1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 | /******************************************** Chip type : AT90S4434 Clock frequency : 8,000000 MHz Memory model : Tiny Internal SRAM size : 256 External SRAM size : 0 Data Stack size : 64 *********************************************/ #include <90s4434.h> #include "kb.h" #include // Alphanumeric LCD Module functions #asm .equ __lcd_port=0x15 #endasm #include // Declare your global variables here void main(void) { // Declare your local variables here unsigned char key; // Input/Output Ports initialization // Port A PORTA=0x00; DDRA=0x00; // Port B PORTB=0x00; DDRB=0x00; // Port C PORTC=0x00; DDRC=0x00; // Port D PORTD=0x00; DDRD=0x00; // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Output Compare // OC0 output: Disconnected TCCR0=0x00; TCNT0=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer 1 Stopped // Mode: Output Compare // OC1A output: Discon. // OC1B output: Discon. // Noise Canceler: Off // Input Capture on Falling Edge TCCR1A=0x00; TCCR1B=0x00; TCNT1H=0x00; TCNT1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer/Counter 2 initialization // Clock source: System Clock // Clock value: Timer 2 Stopped // Mode: Output Compare // OC2 output: Disconnected TCCR2=0x00; ASSR=0x00; TCNT2=0x00; OCR2=0x00; // External Interrupt(s) initialization // INT0: Oon // INT1: Off GIMSK= 0x40; // Enable INT0 interrupt MCUCR=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off ACSR=0x80; // LCD module initialization //lcd_init(20); // Init 20 Zeichendisplay lcd_init(16); // Init 16 Zeichendisplay InitKeyBoard(); // Initialize keyboard reception while(1) { key = getchar_kb(); lcd_putchar(key); delay_ms(5); } } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 | /***************************** ** low level kexboard routines VERSION 1.0 ******************************/ #include "kb.h" #include "scancodes.h" #define BUFF_SIZE 64 unsigned char edge, bitcount; // 0 = neg. 1 = pos. unsigned char kb_buffer[BUFF_SIZE]; unsigned char *inpt, *outpt; unsigned char buffcnt; void InitKeyBoard(void) { inpt = kb_buffer; // Initialize buffer outpt = kb_buffer; buffcnt = 0; MCUCR = 2; // INT0 interrupt on falling edge edge = 0; // 0 = falling edge 1 = rising edge bitcount = 11; #asm("sei") // interrupt enable } interrupt [EXT_INT0] void INT0_interrupt(void) { static unsigned char data; // Holds the received scan code if(bitcount < 11 && bitcount > 2) // Bit 3 to 10 is data. Parity bit, { // start and stop bits are ignored. data = (data >> 1); if(PIND & 8) data = data | 0x80; // Store a '1' } if(--bitcount == 0) // All bits received { decode(data); bitcount = 11; } } void decode(unsigned char sc) { static unsigned char is_up=0, shift = 0, mode = 0; unsigned char i; if (!is_up) // Last data received was the up-key identifier { switch (sc) { case 0xF0 : // The up-key identifier is_up = 1; break; case 0x12 : // Left SHIFT shift = 1; break; case 0x59 : // Right SHIFT shift = 1; break; case 0x05 : // F1 if(mode == 0) mode = 1; // Enter scan code mode if(mode == 2) mode = 3; // Leave scan code mode break; default: if(mode == 0 || mode == 3) // If ASCII mode { if(!shift) // If shift not pressed, { // do a table look-up for(i = 0; unshifted[0]!=sc && unshifted[0]; i++); if (unshifted[0] == sc) { put_kbbuff(unshifted[1]); } } else { // If shift pressed for(i = 0; shifted[0]!=sc && shifted[0]; i++); if (shifted[0] == sc) { put_kbbuff(shifted[1]); } } } else{ // Scan code mode print_hexbyte(sc); // Print scan code put_kbbuff(' '); } break; } } else { is_up = 0; // Two 0xF0 in a row not allowed switch (sc) { case 0x12 : // Left SHIFT shift = 0; break; case 0x59 : // Right SHIFT shift = 0; break; case 0x05 : // F1 if(mode == 1) mode = 2; if(mode == 3) mode = 0; break; case 0x06 : // F2 // clr(); break; } } } void put_kbbuff(unsigned char c) { if (buffcnt *inpt = c; // Put character into buffer inpt++; // Increment pointer buffcnt++; if (inpt >= kb_buffer + BUFF_SIZE) // Pointer wrapping inpt = kb_buffer; } } int getchar_kb(void) { int byte; while(buffcnt == 0); // Wait for data byte = *outpt; // Get byte outpt++; // Increment pointer if (outpt >= kb_buffer + BUFF_SIZE) // Pointer wrapping outpt = kb_buffer; buffcnt--; // Decrement buffer count return byte; } void print_hexbyte(unsigned char i) { unsigned char h, l; h = i & 0xF0; // High nibble h = h>>4; h = h + '0'; if (h > '9') h = h + 7; l = (i & 0x0F)+'0'; // Low nibble if (l > '9') l = l + 7; put_kbbuff(h); put_kbbuff(l); } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 | // Keyboard communication routines #ifndef __KB_INCLUDED #define __KB_INCLUDED #include <90s4434.h> #define CLOCK 2 #define DATAPIN 3 #define ISC00 0 #define ISC01 1 void InitKeyBoard(void); interrupt [EXT_INT0] void INT0_interrupt(void); void decode(unsigned char sc); void put_kbbuff(unsigned char c); int getchar_kb(void); void print_hexbyte(unsigned char i); #endif |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 | // Unshifted characters flash unsigned char unshifted[68][2] = { 0x0d,9, 0x0e,'|', 0x15,'q', 0x16,'1', 0x1a,'z', 0x1b,'s', 0x1c,'a', 0x1d,'w', 0x1e,'2', 0x21,'c', 0x22,'x', 0x23,'d', 0x24,'e', 0x25,'4', 0x26,'3', 0x29,' ', 0x2a,'v', 0x2b,'f', 0x2c,'t', 0x2d,'r', 0x2e,'5', 0x31,'n', 0x32,'b', 0x33,'h', 0x34,'g', 0x35,'y', 0x36,'6', 0x39,',', 0x3a,'m', 0x3b,'j', 0x3c,'u', 0x3d,'7', 0x3e,'8', 0x41,',', 0x42,'k', 0x43,'i', 0x44,'o', 0x45,'0', 0x46,'9', 0x49,'.', 0x4a,'-', 0x4b,'l', 0x4c,'?, 0x4d,'p', 0x4e,'+', 0x52,'?, 0x54,'?, 0x55,'\\', 0x5a,13, 0x5b,'?, 0x5d,'\\', 0x61,'<', 0x66,8, 0x69,'1', 0x6b,'4', 0x6c,'7', 0x70,'0', 0x71,',', 0x72,'2', 0x73,'5', 0x74,'6', 0x75,'8', 0x79,'+', 0x7a,'3', 0x7b,'-', 0x7c,'*', 0x7d,'9', 0,0 }; // Shifted characters flash unsigned char shifted[68][2] = { 0x0d,9, 0x0e,'?, 0x15,'Q', 0x16,'!', 0x1a,'Z', 0x1b,'S', 0x1c,'A', 0x1d,'W', 0x1e,'"', 0x21,'C', 0x22,'X', 0x23,'D', 0x24,'E', 0x25,'?, 0x26,'#', 0x29,' ', 0x2a,'V', 0x2b,'F', 0x2c,'T', 0x2d,'R', 0x2e,'%', 0x31,'N', 0x32,'B', 0x33,'H', 0x34,'G', 0x35,'Y', 0x36,'&', 0x39,'L', 0x3a,'M', 0x3b,'J', 0x3c,'U', 0x3d,'/', 0x3e,'(', 0x41,';', 0x42,'K', 0x43,'I', 0x44,'O', 0x45,'=', 0x46,')', 0x49,':', 0x4a,'_', 0x4b,'L', 0x4c,'?, 0x4d,'P', 0x4e,'?', 0x52,'?, 0x54,'?, 0x55,'`', 0x5a,13, 0x5b,'^', 0x5d,'*', 0x61,'>', 0x66,8, 0x69,'1', 0x6b,'4', 0x6c,'7', 0x70,'0', 0x71,',', 0x72,'2', 0x73,'5', 0x74,'6', 0x75,'8', 0x79,'+', 0x7a,'3', 0x7b,'-', 0x7c,'*', 0x7d,'9', 0,0 }; |
