我的流驱动啊,老是出问题。DLL_THREAD_DETACH
nuanshuiping   2009-8-26 14:00 楼主
我的串口总是提示DLL_THREAD_DETACH如下:
MID = 0xec, DID = 0x76 4th Cycle : 0xa5
NUMBLOCKS : 512(0x200), SECTORSPERBLOCK = 256(0x100), BYTESPERSECTOR = 512(0x200)
STRINGS: **********DLL_PROCESS_ATTACH
STRFMD_OEMIoControl: unrecognized IOCTL (0x71c24).
INGS: **********STR_Init
Venus CIS_Init: context Drivers\Active\14
Virtual alloc/copy success :
CAMERA.DLL::InterruptThread Initialized.
Camera initialization completed successfully..
CAM_Init: ActivateDevice on Pin failed
BWSCON=0x22111120, BANKCON3=0x700, BANKCON4=0x700
BWSCON=0x22111120
[dm9: Tries to map io space with 18000000
[dm9: The mapped address is D0BF0000
[dm9: Chip signature is 90000A46
STRINGS: **********DLL_THREAD_DETACH
回复评论 (8)
这是我的入口函数。
#define BUFSIZE 256
WCHAR achBuffer[BUFSIZE];
BOOL WINAPI
DllEntryPoint(HANDLE hinstDLL,
              DWORD dwReason,
              LPVOID /* lpvReserved */)
    switch(dwReason)
    case DLL_PROCESS_ATTACH:
        g_hInstance = hinstDLL;
        RETAILMSG(1,(TEXT("STRINGS: **********DLL_PROCESS_ATTACH\n")));
        return TRUE;
    case DLL_THREAD_ATTACH:
        RETAILMSG(1,(TEXT("STRINGS: **********DLL_THREAD_ATTACH\n")));
        break;
    case DLL_THREAD_DETACH:
        RETAILMSG(1,(TEXT("STRINGS: **********DLL_THREAD_DETACH\n")));
        break;
    case DLL_PROCESS_DETACH:
        RETAILMSG(1,(TEXT("STRINGS: **********DLL_PROCESS_DETACH\n")));
        break;
#ifdef UNDER_CE
    case DLL_PROCESS_EXITING:
        RETAILMSG(1,(TEXT("STRINGS: **********DLL_PROCESS_EXITING\n")));
        break;
    case DLL_SYSTEM_STARTED:
        RETAILMSG(1,(TEXT("STRINGS: **********DLL_SYSTEM_STARTED\n")));
        break;
#endif
    return TRUE;
点赞  2009-8-26 14:01
DWORD STR_Init(DWORD dwContext)
    DWORD dwRet = 0;
    RETAILMSG(1,(TEXT("STRINGS: **********STR_Init\n")));
    // Initialize buffer to zero.
    memset (achBuffer, 0, BUFSIZE * sizeof(WCHAR));
    // Set return value to non-zero.
    dwRet = 1;
    return dwRet;
点赞  2009-8-26 14:01
一个驱动可不仅仅是初始化呀!楼主,建议你好好研究一下流驱动的架构。你的驱动连线程都没有创建,肯定会一直报DETACH的。
点赞  2009-8-26 14:56
5楼 afg
我其他的函数也写了,不过即使createfile函数移植返回INVALID_HANDLE_VALUE所以贴上了init函数,
返回INVALID_HANDLE_VALUE函数跟是否创建线程有关吗?
点赞  2009-8-26 15:18
不是所有的流驱动都需要ist吧,我的驱动不需要中断,只是创建一个内存空间,存储书写,读出数据。
点赞  2009-8-26 15:30
引用: 引用 4 楼 jiereliyi 的回复:
xxx_write()   xxx_open()    xxx_iocontrol()等等函数你都实现了吗?你的createfile很明显没成功啊。
点赞  2009-8-26 17:34
我找到原因了,漏掉了一个‘:’号。creatfile(“XXX:”):漏掉了
点赞  2009-8-27 12:06
谢谢帮忙 ,分给你了。呵呵
点赞  2009-8-27 12:07
    写回复
