晕倒,这么个问题实在没着了。
不好意思,我咨询的是WDG不能产生复位
用例程能进入中断,但是无论禁止中断还是
在中断中不更新初值
都不能产生控制器的复位!!
我没有在DEBUG状态。
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V2.0.1
* Date : 06/13/2008
* Description : Main program body.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
#include "platform_config.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Configuration(void);
void Delay(vu32 nCount);
/* Private functions ---------------------------------------------------------*/
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
int main(void)
#ifdef DEBUG
debug();
#endif
/* System Clocks Configuration */
RCC_Configuration();
/* GPIO configuration */
GPIO_Configuration();
/* Check if the system has resumed from WWDG reset */
if (RCC_GetFlagStatus(RCC_FLAG_WWDGRST) != RESET)
{ /* WWDGRST flag set */
/* Set GPIO_LED pin 6 */
GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8); //LED ON
/* Clear reset flags */
RCC_ClearFlag();
else
{ /* WWDGRST flag is not set */
/* Reset GPIO_LED pin 6 */
GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8); //LED OFF
/* NVIC configuration */
NVIC_Configuration();
Delay(700000);
Delay(700000);
Delay(700000);
Delay(700000);
/* WWDG configuration */
/* Enable WWDG clock */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);
/* WWDG clock counter = (PCLK1/4096)/8 = 244 Hz (~4 ms) */
WWDG_SetPrescaler(WWDG_Prescaler_8);
/* Set Window value to 65 */
WWDG_SetWindowValue(65);
/* Enable WWDG and set counter value to 127, WWDG timeout = ~4 ms * 64 = 262 ms */
WWDG_Enable(127);
/* Clear EWI flag */
WWDG_ClearFlag();
/* Enable EW interrupt */
WWDG_EnableIT(); //注释这里不能造成STM32复位
while (1)
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if (HSEStartUpStatus == SUCCESS)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Flash 0 wait state */
FLASH_SetLatency(FLASH_Latency_0);
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK */
RCC_PCLK1Config(RCC_HCLK_Div1);
/* Select HSE as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
/* Wait till HSE is used as system clock source */
while (RCC_GetSYSCLKSource() != 0x04)
/* GPIOA, GPIOB and SPI1 clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
RCC_APB2Periph_SPI1, ENABLE);
* Function Name : GPIO_Configuration
* Description : Configures the different GPIO ports.
* Input : None
* Output : None
* Return : None
GPIO_InitTypeDef GPIO_InitStructure;
/*led*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
* Function Name : NVIC_Configuration
* Description : Configures NVIC and Vector Table base location.
* Input : None
* Output : None
* Return : None
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* 2 bits for Preemption Priority and 2 bits for Sub Priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = WWDG_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
* Function Name : Delay
* Description : Inserts a delay time.
* Input : nCount: specifies the delay time length.
* Output : None
* Return : None
for (; nCount != 0; nCount--);
#ifdef DEBUG
* Function Name : assert_failed
* Description : Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* Input : - file: pointer to the source file name
* - line: assert_param error line source number
* Output : None
* Return : None
void assert_failed(u8* file, u32 line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d
", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
* Function Name : WWDG_IRQHandler
* Description : This function handles WWDG interrupt request.
* Input : None
* Output : None
* Return : None
void WWDG_IRQHandler(void)
/* Update WWDG counter */
WWDG_SetCounter(0x7F); //注释这里不能造成STM32复位!!!!
WWDG_ClearFlag();
请问你用的什么硬件?如何判断没有复位
通过程序看到好像在检测到WWDG复位时,会点亮2个LED,但很快又关上了,有可能因为速度太快,你根本没有看见他们被点亮。
LED的闪动
通过这个:
Delay(700000);
Delay(700000);
Delay(700000);
Delay(700000);
请在检测到WWDG复位时,打开LED后作个延迟
否则你还没有看到他们亮,程序就到了5楼的部分,LED又被关闭!
气死我了,是这个玩意儿在捣鬼
使用 ST LINKII 的USB供电不行!!断开后单独供电,好了。
太郁闷了,实在想不到会是这里。
总算好了,多谢香主帮助。
我是不在DEBUG状态,IAR都退出了!
只能说ST-JLINK 影响了芯片的工作,由他供电不行。
