大家好,请问各位FPGA大神们,想问一下大家这个多频率怎么编写啊,这是一款EEPROM存储芯片,要求输入如下面频率信号。
图中电源电压VCC=3.3V,R1 = 1×(1±10%)KΩ,R2 = 1×(1±10%)KΩ,C1 = 30×(1±10%)pF。输入信号F0 = 1MHz,F1 = F0/2,F2 = F1/2,F3 = F2/2,F4 = F3/2,F5 = F4/2,F6 = F5/2,F7 = F6/2,F8 = F7/2,F9 = F8/2,F10 = F9/2,F11 = F10/2,F12 = F11/2,F13 = F12/2,F14 = F13/2,F15 = F14/2,F16 = F15/2,FC0 = 500KHZ。请问F0,F1,F2,F3,F4,F5,,,的频率怎么分。
时钟频率由外部clk0产生50MHZ的晶振,从CLK0输入到CPLD芯片内部,但现在我有点不知道怎么把50HMZ的频率,每次都二分频,给到不同的地址上去,百度过,想到用二分频的方法,由于小弟对FPGA不很会用,只是在学校学习过VHDL语言,有些语法还不太会用。请大神们指点一下。下面是我预先写的一个程序,在处理地址上的不同频率,还不太对。望指点一下感激不尽。
module VDEE5M40VS(clk_in,cs,led,rest,address);
input clk_in,rest;
output [2:0] led;
output [16:0] address;
output cs;
reg cs;
reg clk_out;
reg clk_500k;
reg [2:0] led;
reg [49:0] j; // 1MHZ counter data
reg [99:0] k; // 500khz counter data
reg [31:0] count1;
reg [31:0] num;
reg [16:0] address;
reg [35:0] count2;
parameter N=36;
initial
begin
count1 <=32'h0000_0000;
count2<=32'h0000_0000;
num<= 32'h0000_0000;
led<= 3'hf0;
cs<=1'b0;
address<= 17'h0000_0000;
end
always @(posedge clk_in)
begin
if(count2==N/2-1) // 50MHZfrequency counter number 50 generate 1MHZ
begin
clk_out <=!clk_out;
count2 <=0;
end
else
count2<= count2+1'b1;
end
LED Control 1s 闪烁
begin
if(num == 32'd50000000)
begin
led[0]<=~led[0];
num<=32'b0;
end
else
begin
num <= num +1'b1;
end
end
address control 这里的多频率/2,加载到不同的地址线上,不知改如何处理
always@(posedge clk_out)
begin
if(count1 <= 32'd50)
begin
if(count1 %2 ==1'b1)
begin
//we <= 1'b1;
//oe <= 1'b1;
address <= address+1'b1;
end
elsebegin
//we <= 1'b1;
// oe <= 1'b1;
address <= address;
end
count1 <=count1+1'b1;
end
elsebegin
led [2] <= ~led [2];
count1<= 32'h0000000;
address<=17'h000000;
end
end
generate 500kHZ frequency
always @(posedge clk_in) //50MHZ clk 时钟信号产生 500KHZ信号
begin
if(k==100) //500KHZ=50MHZ/100
begin
k <=0;
clk_500k <=~clk_500k;
end
end
chip cs0 control
always @(posedge clk_500k)
begin
if(led[2] <=1'b0)
begin
cs<= ~cs;
end
else
cs<= 1'b1;
end
endmodule
IC测试QQ群(111938408
