手头有w25x80的IC,是spi接口的flash芯片,很好读写和使用,就连在launchpad的接口上试试
其实只要实现字节的读写就好了,其它的页段操作都是在这上面实现的
源代码在这里
3.rar
(738.78 KB)
(下载次数: 7, 2013-11-16 17:52 上传)
- void
- SPI1_CSIO_Init(void)
- // Enable Peripheral Clocks
- MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
- MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
- // Enable port PC5 for GPIOOutput
- MAP_GPIOPinTypeGPIOOutput(GPIO_PORTC_BASE, GPIO_PIN_5);
- // Enable port PD1 for GPIOOutput
- MAP_GPIOPinTypeGPIOOutput(GPIO_PORTD_BASE, GPIO_PIN_1);
- void SPI_CS(enum Device tDev)
- switch(tDev)
- case SD:
- FLASH_CS0(0);
- SD_CS0(1);
- break;
- case FLASH:
- SD_CS0(0);
- FLASH_CS0(1);
- break;
- case VS1003:
- NRF2401_CS0(0);
- VS1003_CS0(1);
- break;
- case NRF2401:
- VS1003_CS0(0);
- NRF2401_CS0(1);
- break;
- default:break;
- void SD_CS(unsigned char id)
- SD_CS0(id);
- void
- SPI0_Prot_Init(void)
- MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);
- MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
- // Enable port PA4 for SSI0 SSI0RX
- MAP_GPIOPinConfigure(GPIO_PA4_SSI0RX);
- MAP_GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_4);
- // Enable port PA5 for SSI0 SSI0TX
- MAP_GPIOPinConfigure(GPIO_PA5_SSI0TX);
- MAP_GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5);
- // Enable port PA2 for SSI0 SSI0CLK
- MAP_GPIOPinConfigure(GPIO_PA2_SSI0CLK);
- MAP_GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_2);
- // Enable port PA3 for SSI0 SSI0FSS
- MAP_GPIOPinConfigure(GPIO_PA3_SSI0FSS);
- MAP_GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_3); */
- void
- SPI1_Port_Init(void)
- MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI1);
- // Enable port PD3 for SSI1 SSI1TX
- MAP_GPIOPinConfigure(GPIO_PD3_SSI1TX);
- MAP_GPIOPinTypeSSI(GPIO_PORTD_BASE, GPIO_PIN_3);
- // Enable port PD0 for SSI1 SSI1CLK
- MAP_GPIOPinConfigure(GPIO_PD0_SSI1CLK);
- MAP_GPIOPinTypeSSI(GPIO_PORTD_BASE, GPIO_PIN_0);
- // Enable port PD2 for SSI1 SSI1RX
- MAP_GPIOPinConfigure(GPIO_PD2_SSI1RX);
- MAP_GPIOPinTypeSSI(GPIO_PORTD_BASE, GPIO_PIN_2);
- // Enable port PD1 for SSI1 SSI1FSS
- MAP_GPIOPinConfigure(GPIO_PD1_SSI1FSS);
- MAP_GPIOPinTypeSSI(GPIO_PORTD_BASE, GPIO_PIN_1); */
- void
- SPI0_Init(unsigned long ulBitRate)
- SPI0_Prot_Init();
- // Configure and enable the SSI port for SPI master mode. Use SSI0,
- // system clock supply, idle clock level low and active low clock in
- // freescale SPI mode, master mode, 1MHz SSI frequency, and 8-bit data.
- // For SPI mode, you can set the polarity of the SSI clock when the SSI
- // unit is idle. You can also configure what clock edge you want to
- // capture data on. Please reference the datasheet for more information on
- // the different SPI modes.
- SSIConfigSetExpClk(SSI0_BASE, SysCtlClockGet(), SSI_FRF_MOTO_MODE_0,
- SSI_MODE_MASTER, ulBitRate, 8);
- // Enable the SSI0 module.
- SSIEnable(SSI0_BASE);
- void
- SPI1_Init(unsigned long ulBitRate)
- SPI1_Port_Init();
- // Configure and enable the SSI port for SPI master mode. Use SSI1,
- SSIConfigSetExpClk(SSI1_BASE, SysCtlClockGet(), SSI_FRF_MOTO_MODE_0,
- // Enable the SSI1 module.
- SSIEnable(SSI1_BASE);
- void
- SPI0_SetSpeed(unsigned char speed)//SPI速度设置
- SSI_MODE_MASTER, MAXHZ>>speed, 8);
- void
- SPI1_SetSpeed(unsigned char speed)//SPI速度设置
- unsigned char
- SPI0_ReadWriteByte(unsigned char data)//发送接收一个数据
- unsigned long rcvdat;
- ROM_SSIDataPut(SSI0_BASE, data); /* write dummy data */
- ROM_SSIDataGet(SSI0_BASE, &rcvdat); /* read data frm rx fifo */
- return (unsigned char)rcvdat;
- unsigned char
- SPI1_ReadWriteByte(unsigned char data)//发送接收一个数据
- ROM_SSIDataPut(SSI1_BASE, data); /* write dummy data */
- ROM_SSIDataGet(SSI1_BASE, &rcvdat); /* read data frm rx fifo */
本帖最后由 shower.xu 于 2013-11-16 17:52 编辑 ]
