上传程序和电路,大家自看看吧,LCD是通过TIM2做刷新的。
外行看热闹,内行看门道。呵,反正我还没怎么看懂。
void TIM2_IRQHandler(void)
GPIO_InitTypeDef GPIO_InitStructure;
static u16 Seg_Old;
if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
if (var == 0) /* OCMP_1 */
var++;
/* Segments(lcdcr) to be turned on are loaded with the value 1 otherwise 0 */
Seg_Old = frame[lcdcr];
GPIO_Write(GPIOE,Seg_Old);
/* com(lcdcr) is set to low, other coms set to Vdd/2 */
/* Configure all coms as Floating Input */
GPIO_InitStructure.GPIO_Pin = COMPORT;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* com(lcdr) is set to low PP */
GPIO_ResetBits(GPIOC,com[lcdcr]);
GPIO_InitStructure.GPIO_Pin = com[lcdcr];
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
else /* OCMP_2 */
var = 0;
/* Segments(lcdcr) values are inverted */
Seg_Old = (u16)(~Seg_Old);
/* com(lcdcr) is set to high, other coms set to Vdd/2 */
/* com(lcdr) is set to high PP */
GPIO_SetBits(GPIOC,com[lcdcr]);
lcdcr++;
if (lcdcr>3) lcdcr =0;
else if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
/* All seg and coms off to decrease VRMS */
GPIO_Write(GPIOE,0); /* Clear segments on portE */
GPIO_ResetBits(GPIOC,COMPORT); /* Clear segments on portC */
/* Configure all coms as PP_output */
