TFT彩屏初始化程序,看不懂,求解释
顺便问一句谁有TFT彩屏驱动(ST7735R )的中文资料
void TftInit(void)
REPort&=~RE;
DelayMs(100);
REPort|=RE;
DelayMs(100);
//-------------------Software Reset---------------------------------//
TftWriteCom(0x11);//Sleep exit
DelayMs(120);
//ST7735R Frame Rate 帧速率设置
TftWriteCom(0xB1); //正常模式全色彩
TftWriteData(0x01); TftWriteData(0x2C); TftWriteData(0x2D);
TftWriteCom(0xB2); //在待机模式
TftWriteCom(0xB3); //在部分模式全彩
TftWriteCom(0xB4); //Column inversion 显示逆控制
TftWriteData(0x07);
//ST7735R Power Sequence
TftWriteCom(0xC0); //功率控制1
TftWriteData(0xA2); TftWriteData(0x02); TftWriteData(0x84);
TftWriteCom(0xC1); TftWriteData(0xC5); //功率控制2
TftWriteCom(0xC2); //功率控制3 (正常模式/全彩)
TftWriteData(0x0A); TftWriteData(0x00);
TftWriteCom(0xC3); //控制功率4在空闲模式
TftWriteData(0x8A); TftWriteData(0x2A);
TftWriteCom(0xC4); //功率控制5在部分模式/全彩
TftWriteData(0x8A); TftWriteData(0xEE);
TftWriteCom(0xC5); //VCOM 控制11
TftWriteData(0x0E);
TftWriteCom(0x36); //MX, MY, RGB mode
TftWriteData(0xC8);
//ST7735R Gamma Sequence +伽码校正特性设置
TftWriteCom(0xE0);
TftWriteData(0x0F); TftWriteData(0x1A);
TftWriteData(0x0F); TftWriteData(0x18);
TftWriteData(0x2F); TftWriteData(0x28);
TftWriteData(0x20); TftWriteData(0x22);
TftWriteData(0x1F); TftWriteData(0x1B);
TftWriteData(0x23); TftWriteData(0x37); TftWriteData(0x00);
TftWriteData(0x07);
TftWriteData(0x02); TftWriteData(0x10);
TftWriteCom(0xE1); //-伽码校正特性设置
TftWriteData(0x0F); TftWriteData(0x1B);
TftWriteData(0x0F); TftWriteData(0x17);
TftWriteData(0x33); TftWriteData(0x2C);
TftWriteData(0x29); TftWriteData(0x2E);
TftWriteData(0x30); TftWriteData(0x30);
TftWriteData(0x39); TftWriteData(0x3F);
TftWriteData(0x00); TftWriteData(0x07);
TftWriteData(0x03); TftWriteData(0x10);
TftWriteCom(0x2A); //列地址设置
TftWriteData(0x00);TftWriteData(0x00);
TftWriteData(0x00);TftWriteData(0x7F);
TftWriteCom(0x2B); //行地址设置
TftWriteData(0x00);TftWriteData(0x9F);
TftWriteCom(0xF0); //Enable test command 使能测试命令
TftWriteData(0x01);
TftWriteCom(0xF6); //Disable ram power save mode
TftWriteData(0x00);
TftWriteCom(0x3A); //65k mode 接口像素格式
TftWriteData(0x05); //18-bit/pixel
TftWriteCom(0x29); //Display on
