Modelsim SE后仿真问题请教
eeleader   2010-8-18 17:58 楼主
用Modelsim SE做PCI接口的后仿真,步骤是这样的,先在Modelsim根目录下新建文件夹test,将接口模块(顶层模块pci_top),和测试模块(顶层模块为pci_tb)放入其中,然后在Quartus下将这2个模块放入工程中,编译后在 test目录下出现新建的simulation\modelsim目录,里面有3个文件: pci_top.vo, pci_top_modelsim.xrf, pci_top_v.sdo,完了打开Modelsim SE建工程,将接口模块、测试模块、库文件都放入,编译通过。然后启动仿真器,在SDF选项卡处将pci_top_v.sdo加进去,Apply to Region处写的是/pci_tb/pci_tb,开始仿真后老是提示 ** Error: (vsim-SDF-3250) C:/Modeltech_6.0/test/simulation/modelsim/pci_top_v.sdo(0): Failed to find INSTANCE '/test/pci_tb'.个人感觉应该是Apply to Region处出错.
补充:重新建个文件夹jiayou,将上面的步骤进行一遍后出现下面的错误提示:
# Loading C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo
# ** Error: (vsim-SDF-3250) C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo(35): Failed to find INSTANCE '/pci_tb/pci_ad[0]~I/inst1'.
# ** Error: (vsim-SDF-3250) C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo(49): Failed to find INSTANCE '/pci_tb/pci_ad[1]~I/inst1'.
# ** Error: (vsim-SDF-3250) C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo(63): Failed to find INSTANCE '/pci_tb/pci_ad[2]~I/inst1'.
# ** Error: (vsim-SDF-3250) C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo(77): Failed to find INSTANCE '/pci_tb/pci_ad[3]~I/inst1'.
# ** Error: (vsim-SDF-3250) C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo(91): Failed to find INSTANCE '/pci_tb/pci_ad[4]~I/inst1'.
# ** Warning: (vsim-SDF-3432) C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo: This file is probably applied to the wrong instance.
# Ignoring subsequent missing instances from this file.
# ** Warning: (vsim-SDF-3440) C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo: Failed to find any of the 569 instances from this file.
# ** Warning: (vsim-SDF-3442) C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo: Try instance '/pci_tb/P_CLK'. It contains all instance paths from this file.
# ** Error: (vsim-SDF-3445) Failed to parse SDF file "C:/Modeltech_6.0/jiayou/simulation/modelsim/pci_top_v.sdo".
#    Time: 0 ps  Iteration: 0  Region: /pci_tb  File: C:/Modeltech_6.0/jiayou/pci_tb.v
# Error loading design
一个为理想不懈前进的人,一个永不言败人! http://shop57496282.taobao.com/ 欢迎光临网上店铺!
回复评论 (1)
我也遇到这样的问题,总觉得是sdo文件有问题,但是又不知道问题出在哪里
点赞  2012-10-26 20:19
    写回复
