[原创] TMS320F28335项目开发记录7_28335之时钟
风雨也无晴   2015-3-30 11:52 楼主
TMS320F28335时钟
    TMS320F28335上有一个基于PLL电路的片上时钟模块,如图1所示,为CPU及外设提供时钟有两种方式:
      一种是用外部的时钟源,将其连接到X1引脚上或者XCLKIN引脚上,X2接地;
      另一种是使用振荡器产生时钟,用30MHz的晶体和两个20PF的电容组成的电路分别连接到X1和X2引脚上,XCLKIN引脚接地。
    我们常用第二种来产生时钟。此时钟将通过一个内部PLL锁相环电路,进行倍频。由于F28335的最大工作频率是150M,所以倍频值最大是5。其中倍频值由PLLCR的低四位和PLLSTS的第7、8位来决定。其详细的倍频值可以参照TMS320F28335的Datasheet。
三种时钟输入的接法:
下面是InitSysCtrl函数中调用的InitPll函数进行时钟设置:
  1. //---------------------------------------------------------------------------
  2. // This function initializes the PLLCR register.
  3.
  4. void InitPll(Uint16 val, Uint16 divsel)
  5. {
  6.
  7.    // Make sure the PLL is not running in limp mode
  8.    if (SysCtrlRegs.PLLSTS.bit.MCLKSTS != 0)
  9.    {
  10.       // Missing external clock has been detected
  11.       // Replace this line with a call to an appropriate
  12.       // SystemShutdown(); function.
  13.       asm("        ESTOP0");
  14.    }
  15.
  16.    // DIVSEL MUST be 0 before PLLCR can be changed from
  17.    // 0x0000. It is set to 0 by an external reset XRSn
  18.    // This puts us in 1/4
  19.    if (SysCtrlRegs.PLLSTS.bit.DIVSEL != 0)
  20.    {
  21.        EALLOW;
  22.        SysCtrlRegs.PLLSTS.bit.DIVSEL = 0;
  23.        EDIS;
  24.    }
  25.
  26.    // Change the PLLCR
  27.    if (SysCtrlRegs.PLLCR.bit.DIV != val)
  28.    {
  29.
  30.       EALLOW;
  31.       // Before setting PLLCR turn off missing clock detect logic
  32.       SysCtrlRegs.PLLSTS.bit.MCLKOFF = 1;
  33.       SysCtrlRegs.PLLCR.bit.DIV = val;
  34.       EDIS;
  35.
  36.       // Optional: Wait for PLL to lock.
  37.       // During this time the CPU will switch to OSCCLK/2 until
  38.       // the PLL is stable.  Once the PLL is stable the CPU will
  39.       // switch to the new PLL value.
  40.       //
  41.       // This time-to-lock is monitored by a PLL lock counter.
  42.       //
  43.       // Code is not required to sit and wait for the PLL to lock.
  44.       // However, if the code does anything that is timing critical,
  45.       // and requires the correct clock be locked, then it is best to
  46.       // wait until this switching has completed.
  47.
  48.       // Wait for the PLL lock bit to be set.
  49.
  50.       // The watchdog should be disabled before this loop, or fed within
  51.       // the loop via ServiceDog().
  52.
  53.       // Uncomment to disable the watchdog
  54.       DisableDog();
  55.
  56.       while(SysCtrlRegs.PLLSTS.bit.PLLLOCKS != 1)
  57.       {
  58.           // Uncomment to service the watchdog
  59.           // ServiceDog();
  60.       }
  61.
  62.       EALLOW;
  63.       SysCtrlRegs.PLLSTS.bit.MCLKOFF = 0;
  64.       EDIS;
  65.     }
  66.
  67.     // If switching to 1/2
  68.     if((divsel == 1)||(divsel == 2))
  69.     {
  70.         EALLOW;
  71.         SysCtrlRegs.PLLSTS.bit.DIVSEL = divsel;
  72.         EDIS;
  73.     }
  74.
  75.     // If switching to 1/1
  76.     // * First go to 1/2 and let the power settle
  77.     //   The time required will depend on the system, this is only an example
  78.     // * Then switch to 1/1
  79.     if(divsel == 3)
  80.     {
  81.         EALLOW;
  82.         SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;
  83.         DELAY_US(50L);
  84.         SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;
  85.         EDIS;
  86.     }
  87. }
如果我们希望DSP工作在某一个频率下,我们就可以对Uint16 val, Uint16 divsel两个参数进行设定。
说白了就相当于乘10,除2 (30*10/2 = 150MHZ)
更详细内容参考:
http://wenku.baidu.com/link?url=vL0bh97ETShHDNcARicm11dkcvSac4VbUE-mm9uvkZSxq4wDpYi3x9Xxevtq7moLFlBX3KSYSQ6icRGo21ePg7MWfu8hI4cnfrn_aAFRUUi
路漫漫其修远兮,吾将上下而求索!(今天,你努力了吗?还记得你的目标吗?)
回复评论
暂无评论,赶紧抢沙发吧
    写回复
