C6416EMIFA的CE0空间接了一片32bit的SDRAM,C6416的高32bit悬空不用,在对SDRAM进行写操作时,对一个地址操作会同时影响与其相邻16byte的地址空间,如对0x8000 0000写数据时,0x8000 0000和0x8000 0010的数据都会改变,同时对0x8000 0010操作也会改变0x8000 0000的数据,请问这是怎么一回事啊??
我仔细查了下硬件,数据线、地址线都没有问题,数据类型定义为Unsigned int。而且如果用16bit的SDRAM,数据类型相应的改为Unsigned short时,此时相互影响的为每相隔8Byte的地址,如写数据到0x8000 0000,会使0x8000 0008内数据改变,反之也是。如果用8bit的SDRAM,相互影响的是0x8000 0000和0x8000 0004。这个是否与字节对齐有关?
怀疑是EMIFA的配置问题,
EMIFA的配置为:
static EMIFA_Config MyEmifaConfig =
EMIFA_GBLCTL_RMK
EMIFA_GBLCTL_EK2RATE_FULLCLK,
EMIFA_GBLCTL_EK2HZ_CLK,
EMIFA_GBLCTL_EK2EN_ENABLE,
EMIFA_GBLCTL_BRMODE_MRSTATUS,
EMIFA_GBLCTL_NOHOLD_DISABLE,
EMIFA_GBLCTL_EK1HZ_CLK,
EMIFA_GBLCTL_EK1EN_ENABLE,
EMIFA_GBLCTL_CLK4EN_ENABLE,
EMIFA_GBLCTL_CLK6EN_ENABLE
0xffffff33, //32BIT SDRAM
0xffffff13,
0xffffff13,
0xffffff13,
EMIFA_SDCTL_RMK
EMIFA_SDCTL_SDBSZ_4BANKS,
EMIFA_SDCTL_SDRSZ_12ROW,
EMIFA_SDCTL_SDCSZ_8COL,
EMIFA_SDCTL_RFEN_ENABLE,
EMIFA_SDCTL_INIT_YES, //SDRAM 配置完每个CE空间后,初始化
EMIFA_SDCTL_TRCD_OF(1), //TRCD = 20ns
EMIFA_SDCTL_TRP_OF(1), //TRP = 20ns
EMIFA_SDCTL_TRC_OF(6),
EMIFA_SDCTL_SLFRFR_DISABLE //self refresh mode disable
EMIFA_SDTIM_RMK
EMIFA_SDTIM_XRFR_DEFAULT, //EXT TIMER default
EMIFA_SDTIM_PERIOD_OF(1560) //64ms, 4096 cycle refresh
EMIFA_SDEXT_RMK
EMIFA_SDEXT_WR2RD_OF(0), //cycles between write to read command = 1 CLK
EMIFA_SDEXT_WR2DEAC_OF(1), //cycles between write to precharge
EMIFA_SDEXT_WR2WR_OF(0), //cycles between write to write = 1 CLK
EMIFA_SDEXT_R2WDQM_OF(1), //cycles between read to bex = 2 CLK
EMIFA_SDEXT_RD2WR_OF(0), //cycles between read to write = 1 CLK
EMIFA_SDEXT_RD2DEAC_OF(1), //cycles between read to precharge
EMIFA_SDEXT_RD2RD_OF(0), //cycles between read to read = 1 CLK
EMIFA_SDEXT_THZP_OF(0), //Troh = 2 CLK
EMIFA_SDEXT_TWR_OF(1), //Twr >= 1 CLK +7 ns
EMIFA_SDEXT_TRRD_OF(0), //Trrd >= 14ns
EMIFA_SDEXT_TRAS_OF(4), //Tras >= 42ns
EMIFA_SDEXT_TCL_OF(0) //cas latency = 2 CLK
0x00000002,
0x00000002,
0x00000002,
0x00000002
SDRAM时钟为100M,使用的是MT48LC4M32b2-7,1M*4BAMK*32bit,自己实在看不出什么问题,麻烦大家帮我看看。
