch OSPI module to 1S-1S-1S mode to configure flash device */
err = R_OSPI_B_SpiProtocolSet(&g_ospi_flash_ctrl, SPI_FLASH_PROTOCOL_EXTENDED_SPI);
/* Reset flash device by driving OM_RESET pin */
R_XSPI->LIOCTL_b.RSTCS0 = 0;
R_BSP_SoftwareDelay(OSPI_B_TIME_RESET_PULSE, OSPI_B_TIME_UNIT);
R_XSPI->LIOCTL_b.RSTCS0 = 1;
R_BSP_SoftwareDelay(OSPI_B_TIME_RESET_SETUP, OSPI_B_TIME_UNIT);
err = ospi_b_write_enable();
return err;
fsp_err_t ospi_b_operation (uint8_t * p_address)
uint16_t i = 0;
if(err==FSP_SUCCESS)
printf("Write %d bytes completed successfully\r\n", (int)(OSPI_B_APP_DATA_SIZE));
else
printf("Write operation failure\r\n");
printf("Write Data:\r\n");
for(i=0;i<=OSPI_B_APP_DATA_SIZE-1;i++)
printf("%d ",g_write_data[i]);
err = ospi_b_read_operation (p_address);
/* Print execution time */
printf("\r\nRead %d bytes completed successfully\r\n", (int)(OSPI_B_APP_DATA_SIZE));
else
printf("\r\nRead operation failure\r\n");
printf("Read Data:\r\n");
for(i=0;i<=sizeof(g_read_data)-1;i++)
printf("%d ",g_read_data[i]);
if(RESET_VALUE == memcmp(&g_read_data, &g_write_data, (size_t)OSPI_B_APP_DATA_SIZE))
printf("\r\nData read matched data written\r\n");
printf("flash读写数据成功\r\n");
else
printf("\r\nData read does not match data written\r\n");
printf("flash读写数据失败\r\n");
/* Performs OSPI erase operation */
printf("Erase sector completed successfully\r\n");
else
printf("erase operation failure\r\n");
return err;
四、运行结果
读写数据测试结果
