[原创] 【LPC54100】LPC54102 通过I2C读取总线上的TMP275(板温度)
蓝雨夜   2015-5-23 14:01 楼主
目的:M0+核通过I2C总线,通过板上TMP275温度传感器,了解当前角度传感器使用的环境温度
占用端口:GPIO口
占用硬件资源   I2C
一、初始化I2C
int Init_I2C(void)
        uint32_t memSize, *devMem;
        ROM_I2CM_INIT_T i2cmInit;
        /* Setup I2C pin muxing, enable I2C clock and reset I2C peripheral */
        //Init_I2C_PinMux();
        Chip_Clock_EnablePeriphClock(LPC_I2CM_CLOCK);
        Chip_SYSCON_PeriphReset(LPC_I2CM_RESET);
        /* Get needed size for driver context memory */
        memSize = ROM_I2CM_GetMemSize();
        if (memSize > sizeof(drvData)) {
        devMem = drvData;        /* Or just use malloc(memSize) */
        /* Initialize driver */
        i2cmInit.pUserData = NULL;
        i2cmInit.base = (uint32_t) LPC_I2C_PORT;
        i2cmHandle = ROM_I2CM_Init(devMem, &i2cmInit);
        if (i2cmHandle == NULL) {
                /* Error initializing I2C */
        /* Set I2C clock rate */
        ROM_I2CM_SetClockRate(i2cmHandle, Chip_Clock_GetAsyncSyscon_ClockRate(), I2C_BITRATE);
        /* Code never reaches here. Only used to satisfy standard main() */
        return 0;
二、初始化TMP275
* 函数名:
* 输入:
* 返回:
* 描述:
void Init_TMP275(void)
        unsigned char RxData[3],TxData[3];
        Init_I2C();
        //读配置寄存器
        Read_TMP275(TMP275_Con_Reg,&RxData[0]);
        TxData[0]=0xFF;
        Write_TMP275(TMP275_Con_Reg,&TxData[0]);
        //读配置寄存器
        TxData[0]=0x00;
        //读配置寄存器
        //读配置寄存器
        //写配置寄存器
        TxData[0] =        TMP275_CR_12BITS|//12 Bits (0.0625°C)转换时间 220ms
                                TMP275_FQ6                |//故障队列
                                TMP275_ALERT_L        |//ALERT脚为H
                                TMP275_SM_E                |//连续转换模式
                                TMP275_TM_C                ;//比较模式
三、读写TMP275
* 函数名:
* 输入:
* 返回:
* 描述:
void Write_TMP275(unsigned char Reg_Address,unsigned char * data)
                /* Write address, write 1 btye, read 8 bytes back */
                i2cmXfer.slaveAddr = TMP275_ADDRESS;
                tx[0] = Reg_Address;        //寄存器地址
                tx[1]=data[0];                //寄存器值 MSB
                //tx[2]=data[1];                //寄存器值 LSB
                i2cmXfer.txBuff = tx;
                i2cmXfer.rxBuff = rx;
                i2cmXfer.txSz = 2;
                i2cmXfer.rxSz = 0;
                /* I2C master driver will block if blocking flag is used */
                i2cmXfer.flags = ROM_I2CM_FLAG_BLOCKING;
                /* Start transfer and wait for completion */
                ROM_I2CM_Transfer(i2cmHandle, &i2cmXfer);
* 函数名:
* 输入:
* 返回:
* 描述:
void Read_TMP275(unsigned char Reg_Address,unsigned char *RxData )
                i2cmXfer.txSz = 1;
                i2cmXfer.rxSz = 2;
          RxData[0]=rx[0];
          RxData[1]=rx[1];
四、读温度
nsigned int Read_TMP275_TEMP(void)
        unsigned char RxData[2] ;
        _ui2uc ui2uc;
        unsigned int temp=0;
        //读配置寄存器
        //读温度寄存器
        Read_TMP275(TMP275_Tem_Reg,&RxData[0]);
        ui2uc.ucdata[1]=RxData[0];
        ui2uc.ucdata[0]=RxData[1];
        temp=(ui2uc.uidata>>4);
        return temp;
这里没有在M0+核中进行浮点数的除法计算,而是把采样的温度码发送给M4,让M4做最终的浮点数计算!
回复评论
暂无评论,赶紧抢沙发吧
    写回复
