[求助] 串口中断不能返回主函数???急急急
lukyoo   2012-5-30 12:05 楼主
#include "stm32f10x.h"
#include "stm32f10x_usart.h"
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
void RCC_Configuration(void);
void USART1_InitConfig(u32 BaudRate);
void NVIC_Configuration(void);
void Delay(__IO uint32_t nCount);
   //使能串口的 RCC 时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE);
    //串口使用的 GPIO 口配置
    //配置串口接收脚
    /* Configure USART1 Rx (PA.10) as input floating */
    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOA,&GPIO_InitStructure);
    /* Configure USART1 Tx (PA.09) as alternate function push-pull */
    //配置串口发送脚
    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
    //配置串口,异步模式
    USART_InitStructure.USART_BaudRate=BaudRate;
    USART_InitStructure.USART_WordLength=USART_WordLength_8b;
    USART_InitStructure.USART_StopBits=USART_StopBits_1;
    USART_InitStructure.USART_Parity=USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
    USART_Init(USART1,&USART_InitStructure);//配置串口 1
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);   //使能接收中断
  //  USART_ITConfig(USART1, USART_IT_TXE, ENABLE);        //使能发送缓冲空中断
    USART_Cmd(USART1,ENABLE);//使能串口 1
        USART_ClearFlag(USART1, USART_FLAG_TC);
          //串口中断配置
          //设置优先级配置的模式,详情请阅读原材料中的文章
          NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
                    // Enable the USART1 Interrupt
          NVIC_InitStructure.NVIC_IRQChannel =USART1_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
          NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
          NVIC_Init(&NVIC_InitStructure);  //将结构体丢到配置函数,即写入到对应寄存器中
extern int f;
extern u8 Uart1_get_Data;
int main(void)
  RCC_Configuration();                                   //系统时钟配置
  USART1_InitConfig(9600);
  NVIC_Configuration();
  while(f)
          USART_SendData(USART1,Uart1_get_Data);
//        USART_ClearITPendingBit(USART1,USART_FLAG_TC);
        //while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);//等待发送结束
* 名    称:void RCC_Configuration(void)
* 功    能:系统时钟配置为72MHZ
* 入口参数:无
* 出口参数:无
* 说    明:
* 调用方法:无
  SystemInit();
* 名    称:void Delay(__IO uint32_t nCount)
* 功    能:延时函数
* 入口参数:无
* 出口参数:无
* 说    明:
* 调用方法:无
void Delay( uint32_t nCount)
   for(; nCount != 0; nCount--);
int f=0;
u8 Uart1_get_Data;
void USART1_IRQHandler(void)    //中断发送方式
//    if(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) != RESET) //判断发生发送中断  *******************
//   { USART_ClearFlag(USART1,USART_FLAG_RXNE);
//      USART_GetFlagStatus(USART1,USART_FLAG_RXNE);
         if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
           //USART_ClearFlag();
           USART_ClearITPendingBit(USART1,USART_IT_RXNE);//清楚中断标注位
           Uart1_get_Data=USART_ReceiveData(USART1);     //发送数据
           f=1;
           USART_SendData(USART1,f);
//           while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);//等待发送结束
回复评论
暂无评论,赶紧抢沙发吧
    写回复
