[求助] Virtex5 mgt 仿真遇到的问题
jasonshows   2011-11-3 15:26 楼主
各位好  我在用modelsim se 6.5 仿真 rocket io的时候 在modelsim中出现如下警告 :
# ** Error:  Input Error : RST on instance   must be asserted for 3 CLKIN clock cycles.
#    Time: 19252 ps  Iteration: 4  Instance: /example_tb/example_mgt_top_i/txoutclk_dcm0_i/clock_divider_i/dcm_adv_inst
#    Time: 134452 ps  Iteration: 4  Instance: /example_tb/example_mgt_top_i/txoutclk_dcm0_i/clock_divider_i/dcm_adv_inst
我是将生成ipcore中的仿真代码加入到ise下的工程中,再调用modelsim仿真的。ise下的仿真库我全部编译过。
请问大家这是什么原因造成的?
FPGA
回复评论 (2)
In simulation, the TXOUTCLK port of the MGT will only start toggling 1 or 2 cycles prior to PLLLKDET asserting. If PLLLKDET is used to drive the RST port of the DCM, this can lead to the above warning. In most cases this warning can be ignored, though in rare cases the DCM output will remain flat lined. To work around this possibility, adding a 3-cycle pipeline to PLLLKDET will add enough delay to correctly reset the DCM.
In hardware, this is not a problem as TXOUTCLK will be toggling at the correct speed for a large number of cycles prior to PLLLKDET asserting.
点赞  2011-11-29 23:10
引用: RST on instance must be asserted for 3 CLKIN clock cycles.
上面不是清楚说明了你的原因,就是因为你RST信号没有持续3个时钟周期以上啊!
一个为理想不懈前进的人,一个永不言败人! http://shop57496282.taobao.com/ 欢迎光临网上店铺!
点赞  2011-11-30 09:14
    写回复
