wince下加载3M触摸屏驱动?
Nechi   2008-11-6 12:59 楼主
厂家有提供驱动下载,但不是CAB文件.是EXE的
厂家也提供说明文档.由于初学.还看不太懂.头很大啊
INSTALLATION INSTRUCTIONS
* Using Windows Explorer, browse to the software distribution and
  double-click on the Setup program to start the installation. If you
  downloaded the distribution, unzip the file into another directory.
* The Installer requires that Platform Builder be installed in your
  Windows 2000 or XP machine.  The Installer puts the driver and any
  tools selected by user into the proper Platform Builder directories.
* Follow the instructions given by the Setup program.  First you will
  be asked to browse to a directory in your Platform Builder
  installation. Normally a platform directory will look like this:
    C:\WINCE###\PLATFORM\CEPC\FILES
  or a specific project directory, such as this:
    C:\WINCE###\PUBLIC\MyProject\WINCE###\CEPC\OAKS\FILES
* The Installer places most its files in a central directory called
  "C:\MT7_CE\x86". This allows multiple Platform Builder platforms and
  projects to access the same files.
* The Installer attempts to change the Platform.bib and Platform.reg,
  or Project.bib and Project.reg, files in a Platform Builder system.
  The changes are "#include" directives that add MT 7 components to
  your target system.
* With the Installer you may choose to customize your installation.
  This allows you to select which components to install. The following
  components are selectable.
  - The Touch Screen Driver is mandatory to operate the touch screen.
  - The Calibration Tool is recommended.
  - The Control Panel includes calibration support and is recommended
    if additional settings are needed.
  - The Touch Monitor Tool is required for features such as the right-
    click tool and the virtual mouse.
* The Installer produces a file, TwTouch.bib, that reflects the
  components you selected.
* For the touch screen driver to work, you must include USB support
  in your Windows CE image, regardless of the type of touch screen you
  use.
INSTRUCTIONS FOR PLATFORM BUILDER FOR MICROSOFT WINDOWS CE 4.0
As installed, MT 7 should operate under the Platform Builder for
Windows CE 4.1 and above without any user changes.
The MT 7 Installer places an "#include" directive in Platform.reg and
Platform.bib to include the files TwTouch.reg and TwTouch.bib. In
Platform Builder 4.0 this directive does not work. Therefore you need
to replace this "#include" directive with the contents of the MT 7
files.
Edit Platform.bib and locate the include directive for TwTouch.bib.
Open TwTouch.bib in another editor, copy its contents to the clipboard
and paste the clipboard into Platform.bib, replacing the include
directive. Save Platform.bib.
Repeat the editing with Platform.reg, replacing the include directive
with the contents of TwTouch.reg.
If you installed MT 7 into a project instead of a platform, the files
you need to edit are Project.bib and Project.reg.
回复评论 (1)
零分帖,路过一下
点赞  2008-11-6 21:43
    写回复
