#include <reg52.h>
#include <stdlib.h>
#include <intrins.h>
#include <stdio.h>
#define uchar unsigned char
#define uint unsigned int
char code DAT1[13]={0x14,0xD7,0x4C,0x45,0x87,0x25,0x24,0x57,0x04,0x05,0xef,0xff,0x3c,};
char code DAT2[11]={0x82,0xE7,0x4A, 0x46,0x27,0x16,0x12,0xC7,0x02,0x06,0x7f,};
sbit ledout = P3^1;
sbit heatout = P3^2;
sbit mout= P1^3;
sbit spk =P2^5;
sbit ld0=P2^0;
sbit ld1=P2^1;
sbit ld2=P2^2;
sbit ld3=P1^4;
sbit ld4=P1^5;
sbit k0 = P3^4;
sbit k1 = P3^3;
sbit k2 = P1^2;
sbit k3 = P1^6;
sbit SDA=P3^6;
sbit SCL=P3^7;
sbit sw=P3^5;
sbit aled = P2^6;
sbit bled = P2^4;
bit aledk=0;
bit yx=0;
bit yb=0;
bit led0=0;
bit ick=1;
bdata char com_data;
sbit mos_bit=com_data^7;
sbit low_bit=com_data^0;
uchar cc=40,ccc=170;
char key=0,keyt=0,minaok=0,minbok=0;ickk=0,ickkk=0,min=0,sec=60,cshc=0;
char led1=0xff,table_2=0,table_3=0,table_4=0,table_5=0,table_8=0;
char cnt=0,cnttme=0,cnt6=0,cnt7=0,cnt8=0,dcnt=0,kcnt=0;
void delay( uint z )
uint x,y;
for(x=z;x>0;x--)
for(y=150;y>0;y--);
void BEEP (void)
spk =0;
delay(80);
spk =1;
void start()
SDA=1;_nop_();_nop_();_nop_();_nop_();
SCL=1;_nop_();_nop_();_nop_();_nop_();
SDA=0;_nop_();_nop_();_nop_();_nop_();
SCL=0;_nop_();_nop_();_nop_();_nop_();
void stop()
void ack()
void shift8(char a)
data uchar i;
com_data=a;
for(i=0;i<8;i++)
SDA=mos_bit;
SCL=1;_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
SCL=0;_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
com_data=com_data*2;
uchar rd_24c01(char a)
data uchar i,command;
start();
command=160;
shift8(command);
ack();
shift8(a);
ack();
start();
command=161;
shift8(command);
ack();
for(i=0;i<8;i++)
low_bit=SDA;
stop();
return(com_data);
void wr_24c01(char a,b)
data uchar command;
start();
command=160;
shift8(command);
ack();
shift8(a);
ack();
shift8(b);
ack();
stop();
void kay(void)
if(minaok>=20)
min++;
heatout=1;
if((k3)&&(key==0)){minaok=0;}
delay(100);
if(min>=99){min=99;minaok=0;}
else{if((k3)&&(key==0)){minaok=0;}}
if(minbok>=20)
min--;
heatout=1;
if((k2)&&(key==0)){minbok=0;}
delay(100);
if(min<=1){min=1;minbok=0;}
else{if((k2)&&(key==0)){minbok=0;}}
if((keyt!=key)&&((!k1)||(!k2)||(!k3)||(!k0)))delay(5);
if(key==1)
min++;
BEEP();
if(min>98)min=99;
if(key==2)
min--;
BEEP();
if(min<1)min=1;
if(key==3)
yb=~yb;
if(!yb){bled=1;led1=0xff;cnt7=0;}
BEEP();
if(key==4)
yx=~yx;
if(yx){ledout =1;aled=0;} else{ledout=0;aled=1;led1=0xff;}BEEP();
keyt=key;
void display(void)
if((yb)&&(cc<ccc))
mout=0;
else
mout=1;
table_4=min%10;
table_5=min/10;
if(cc>=90)
table_2=(cc%100)%10;
table_3=(cc%100)/10;
table_8=cc/100;
heatout=1;
if(yb){bled=0;}
if(cc<90)
heatout=0;
if(yb)
if(aledk)bled=1;
if(!aledk)bled=0;
switch(cnt7)
case 0:{
table_2=10;table_3=10;table_8=10;
}break;
case 1:{
table_2=11;table_3=11;table_8=12;
}break;
case 2:{
table_2=11;table_3=12;table_8=12;
}break;
case 3:{
table_2=12;table_3=12;table_8=12;
void LcmInit( void )
TMOD = 0x11;
TH0 = (65536-50000)/256;
TL0 = (65536-50000)%256;
ET0 = 1;TR0 = 1;
TH1= (65536-1000)/256;
TL1 = (65536-1000)%256;
ET1 = 1;TR1 = 1;EA = 1;
void time(void)
if(cnt>=19)
cnt=0;
sec--;
led0=~led0;
if(led0)led1=0xfd;
if(!led0)led1=0xff;
if(sec<=0){if(min!=0){sec=59;min--;}
void time1 (void) interrupt 1
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
if(yb||yx)cnt++;
/***此处屏蔽为商业用的***/
void time2 (void)interrupt 3
TH1= (65536-1500)/256;
TL1=(65536-1500)%256;
P0=0xff;ld0=1;ld1=1;ld2=1;ld3=1;ld4=1;
switch(dcnt)
case 0:{P0=DAT1[table_8];ld4=1;ld0=0;}break;
case 1:{P0=DAT1[table_3];ld0=1;ld1=0;}break;
case 2:{P0=DAT1[table_2];ld1=1;ld2=0;}break;
case 3:{P0=DAT2[table_5];ld2=1;ld3=0;}break;
case 4:{P0=DAT2[table_4]&led1;ld3=1;ld4=0;}break;
case 5:{
k0=1;k1=1;k2=1;k3=1;
switch(kcnt)
case 0:{if(!k0)key=3;}break;
case 1:{if(!k1)key=4;}break;
case 2:{if(!k2){key=2;minbok++;if(minbok>25)minbok=25;}}break;
case 3:{if(!k3){key=1;minaok++;if(minaok>25)minaok=25;}}break;
if((k0)&&(k1)&&(k2)&&(k3)){key=0;keyt=10;}
dcnt++;
if(dcnt>=6)
dcnt=0;
kcnt++;
if(kcnt>=4)
kcnt=0;
void Main( void )
LcmInit();
icaa:
heatout=0;
mout=1;
ledout=0;
ick=1;ickk=0;ickk=0;
min=0;cshc=0;yx=0;yb=0;
aled=1;bled=1;led1=0xff;
table_4=10;table_5=10;table_2=10;
table_3=10;table_8=10;cnt7=0;
do{
if(cc>=88)display();
aled =~aled;delay(150);
if(!sw)delay(10);
if(!sw)
ickk=rd_24c01(1);delay(10);
ickkk=rd_24c01(2);delay(10);
min=rd_24c01(3);delay(10);
cshc=rd_24c01(4);delay(10);
BEEP();
if((ickk==1)&&(ickkk==2)&&(cshc>=1)&&(cshc<=99))
table_4=min%10;
table_5=min/10;
table_3=cshc%10;
table_8=cshc/10;
table_2=11;
aled=1;bled=1;ick=0;
while(ick);
do{bled =~bled;delay(80);}while(k0&&(!sw));delay(5);
if(sw){goto icaa;}
cshc--;
wr_24c01(4,cshc);delay(10);
table_8=10;
table_2=cshc%10;
table_3=cshc/10;
BEEP();
bled=1;
delay(3000);
while(1)
if(min==0&&(yb||yx))
BEEP();delay(500);
BEEP();delay(500);
BEEP();delay(500);
goto icaa;
if((sw)||(cshc<=0))delay(10);
if((sw)||(cshc<=0))
goto icaa;
time();
kay();
display();
