library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ad_hgq is
port(
d :in std_logic_vector(7 downto 0);---AD输入;
clk,eoc :in std_logic; ---eoc:转换结束状态信号;
oe : buffer std_logic;
ale,start:out std_logic; ---ale:允许地址锁存;
q :buffer std_logic_vector(7 downto 0);
OneUSCLK : inout std_logic
); ---转换数据输出显示;
end ad_hgq;
architecture behaviour of ad_hgq is
type state is (st0,st1,st2,st3,st4,st5,st6,st7); ---以枚举类型定义各状态子类型;
signal current_state,next_state :state:=st0;
signal regl :std_logic_vector(7 downto 0);
signal lock :std_logic; ---转换后数据输出锁存时钟信号;
signal hex :std_logic_vector(7 downto 0);
signal clkCount: std_logic_vector (6 downto 0);
begin
process(current_state,eoc)
begin
case current_state is
when st0=> ale<='0';start<='0';oe<='0';lock<='0'; next_state<=st1;
---初始态ST0向下一状态ST1转换,0809采样控制信号初始化;
when st1=> ale<='1';start<='0';oe<='0';lock<='0'; next_state<=st2;
---由ALE的上升沿将通道地址'001'锁入0809的地址寄存器;
when st2=> ale<='1';start<='1';oe<='0';lock<='0'; next_state<=st3; ---启动采样信号;
when st3=> ale<='0';start<='1';oe<='0';lock<='0';
if(eoc='0') then next_state<=st4; ---转换即将结束,转换至下一状态;
else next_state<=st3; ---转换未结束,继续在状态ST3中等待;
end if;
when st4=> ale<='0';start<='0';oe<='0';lock<='0';
if(eoc='1') then next_state<=st5; ---EOC由0恢复1,转换结束;
else next_state<=st4; ---转换未结束,等待;
end if;
when st5=> ale<='0';start<='0';oe<='1';lock<='0'; next_state<=st6; --开启输出允许OE;
when st6=> ale<='0';start<='0';oe<='1';lock<='1'; next_state<=st7; --开启数据锁存LOCK;
when st7=> ale<='0';start<='0';oe<='0';lock<='1'; next_state<=st0;
when others=>next_state<=st0; ---其它状态返回ST0;
end case;
end process;
process (CLK)
begin
if (CLK = '1' and CLK'event) then
if(clkCount = "1100011") then
clkCount <= "0000000";
oneUSClk <= not oneUSClk;
else
clkCount <= clkCount + 1;
end if;
end if;
end process;
process(oneUSClk)
begin
if(oneUSClk'event and oneUSClk='1') then current_state<=next_state;
end if; ---在时钟上升沿,转换至下一状态;
end process ; ---由信号current_state将当前状态带出进程,进入下一进程;
process(lock)
begin
if (lock='1'and lock'event) then regl<=d;
end if; --在lock上升沿,将转换好的数据锁存入8位锁存器中;
end process;
q<=regl; ---数据输出;
process(oneUSClk)
begin
if( oneUSClk'event and oneUSClk ='1') then if oe='1' then hex<=q; ---将数据送给hex;
end if;
end if;
end process;
end behaviour;
