[求助] 求助STM32操作ADS1247
a_____a   2011-5-10 19:55 楼主
求助STM32操作ADS1247,向地址为0X04的寄存器写入0XA3,读出不正确(data_Buf[3]要么是0要么是乱码),代码在内容中,请教高手!
void ADS1247_LowLevel_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  /*!< ADS1247_SPI Periph clock enable */
  /*!< ADS1247_SPI_SCL_GPIO_CLK, ADS1247_SPI_SDA_GPIO_CLK
       and ADS1247_SPI_SMBUSALERT_GPIO_CLK Periph clock enable */
  RCC_APB2PeriphClockCmd(ADS1247_SPI_CLK_GPIO_CLK | ADS1247_SPI_STR_GPIO_CLK | ADS1247_SPI_RDY_GPIO_CLK, ENABLE);
  /*!< Configure ADS1247_SPI pins: CLK SDI */
  GPIO_InitStructure.GPIO_Pin = ADS1247_SPI_CLK_PIN  | ADS1247_SPI_SDI_PIN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(ADS1247_SPI_CLK_GPIO_PORT, &GPIO_InitStructure);
  /*!< Configure ADS1247_SPI pins: SDO */
  GPIO_InitStructure.GPIO_Pin = ADS1247_SPI_SDO_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(ADS1247_SPI_SDO_GPIO_PORT, &GPIO_InitStructure);
  /*!< Configure ADS1247_SPI pins: START RESET */
  GPIO_InitStructure.GPIO_Pin = ADS1247_SPI_STR_PIN  | ADS1247_SPI_RET_PIN;
  GPIO_Init(ADS1247_SPI_STR_GPIO_PORT, &GPIO_InitStructure);
  /*!< Configure ADS1247_SPI pins: CS */
  GPIO_InitStructure.GPIO_Pin = ADS1247_SPI_CS_PIN;
  GPIO_Init(ADS1247_SPI_CS_GPIO_PORT, &GPIO_InitStructure);
  /*!< Configure ADS1247_SPI pins: READY*/
  GPIO_InitStructure.GPIO_Pin = ADS1247_SPI_RDY_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_Init(ADS1247_SPI_RDY_GPIO_PORT, &GPIO_InitStructure);
void ADS1247_Init(void)
    ADS1247_LowLevel_Init();
    ADS1247_CS_H;
    ADS1247_RET_H;
    ADS1247_RET_L;
    delay(5000000);
    ADS1247_RET_H;
    delay(5000000);
    ADS1247_STR_L;
    delay(DELAY_T);
    ADS1247_STR_H;
** 函数名称: void SPI_SendByte()    Name:   void SPI_SendByte()
** 功能描述: 通过SPI接口发送一个字节   Function: send a byte by SPI interface
** 输   入: INT8U byte: 发送的字节    Input:   INT8U byte: the byte that will be send
** 输   出: 无         Output:   NULL
** 说  明:
unsigned char SPI_SendByte(unsigned char byte)
    unsigned char i,j;
    j=0;
    ADS1247_CS_L;
    SPI_CLK_L;
    delay(DELAY_T);
    for(i=0;i<8;i++)           //"发数据
      SPI_CLK_H;
      if(byte&0x80)SPI_SDI_H;
      else SPI_SDI_L;
      byte=byte<<1;
      delay(DELAY_T);
      j=j<<1;
      if(GPIO_ReadInputDataBit(ADS1247_SPI_SDO_GPIO_PORT,ADS1247_SPI_SDO_PIN))j=(j|0x01);     //"读数据
      SPI_CLK_L;//
      delay(DELAY_T);
    //ADS1247_CS_H;
    return j;
** 函数名称: INT8U SPI_RecByte()    Name:   INT8U SPI_RecByte()
** 功能描述: 从SPI接口接收一个字节    Function: receive a byte from SPI interface
** 输   入: 无         Input:   NULL
** 输   出: 收到的字节       Output:   the byte that be received
unsigned char SPI_RecByte(void)
    return SPI_SendByte(0XFF);
}ADS1247_Init();
            //while(aabb)
main()
        ADS1247_Init();
                SPI_SendByte(ADS1247_WREG|0X04);
                SPI_SendByte(0X01);
                SPI_SendByte(0XA3);
                SPI_SendByte(ADS1247_RREG|0X04);
                SPI_SendByte(0X01);
                data_Buf[3] = SPI_RecByte();
回复评论 (3)
data_Buf[3]要么是0要么是乱码 是不是你数据没有传完才出现这种情况!
点赞  2011-5-10 20:13
回复 沙发 fxw451 的帖子
谢谢回复,应该不是,因为这段代码就是向地址为0X04的寄存器写入0XA3,然后再读出来,验证读写寄存器的正确性
点赞  2011-5-10 20:15
会不是是和ADS1247的上电顺序有关系呢?
点赞  2011-5-10 20:18
    写回复
