最近版主主去哪里了
mfg875   2010-10-14 17:28 楼主
                                 如题
回复评论 (10)
                                 突尼斯和法国
点赞  2010-10-14 17:57
                                 估计出差去了
点赞  2010-10-14 18:57
那你用STM32做过对外部脉冲计数吗?或者哪里看过,我自己也做了,可是怎么都不对
点赞  2010-10-14 20:31
                                 我正在去月球的路上,有什么可以效劳的?
点赞  2010-10-14 20:52
                                 搭载的可是传说中的嫦娥2号
点赞  2010-10-14 22:49
搭载的可是传说中的嫦娥2号
点赞  2010-10-15 05:01
                                 就算赶上了也还没到
点赞  2010-10-15 06:52
人民可把你盼回来了
点赞  2010-10-15 08:25
我之前看过你博客里面写到的关于运用STM32对外部脉冲计数的例程
我学习了下并实际操作了一下,根据自己实际情况稍微改了一点
程序如下:
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_ICInitTypeDef  TIM_ICInitStructure;
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
int count_out[3000];
int     i,j;
/* Private functions ---------------------------------------------------------*/
* Function Name  : Delay
* Description    : Inserts a delay time.
* Input          : nCount: specifies the delay time length.
* Output         : None
* Return         : None
* Function Name  : main
* Description    : Main program
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
RCC_Configuration(); // System Clocks Configuration
NVIC_Configuration(); // NVIC configuration
GPIO_Configuration(); // Configure the GPIO ports
TIM_TimeBaseStructure.TIM_Period = 0x0400;
TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); // Time base configuration
TIM_ETRClockMode2Config(TIM2, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);
TIM_SetCounter(TIM2, 0);
TIM_Cmd(TIM2, ENABLE);
for(i=0;i<3000;i++)
    count_out=TIM_GetCounter(TIM2);
    Delay(100);
TIM_Cmd(TIM2, DISABLE);
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input   : None
* Output  : None
* Return  : None
RCC_DeInit();            /* RCC system reset(for debug purpose) */
RCC_HSEConfig(RCC_HSE_ON);         /* Enable HSE */
HSEStartUpStatus = RCC_WaitForHSEStartUp();     /* Wait till HSE is ready */
if(HSEStartUpStatus == SUCCESS) {
  FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); /* Enable Prefetch Buffer */
  FLASH_SetLatency(FLASH_Latency_2);      /* Flash 2 wait state */
  RCC_HCLKConfig(RCC_SYSCLK_Div1);      /* HCLK = SYSCLK */
  RCC_PCLK2Config(RCC_HCLK_Div1);       /* PCLK2 = HCLK */
  RCC_PCLK1Config(RCC_HCLK_Div2);       /* PCLK1 = HCLK/2 */
  RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); /* PLLCLK = 8MHz * 9 = 72 MHz */
  RCC_PLLCmd(ENABLE);          /* Enable PLL */
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) {} /* Wait till PLL is ready */
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);    /* Select PLL as system clock source */
  while(RCC_GetSYSCLKSource() != 0x08) {}     /* Wait till PLL is used as system clock source */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);  /* TIM2 clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE); /* GPIOA、C clock enable */
* Function Name  : GPIO_Configuration
* Description : Configure the GPIOD Pins.
* Input    : None
* Output   : None
* Return   : None
  GPIO_InitTypeDef GPIO_InitStructure;
  /* GPIOA Configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //50M时钟速度
  GPIO_Init(GPIOA, &GPIO_InitStructure);
for(; nCount != 0; nCount--);
* Function Name  : NVIC_Configuration
* Description : Configure the nested vectored interrupt controller.
* Input    : None
* Output   : None
* Return   : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
#ifdef  DEBUG
* Function Name  : assert_failed
* Description : Reports the name of the source file and the source line number
*      where the assert_param error has occurred.
* Input    : - file: pointer to the source file name
*      - line: assert_param error line source number
* Output   : None
* Return   : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
  ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  while (1)
#endif
不知道哪里设置不对还是怎么的,n的值一直变化,就算没有外接脉冲信号也是
您能帮我看下吗
点赞  2010-10-15 08:27
点赞  2010-10-15 09:16
    写回复
