[原创] 【年终回炉:ST NUCLEO-U083RC】+SPI点亮OLED屏应用测试
流水源   2026-3-24 22:38 楼主
本次来试试SPI功能。使用手上SPI接口的oled来试一试。
首先还是打开STM32CUBEMX来配置SPI接口。
OLED接口使用SPI1,PA5,PA6,PA7。
片选使用PB6,DC脚使用PC7,复位脚使用PA9。
下面是编写代码,OLED的spi接口驱动如下
#include "main.h"
#include "drv_spi.h"
void    drv_spi_gpio_init( void )
 * SSIOF callback function
 * @param[in]   dataCnt     Count of writing
 * @param[in]   errStatus   Status of operation result
 * [url=home.php?mod=space&uid=784970]@return[/url] None
typedef  void (*CallbackHook)(void);
volatile uint32_t spi_transmit_ok;
CallbackHook    spi_cmpl_fn = NULL;
extern SPI_HandleTypeDef hspi1;
void HAL_SPI_ErrorCallback(SPI_HandleTypeDef *hspi)
    if(hspi->Instance == SPI1)
void HAL_SPI_TxCpltCallback(SPI_HandleTypeDef *hspi)
        spi_transmit_ok = 1;
        if(spi_cmpl_fn != NULL)    spi_cmpl_fn();
uint8_t spi_transmit_byte(void *spibus,uint8_t ch)
    uint8_t txbuf,rxbuf;
    txbuf = ch;
    rxbuf = 0xff;
    spi_transmit_ok = 0;
    spi_cmpl_fn = NULL;
    HAL_SPI_TransmitReceive(&hspi1,(void *)&txbuf, (void *)&rxbuf, 1, 10);
    return rxbuf;
uint8_t spi_transmit_buff(void *spibus,uint8_t * wbuf,uint8_t * rbuf,uint32_t len,void(* callback)(void))
    spi_cmpl_fn = callback;
    HAL_SPI_TransmitReceive_DMA(&hspi1,wbuf, rbuf, len);
    if(callback == NULL)
        while(!spi_transmit_ok);
    return 0;
void spi_write_read_buff(void *spibus,uint8_t * wbuf,uint32_t wl,uint8_t * rbuf,uint32_t rl)
    if((wbuf != NULL) && (wl != 0))
        spi_cmpl_fn = NULL;
        HAL_SPI_Transmit(&hspi1,wbuf, wl, 100);
    if((rbuf != NULL) && (rl != 0))
        memset(rbuf,0,rl);
        spi_cmpl_fn = NULL;
        HAL_SPI_Receive(&hspi1,rbuf, rl, 100);
#include <main.h>
// Choose a bus
//#define SSD1306_USE_I2C
#define SSD1306_USE_SPI
#ifdef  SSD1306_USE_I2C
#include "drv_i2c.h"
#define SSD1306_I2C_NUM         0
#define SSD1306_I2C_ADDR        (0x3C)
#endif
#ifdef  SSD1306_USE_SPI
#define SSD1306_SPI_NUM             0
#define SSD1306_RST_Set()           HAL_GPIO_WritePin(LCD_BLK_GPIO_Port,LCD_BLK_Pin,GPIO_PIN_SET)
#define SSD1306_RST_Reset()         HAL_GPIO_WritePin(LCD_BLK_GPIO_Port,LCD_BLK_Pin,GPIO_PIN_RESET)
#define SSD1306_DC_Set()            HAL_GPIO_WritePin(LCD_DC_GPIO_Port,LCD_DC_Pin,GPIO_PIN_SET)
#define SSD1306_DC_Reset()          HAL_GPIO_WritePin(LCD_DC_GPIO_Port,LCD_DC_Pin,GPIO_PIN_RESET)
#define SSD1306_SPI_CS_Set()        HAL_GPIO_WritePin(SPI_CS_GPIO_Port,SPI_CS_Pin,GPIO_PIN_SET)
#define SSD1306_SPI_CS_Reset()      HAL_GPIO_WritePin(SPI_CS_GPIO_Port,SPI_CS_Pin,GPIO_PIN_RESET)
#endif
#define ssd1306_mdelay(x)      delay_ms(x)
#if defined(SSD1306_USE_SPI)
void ssd1306_Reset(void)
    SSD1306_SPI_CS_Set();
    // Reset the OLED
    SSD1306_RST_Reset();
    ssd1306_mdelay(10);
    SSD1306_RST_Set();
    ssd1306_mdelay(10);
// Send a byte to the command register
void ssd1306_WriteCommand(uint8_t byte)
    SSD1306_SPI_CS_Reset(); // select OLED
    SSD1306_DC_Reset();     // command
    spi_transmit_byte(SSD1306_SPI_NUM, byte);
    SSD1306_SPI_CS_Set();   // un-select OLED
// Send data
void ssd1306_WriteData(uint8_t* buffer, size_t buff_size)
    SSD1306_DC_Set();     // command
    spi_write_read_buff(SSD1306_SPI_NUM, buffer, buff_size,NULL,0);
#else
#error "You should define SSD1306_USE_SPI or SSD1306_USE_I2C macro"
#endif
uint8_t SSD1306_Buffer[SSD1306_BUFFER_SIZE];
void ssd1306_SetContrast(const uint8_t value)
    const uint8_t kSetContrastControlRegister = 0x81;
    ssd1306_WriteCommand(kSetContrastControlRegister);
    ssd1306_WriteCommand(value);
uint32_t ssd1306_SetDisplayOn(uint8_t light)
    if (light)
        ssd1306_WriteCommand(0x8D); //--set DC-DC enable
        ssd1306_WriteCommand(0x14); //
        ssd1306_WriteCommand(0xAF);// Display on
    }else
        ssd1306_WriteCommand(0x10); //
        ssd1306_WriteCommand(0xAE);// Display off
    return 0;
// Initialize the oled screen
uint32_t ssd1306_Init(void *args)
#if defined(SSD1306_USE_I2C)
    I2C_BUS_DEV = I2C_FindDevice(I2C_NAME);
    if (I2C_BUS_DEV == NULL)
        return -1;
#endif
#endif
    // Reset OLED
    ssd1306_Reset();
    // Wait for the screen to boot
    ssd1306_mdelay(100);
    // Init OLED
    ssd1306_SetDisplayOn(0); //display off
    ssd1306_WriteCommand(0x20); //Set Memory Addressing Mode
    ssd1306_WriteCommand(0x00); // 00b,Horizontal Addressing Mode; 01b,Vertical Addressing Mode;
                                // 10b,Page Addressing Mode (RESET); 11b,Invalid
    ssd1306_WriteCommand(0xB0); //Set Page Start Address for Page Addressing Mode,0-7
#ifdef SSD1306_MIRROR_VERT
    ssd1306_WriteCommand(0xC0); // Mirror vertically
#else
    ssd1306_WriteCommand(0xC8); //Set COM Output Scan Direction
#endif
    ssd1306_WriteCommand(0x00); //---set low column address
    ssd1306_WriteCommand(0x10); //---set high column address
    ssd1306_WriteCommand(0x40); //--set start line address - CHECK
    ssd1306_SetContrast(0xFF);
#ifdef SSD1306_MIRROR_HORIZ
    ssd1306_WriteCommand(0xA0); // Mirror horizontally
#else
    ssd1306_WriteCommand(0xA1); //--set segment re-map 0 to 127 - CHECK
#endif
#ifdef SSD1306_INVERSE_COLOR
    ssd1306_WriteCommand(0xA7); //--set inverse color
#else
    ssd1306_WriteCommand(0xA6); //--set normal color
#endif
// Set multiplex ratio.
#if (SSD1306_HEIGHT == 128)
    // Found in the Luma Python lib for SH1106.
    ssd1306_WriteCommand(0xFF);
#else
    ssd1306_WriteCommand(0xA8); //--set multiplex ratio(1 to 64) - CHECK
#endif
#if (SSD1306_HEIGHT == 32)
    ssd1306_WriteCommand(0x1F); //
#elif (SSD1306_HEIGHT == 64)
    ssd1306_WriteCommand(0x3F); //
#elif (SSD1306_HEIGHT == 128)
    ssd1306_WriteCommand(0x3F); // Seems to work for 128px high displays too.
#else
#error "Only 32, 64, or 128 lines of height are supported!"
#endif
    ssd1306_WriteCommand(0xA4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
    ssd1306_WriteCommand(0xD3); //-set display offset - CHECK
    ssd1306_WriteCommand(0x00); //-not offset
    ssd1306_WriteCommand(0xD5); //--set display clock divide ratio/oscillator frequency
    ssd1306_WriteCommand(0xF0); //--set divide ratio
    ssd1306_WriteCommand(0xD9); //--set pre-charge period
    ssd1306_WriteCommand(0x22); //
    ssd1306_WriteCommand(0xDA); //--set com pins hardware configuration - CHECK
    ssd1306_WriteCommand(0x02);
    ssd1306_WriteCommand(0x12);
#else
#endif
    ssd1306_WriteCommand(0xDB); //--set vcomh
    ssd1306_WriteCommand(0x20); //0x20,0.77xVcc
    ssd1306_SetDisplayOn(1); //--turn on SSD1306 panel
    return 0;
整个工程如图:
image.png   下面是测试oled显示代码:
最终编译下载之后就可以看到oled显示字符。
这里顺便移植了一个qrcode显示。
 工程代码:
STM32U083_Demo.zip (9.31 MB)
(下载次数: 0, 昨天 22:38 上传)
回复评论
暂无评论,赶紧抢沙发吧
    写回复
