其中一个process如下,可不可以这样计数呀,就是不同的状态要延续不同的时间
process(clk,reset,call)
begin
if(reset='1')then
cur_st<=s0;
else
if(cur_st=s0)then
if(clk'event and clk='1')then
if(call='0')then
if(count0=4999)then
cur_st<=next_st;
count0<=0;
else
count0<=count0+1;
end if;
end if;
end if;
elsif(cur_st=s1 or cur_st=s3)then
if(call='0')then
if(count1=24999)then
cur_st<=next_st;
count1<=0;
else
count1<=count1+1;
end if;
end if;
end if;
elsif(cur_st=s2 or cur_st=s4)then
if(call='0')then
if(count2=9999)then
cur_st<=next_st;
count2<=0;
else
count2<=count2+1;
end if;
end if;
end if;
end if;
end if;
end process;
出现如下编译错误,求救啊!!!该怎么改呢??
Error (10821): HDL error at jiaotongdeng.vhd(21): can't infer register for "cur_st.s4" because its behavior does not match any supported register model
Error (10821): HDL error at jiaotongdeng.vhd(21): can't infer register for "cur_st.s3" because its behavior does not match any supported register model
Error (10821): HDL error at jiaotongdeng.vhd(21): can't infer register for "cur_st.s2" because its behavior does not match any supported register model
Error (10821): HDL error at jiaotongdeng.vhd(21): can't infer register for "cur_st.s1" because its behavior does not match any supported register model
Error (10821): HDL error at jiaotongdeng.vhd(21): can't infer register for "cur_st.s0" because its behavior does not match any supported register model
Error (10822): HDL error at jiaotongdeng.vhd(33): couldn't implement registers for assignments on this clock edge
Error (10822): HDL error at jiaotongdeng.vhd(44): couldn't implement registers for assignments on this clock edge
Info (10018): Can't recognize finite state machine "cur_st" because it has a complex reset state
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Synthesis was unsuccessful. 8 errors, 6 warnings
Error: Peak virtual memory: 214 megabytes
Error: Processing ended: Wed Aug 24 15:50:17 2011
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:03
Error: Quartus II Full Compilation was unsuccessful. 10 errors, 6 warnings
if(cur_st=s0)then
if(call='0')then
if(count0=4999)then
楼主这种语法格式绝对不正确,不符合电路,VHDL标准的电路编写方式
begin
if (rst='1') then
end if;
一个为理想不懈前进的人,一个永不言败人!
http://shop57496282.taobao.com/
欢迎光临网上店铺!
