请教WinCE的打印问题
tulao   2007-7-6 14:32 楼主
我用VB.net2005开发WinCE程序,我想调用WinCE系统的打印对话框,请问该怎么写才能调用打印对话框?
回复评论 (10)
用MFC比较好
点赞  2007-7-6 23:20
客户的要求就是用vb.net2005
哪位大侠帮帮忙,在下不胜感激~
点赞  2007-7-9 09:45
请高手帮忙!~~
我补充一下问题:
  我在WinCE的机器上放了一个print.dll的文件(客户给的),然后打开一个文本文件,
  选择[文件]->[打印],就弹出一个打印设置的对话框,按“OK”就可以打印了。
  但现在的问题是需要用vb.net实现这一功能,即是弹出打印设置的对话框。
  谢谢大家了,帮帮忙!
点赞  2007-7-9 11:14
怎麽都沒有人幫我啊?
点赞  2007-7-12 09:11
WINCE下的打印驱动简单完美解决方案
打印很简单4句话就搞定
CDC* pDC = GetDC();
CPRINTSTATUS CPS;
CPS.PrintImage(pDC->m_hDC,0,0,400,300);
ReleaseDC(pDC);
你可以看看blog.eeworld.net/tayosoft
点赞  2007-7-12 10:40
tayosoft 你好,请问在你的Blog上是哪篇文章?有些都打不开,我没有开到你说的四句话。
CDC* pDC = GetDC();
CPRINTSTATUS CPS;
ReleaseDC(pDC);
这个怎么实现,能说得具体点吗?我用的是VB.NET
点赞  2007-7-12 11:14
http://blog.eeworld.net/tayosoft  或则 QQ:19679646 VB.NET 用托管就可以了。我的可以支持C#的。
点赞  2007-7-12 11:22
class CEPRINT
        public struct DEFAULT
            static public short DMORIENT_PORTRAIT = 1;
            static public short DMORIENT_LANDSCAPE = 2;
            static public short DMPAPER_LETTER = 1;
            static public short DMPAPER_LEGAL = 5;
            static public short DMPAPER_A4 = 9;
            static public short DMPAPER_B4 = 12;
            static public short DMPAPER_B5 = 13;
            static public short DMRES_DRAFT = -1;
            static public short DMRES_HIGH = -4;
            static public short DMCOLOR_MONOCHROME = 1;
            static public short DMCOLOR_COLOR = 2;
        /// 首先必须调用这个函数后其它的函数才有效。否则出错
        [DllImport("CEPRINT.DLL", EntryPoint = "CE_ShowPrintDialog")]
        public static extern bool ShowPrintDialog();
                [DllImport("CEPRINT.DLL", EntryPoint = "CE_StartPrint")]
                public static extern bool StartPrint();
                [DllImport("CEPRINT.DLL", EntryPoint = "CE_StopPrint")]
                public static extern bool StopPrint();
                [DllImport("CEPRINT.DLL", EntryPoint = "CE_ExitPrint")]
                public static extern bool ExitPrint();
        [DllImport("CEPRINT.DLL", EntryPoint = "CE_PrintImage")]
        public static extern bool PrintImage(IntPtr hdc, UInt32 nStartX, UInt32 nStartY, UInt32 nWidth, UInt32 nHeight);
        [DllImport("CEPRINT.DLL", EntryPoint = "CE_GetPrintName")]
        public static extern bool GetPrintName(StringBuilder strPrintBuffer, int size);
        [DllImport("CEPRINT.DLL", EntryPoint = "CE_GetPortName")]
        public static extern string GetPortName(StringBuilder strPortBuffer, int size);
        [DllImport("CEPRINT.DLL", EntryPoint = "CE_GetOrientation")]
        public static extern short GetOrientation();
        [DllImport("CEPRINT.DLL", EntryPoint = "CE_GetPapersize")]
        public static extern short GetPapersize();
        [DllImport("CEPRINT.DLL", EntryPoint = "CE_GetPrintQuality")]
        public static extern short GetPrintQuality();
        [DllImport("CEPRINT.DLL", EntryPoint = "CE_GetColor")]
        public static extern short GetColor();
点赞  2007-7-12 11:23
什么叫托管,我还是不会用,我不懂c#啊。
点赞  2007-7-12 17:20
你可以把C#转换成VB.NET 都一样的。2005可以自动转换的。
点赞  2007-7-13 09:08
    写回复
