一个文件读取的问题?
我是特种兵   2007-6-21 09:38 楼主
我在VC下写        char szDrive[256]={0};
        char szDir[256]={0};
        char szPath[256]={0};
        _splitpath(szFileName,szDrive,szDir,NULL,NULL);
        GetPrivateProfileString("robot1", "a3", "1",str,256,filepath);
可以用,但在CE下就不行,没_splitpath和GetPrivateProfileString函数,怎么办那?
回复评论 (6)
呵呵 自己写呀 后者我这里有现成的 给你帖出来
CString PGlobal::GetProfileString(const CString strSection, const CString strEntry,
        const CString strDefault, DWORD nSize, const CString strIniPath)
        if(strIniPath == L"" || strSection == L"" || strEntry == L"")
                return strDefault;
        CFile IniFile;
        CString strCombine;
//        TRY
                // open target ini file.
                if(! IniFile.Open(strIniPath, CFile::modeRead))
                        return strDefault;
                // if the file is no data inside, return error.
                if(IniFile.GetLength() == 0)
                        IniFile.Close();
                        return strDefault;
                // read the string data for later use.
                WCHAR *pBuf;
                //the file is unicode, so data length must be twice size of that.
                pBuf = new WCHAR[IniFile.GetLength() / 2 + 1];
                if(pBuf == NULL)
                        IniFile.Close();
                        return strDefault;
                if(IniFile.Read(pBuf, IniFile.GetLength()) != IniFile.GetLength())
                        delete[] pBuf;
                        IniFile.Close();
                        return strDefault;
                pBuf[IniFile.GetLength() / 2] = NULL;
                strCombine.GetBuffer(nSize); //create a big buffer.
                strCombine = pBuf;
                delete[] pBuf;
                //see if the section, entry already exist.
                int iIndex1, iIndex2, iIndex3, iIndexT;
                iIndex1 = strCombine.Find(L"[" + strSection + L"]\r\n");
                if(iIndex1 == -1) // not found section
                        IniFile.Close();
                        return strDefault;
                iIndexT = iIndex1 + 4 + strSection.GetLength();
                iIndex2 = strCombine.Find(strEntry + L"=", iIndexT);
                if(iIndex2 == -1) // not found entry
                        IniFile.Close();
                        return strDefault;
                else
                        //to find the entry key
                        iIndex3 = strCombine.Find(L"\r\n", iIndex2 + 1);
                        if(iIndex3 == -1)
                                IniFile.Close();
                                return strDefault;
                        // if find the entry key,
                        iIndexT = iIndex2 + 1 + strEntry.GetLength();
                        IniFile.Close();
                        //get the string between "enter key" and end of the string being searched before.
                        return strCombine.Mid(iIndexT, iIndex3 - iIndexT);
//        CATCH(CFileException, e)
//        END_CATCH //
        IniFile.Close();
        return strDefault;
点赞  2007-6-21 10:35
只能自己写了啊,后者有现成的,帖给你,呵呵
                return strDefault;
        CFile IniFile;
        CString strCombine;
//        TRY
                        return strDefault;
                        IniFile.Close();
                        return strDefault;
                WCHAR *pBuf;
                if(pBuf == NULL)
                        IniFile.Close();
                        return strDefault;
                        delete[] pBuf;
                        IniFile.Close();
                        return strDefault;
                strCombine = pBuf;
                delete[] pBuf;
                        IniFile.Close();
                        return strDefault;
                        IniFile.Close();
                        return strDefault;
                else
                        if(iIndex3 == -1)
                                IniFile.Close();
                                return strDefault;
                        IniFile.Close();
//        END_CATCH //
        IniFile.Close();
        return strDefault;
点赞  2007-6-21 10:36
无语ing........ 这垃圾网络....... 帖多了 别拍我砖头.... @_@
点赞  2007-6-21 10:37
举个例子好吗比方我想读取 CF卡上 config.ini 里的AAA=20的AAA 的值怎么写那?
点赞  2007-6-21 11:00
[TEST]
AAA=20
第一个参数是Section, 就是[TEST]这个,第二个是入口点AAA,最后一个是文件名,成功则返回20,失败则返回"".
strValue = GetProfileString(_T("TEST"), _T("AAA"),  _T(""), _MAX_PATH, L"config.ini ");
点赞  2007-6-21 11:29
mark
点赞  2008-11-15 10:38
    写回复
