协议栈版本信息: ZigBee2006\ZStack-1.4.3-1.2.1
因为用现在这模块SerialApp没做成功,上电后按键没反应……两块无线龙小板子已经买来N年了.
自己想在SampleApp例子基础上修改实现串口透明传输:
串口调试助手1<————>模块1 <-----OTA-----> 模块2<————>串口调试助手2
程序修改主要如下:
1、
宏定义事件 #define UART_RX_CB_EVT 0x0002 (SampleApp.h)
全局变量声明: (SPIMgr.h)
extern uint8 rxlen;
2、
串口回调函数rxCB: (SPIMgr.c)
#if defined (ZTOOL_P1) || defined (ZTOOL_P2)
uartConfig.callBackFunc = rxCB;
//uartConfig.callBackFunc = SPIMgr_ProcessZToolData; //回调函数
3、十六进制转字符函数 (SampleApp.c) 这两个函数由青竹提供.
uint8 hextoword1(uint8 t )
uint8 abc;
uint8 cba;
uint8 xx1;
abc=t;
cba=0xf0;
abc=(abc&cba)>>4;
if(abc<10)
xx1=abc+48;
else
xx1=abc+55;
return xx1;
uint8 hextoword2(uint8 t)
uint8 abc;
uint8 cba;
uint8 xx2;
abc=t;
cba=0x0f;
abc=abc&cba;
if(abc<10)
xx2=abc+48;
else
xx2=abc+55;
return xx2;
4、定义串口回调函数rxCB() (SPIMgr.c)
static void rxCB( uint8 port, uint8 event )
// uint8 rxlen; //接收数据长度
// uint8* dataybuf;//接收数据块指针
extern uint8 SampleApp_TaskID;
uint16 short_ddr;
uint8 short_ddr_H;
uint8 short_ddr_L;
// uint8 *pointer1;
// uint8 word_buffer[8];
short_ddr=NLME_GetShortAddr();
short_ddr_H=(uint8)((short_ddr&0xff00)>>8);
short_ddr_L=(uint8)short_ddr;
rxlen=Hal_UART_RxBufLen(SPI_MGR_DEFAULT_PORT); //接收缓冲区数据长度,字节为单位
databuf=osal_mem_alloc(rxlen+1+2); //多分配3字节,分配如下
databuf[0]=rxlen; databuf[1]=short_ddr_H; databuf[2]=short_ddr_L; //databuf[rxlen+1]='\n'; HalUARTRead ( SPI_MGR_DEFAULT_PORT, databuf+3, rxlen);
if(!rxlen)
osal_mem_free( databuf ); osal_set_event(SampleApp_TaskID,UART_RX_CB_EVT);
5、添加:事件处理函数 (SampleApp.c)
uint16 SampleApp_ProcessEvent( uint8 task_id, uint16 events )
afIncomingMSGPacket_t *MSGpkt;
uint16 short_ddr;
uint8 yy1;
uint8 yy2;
uint8 str_1[ ]="my short address is:";
#if defined(ZDO_COORDINATOR)
uint8 str_2[ ]="build the network successfully";
#else
uint8 str_2[ ]="";
#endif
uint8 str_3[ ]={'\n'};
uint8 shortaddr[7];
uint8 *pointer1;
uint8 *pointer2;
uint8 *pointer3;
uint8 *pointer4;
case AF_INCOMING_MSG_CMD:
case ZDO_STATE_CHANGE:
SampleApp_NwkState = (devStates_t)(MSGpkt->hdr.status);
if ( (SampleApp_NwkState == DEV_ZB_COORD)
|| (SampleApp_NwkState == DEV_ROUTER)
|| (SampleApp_NwkState == DEV_END_DEVICE) )
yy1=(uint8)((short_ddr&0xff00)>>8);
yy2=(uint8)short_ddr;
shortaddr[0]=48;
shortaddr[1]=120;
shortaddr[2]=hextoword1(yy1);
shortaddr[3]=hextoword2(yy1);
shortaddr[4]=hextoword1(yy2);
shortaddr[5]=hextoword2(yy2);
shortaddr[6]='\n';
pointer1=&shortaddr[0];
pointer2=&str_1[0];
pointer3=&str_2[0];
pointer4=&str_3[0];
HalUARTWrite(0,pointer4,1);
HalUARTWrite(0,pointer3,29);
HalUARTWrite(0,pointer2,20);
HalUARTWrite(0,pointer1,7);
if ( events & UART_RX_CB_EVT ) //串口数据处理
SampleApp_SPI_SendData( databuf, rxlen+1+2 );
6、定义AF层数据处理函数(SampleApp.c)
默认采用的簇ID为SAMPLEAPP_PERIODIC_CLUSTERID
void SampleApp_MessageMSGCB( afIncomingMSGPacket_t *pkt )
uint16 flashTime;
uint16 short_ddr;
uint8 *pointer1;
uint8 *pointer2;
uint8 *pointer3;
uint8 *pointer4;
uint8 *pointer5;
uint8 *pointer6;
uint8 *pointer7;
uint8 *pointer8;
uint8 *pointer9;
uint8 str_1[ ]="address:";
uint8 str_2[ ]="Destination address:";
uint8 str_3[ ]="Data length:";
uint8 str_4[ ]="Data:";
uint8 str_5[ ]={'\n'};
pointer1=&str_1[0];
pointer2=&str_2[0];
pointer3=&str_3[0];
pointer4=&str_4[0];
pointer9=&str_5[0];
uint8 Src_short_ddr_H;
uint8 Src_short_ddr_L;
uint8 Des_short_ddr_H;
uint8 Des_short_ddr_L;
uint8 word_buffer[4];
uint8 Src_shortaddr[7];
uint8 Des_shortaddr[7];
switch ( pkt->clusterId )//判断簇ID
case SAMPLEAPP_PERIODIC_CLUSTERID:// flashTime = BUILD_UINT16(pkt->cmd.Data[1], pkt->cmd.Data[2] );
// HalLedBlink( HAL_LED_4, 4, 50, (flashTime / 4) );
word_buffer[0]=(pkt->cmd.Data[0])/100+48;
word_buffer[1]=((pkt->cmd.Data[0])0)/10+48;
word_buffer[2]=(pkt->cmd.Data[0])+48;
word_buffer[3]='\n';
pointer6=word_buffer;
Src_short_ddr_H=pkt->cmd.Data[1];
Src_short_ddr_L=pkt->cmd.Data[2];
Src_shortaddr[0]=48;
Src_shortaddr[1]=120;
Src_shortaddr[2]=hextoword1(Src_short_ddr_H);
Src_shortaddr[3]=hextoword2(Src_short_ddr_H);
Src_shortaddr[4]=hextoword1(Src_short_ddr_L);
Src_shortaddr[5]=hextoword2(Src_short_ddr_L);
Src_shortaddr[6]='\n';
pointer7=&Src_shortaddr[0]; //----------------
Des_short_ddr_H=(uint8)((short_ddr&0xff00)>>8);
Des_short_ddr_L=(uint8)short_ddr;
Des_shortaddr[0]=48;
Des_shortaddr[1]=120;
Des_shortaddr[2]=hextoword1(Des_short_ddr_H);
Des_shortaddr[3]=hextoword2(Des_short_ddr_H);
Des_shortaddr[4]=hextoword1(Des_short_ddr_L);
Des_shortaddr[5]=hextoword2(Des_short_ddr_L);
Des_shortaddr[6]='\n';
pointer8=&Des_shortaddr[0];
HalUARTWrite ( 0, pointer1, 15 ); HalUARTWrite ( 0, pointer7, 7 );
HalUARTWrite ( 0, pointer8, 7 );
HalUARTWrite ( 0, pointer3, 12 ); HalUARTWrite ( 0, pointer6, 4 );
HalUARTWrite ( 0, pointer5, pkt->cmd.Data[0] ); //pointer1=&(pkt->cmd.Data[3]);
//HalUARTWrite ( 0, pointer1, 6 );
break;
case SAMPLEAPP_FLASH_CLUSTERID://flash
break;
7、定义串口数据处理函数(SampleApp.c)
我只有两个节点,所以这里采用最简单的单点传送方式.下载协调器程序时目标地址改为0x796F,下载终端程序时目标地址改为0x0000.默认ClusterID为SAMPLEAPP_PERIODIC_CLUSTERID.
void SampleApp_SPI_SendData( uint8 *buf, uint8 len )
SampleApp_SPI_SendData_DstAddr.addrMode = (afAddrMode_t)Addr16Bit;
SampleApp_SPI_SendData_DstAddr.endPoint = SAMPLEAPP_ENDPOINT;
SampleApp_SPI_SendData_DstAddr.addr.shortAddr = 0x796F; //0x796F;0x0000
if ( AF_DataRequest( &SampleApp_SPI_SendData_DstAddr,
(endPointDesc_t *)&SampleApp_epDesc,
SAMPLEAPP_PERIODIC_CLUSTERID,
len, buf,
&SampleApp_TransID,
0,
AF_DEFAULT_RADIUS ) == afStatus_SUCCESS )
osal_mem_free( databuf ); //必须释放内存,不然造成溢出!
else
编译情况:
通信结果1:(关于开头的乱码说明参考后篇记录)
通信结果2:
最大数据只能达到52字节:(但在修改程序过程中,达到过83字节;等修改完整后只有52字节了):
