请教2个函数
jgalz   2008-9-1 09:21 楼主
1、我定义char a[10];
         int i =0;
可以用        _snprintf(a, 10, "%d", i);
但使用RtlStringCchPrintfW(a, 10, "%d", i)时出错
2、我定义BK_CMD_T tAtCmd;
        AT_CMGD_SET_CMD_PARA_T  reqPara;
typedef struct _BK_CMD_T
        BK_CMD_PROTOCOL_T        cmdProt;
        unsigned char       TargetModuleID;
        unsigned char       SourceModuleID;
        unsigned short      CmdID;
        unsigned char       CmdType;
        unsigned char       Reserved[3];
        unsigned short      ParaLen;
        void                *Handle;
        void                *pData;
        unsigned char       Paras[BK_CMD_PARA_MAX_LEN];
} BK_CMD_T;
typedef struct _AT_CMGD_SET_CMD_PARA_T
        int index;
        int delflag;
} AT_CMGD_SET_CMD_PARA_T;
使用memcpy(tAtCmd.Paras, &reqPara, sizeof(AT_CMGD_SET_CMD_PARA_T))可以
但使用RtlCopyMemory(tAtCmd.Paras, &reqPara, sizeof(AT_CMGD_SET_CMD_PARA_T))时出错
回复评论
暂无评论,赶紧抢沙发吧
    写回复
